mulligan
FL, USA Status: offline
Got mine late last week... for $500- couldn't wait for the better deals Over the long 4th weekend, I was able to get it 80% done. Is it just me, or are ARF time-to-complete estimates a crock??? 18-22 hours my butt. Anyway, having fun with this one- not too many issues. Of course, hardware went into the trash- 4-40 rods and Sullivan hardware is definitely the way to go- especially with the long runs up the fuse. And standard servos simply won't do, although I don't think this plane justifies digitals. I used some 60 oz.-in. servos on all control surfaces- a bit higher on rudder. I'm using a 6V system with redundant batteries/switches. A bit of a pain in the rear is the servo orientations. You can only "Y" the ailerons. The elevator and flap halves have to be reversed from each other, so I'm using eight channels. Wing went on with no saddle issues for me- at least one person here had issues- must be luck of the draw. I added some air cylinders I had lying around to actuate the included retracts- looks like some shimming is needed though to prevent wobbling. Also, I epoxied gear doors instead of using screws- I didn't want to mess up the sharp look of these doors. Some of the hinge slots weren't centered or deep enough. Tim, I thought I (and G) were on the high side with a Moki 1.8, but a 2.1??? Sheeesh. And it wasn't nose heavy? That's encouraging, as I thought I would have to add tail weight with the 1.8. Still waiting on my J-Tec muffler before I can install engine and cowl. Might be flying this weekend if I'm lucky. BTW, G, can you approximate how much cant you used on your engine mount? This will help me approximate the cutting of my radial backplate. - George
