Overview
Tower Hobbies
Logged in as Guest
  Printable Version
More Resources on the
P-51 Mustang 150
  • 4 Active Classified Ad(s)
  • Read Full Review
  • See User Ratings
  • Suggest Compatible Equip.
  • Check for Retailers
  • Discussions on this Product
  • All Forums >> RC Airplanes >> RC Warbirds and Warplanes >> Overview
    Page: <<   < prev  3 4 [5] 6 7 8 9 10 11 12   next >   >>
    Login
    Overview - 7/23/2003 6:52:10 AM
    Countryboy
    Status: offline
    Pic showing overview of the 622 layed out on the wing.
    Click to see fullsize image.
    Click for fullsize
    (in reply to 48chebbie)
           Post #: 101
    Overview #2 - 7/23/2003 7:00:55 AM
    Countryboy
    Status: offline
    Pic showing the Centurion layed out.
    With the proper strut length, I think the Centurion in an 85 degree would be a good choice for retrofit. Also the Robart 531 would be a good choice.
    Don't take offense Kyle2Baseball, just pointing out what might have of been a mistake in your Robart # selection. If I'm wrong, the flame suit is on.
    Click for fullsize
           Post #: 102
    Hangar 9 150 Size P-51 - 7/23/2003 8:13:43 AM
    Kyle2Baseball
    Status: offline
    Hey Countryboy,
    Wouldn't you know it, I called Horizon Hobbies tech support and they told me the 622'S would be a direct replacement.
    Go figure
    Thanks for your feed back.
    _____________________________
    I hate Florida Weather
    I want to fly more
           Post #: 103
    Hangar 9 150 Size P-51 - 7/23/2003 8:15:07 PM
    mulligan
    Status: offline
    Countryboy,
    It appears the Robart 531s rotate away from actuator; the 551s rotate towards the actuator, thus they seem to be a better choice if they can clear the gear bay. What's your opinion?
    Also, I'm looking at Robart straight struts 660s as opposed to 650s for length- you agree?
    Finally, does anyone know how those gear door mounting brackets (e.g., #660DB) attach to the door?
    George
    < Message edited by mulligan-RCU -- Jul 23 2003 3:33PM >
           Post #: 104
    Hangar 9 150 Size P-51 - 7/23/2003 9:59:49 PM
    Countryboy
    Status: offline
    [QUOTE]Originally posted by mulligan
    Countryboy,
    George,
    You are correct.... the 551 series would be the better choice. After going back and reviewing Robarts site, I see that the 531 retraction angle is measured from the opposite end of the actuator. Nice catch!!!
    If you choose to go with the straight leg strut, the 660 would be the way to go. The 650's appear to be too light duty also. My personal preference on the strut would be to go with the offset yoke in that series. If you are going to go through the expense.... might as well get the look to go with it. Also, one might have to do some trimming of the wheel well to clear the scissor links.
    Can't answer this one for sure, as I have never used them. Have an idea as to how they attach, but without seeing them first hand, can't say for certain.
    George
    [/QUOTE]
           Post #: 105
    Hangar 9 150 Size P-51 - 7/23/2003 10:30:08 PM
    mulligan
    Status: offline
    Hmmmm, the offset yolk would look better when down, but since the retracts only retract 85 deg., I thought the wheel would not be fully in the bay, and the door would not close fully.
    If you look at the geometry of the 622 (even though it's not a possibility), it actually retracts 90 deg., (85 deg. from down position + 5 deg. extra). Strut is not flush with wing, giving extra room for an offset yolk and wheel to fit in bay.
    What to do, what to do?
    - George
           Post #: 106
    New Robart Gear for H9 Mustang 150 - 7/23/2003 10:44:14 PM
    NoGuts_NoGlory
    Status: offline
    A very reliable source said that Robart is currently working on a set of retracts specifically for this plane. When will they be ready? - "soon".
    Howard
           Post #: 107
    Hangar 9 150 Size P-51 - 7/24/2003 12:49:31 AM
    mulligan
    Status: offline
    Crap. That puts me in a quandry.
    Thanks for the news, though, Howard.
    I was also toying with the idea of getting the 550 90 deg. retracts with 662RL offset yolk struts and mounting at a 5 deg. tilt inside the wing. Gear down would be 85 deg. and the gear up would be 5 deg. into the wing, which would keep everything inside the wing. That would require some gear bay mods, but really anything you do would require some mod.
    - George
           Post #: 108
    Hangar 9 150 Size P-51 - 7/24/2003 5:10:59 AM
    Countryboy
    Status: offline
    George,
    If the wing had no dihedral, life would be simpler. Such is not the case though. If you go back & look at the 551 diagram, you will see that in the fully retracted position, that the strut remains at 90 deg. to the actuator/ pivot point. From this point, the strut will only swing through an 85 deg. arch.
    The relative angle between the retract mounting rails & the wheel bay does not change. Now picture the retract mounted in the wing.... in this case the 551 diagram as shown on Robart's site. Now visualize that retract mounted in the left wing panel "Viewed from Trailing Edge" with the wing panel blocked up to have the correct dihedral, and tell me what you see.
    The way I view it, that will put the wheel at, or close, to 90 deg. to earth when in the extended position, and should not affect the retraction angle. The retract, even though the wing has dihedral, will still be at 90 deg. to the wing.
    Does your head hurt.... mine sure does.
    The 622-5 retract for the T/F 1/5 Mustang has problems in it's own right. That extra 5 deg. causes problems in mounting geometry also. I haven't seen one of these yet, that when sitting on the ground.... did not look like a new born Colt trying to stand for the first time.
    You tell me!!!
    - George
    [/QUOTE]
           Post #: 109
    Hangar 9 150 Size P-51 - 7/24/2003 6:28:19 AM
    rc34074
    Status: offline
    why not look at the spring air 400 series retracts? they would fit much easier than the robart 622s and they are strong gear-at least as strong as the robart 622 retracts. [url]www.retracts.com[/url]
    ed
    "there are fighters and there are targets"
           Post #: 110
    Hangar 9 150 Size P-51 - 7/24/2003 6:41:30 AM
    mulligan
    Status: offline
    This is what I was thinking about...
    - George
    Click for fullsize
           Post #: 111
    P51 Gas - 7/31/2003 7:19:26 PM
    Stagwing
    Status: offline
    I'm putting a G23 in mine. I have wanted to move up to gas for a while and I happen to have a new G23 just sittin there begging to be used. I'll let you know how it works out. I have access to some pretty good modelers around here so brain storming the installation should not be that much of a problem. If anyone else out there has already used a G23 or G26 send pictures of your setup. Dan
    dwt
           Post #: 112
    price??? - 8/1/2003 11:13:28 PM
    yard-dart
    Status: offline
    I'm kinda like P-51B, this plane seems to be a little pricey. I've put some numbers together on what it would take to complete this plane:
    $500.00 Plane
    $400.00 Engine
    $250.00 Servos
    $50.00 Spinner
    $1200.00 Minimum
    Now I don't mean to sound like a tight-ass, but this seems a little much. I know that all of these items are mandatory, but $500.00 for a plane that's not even considered a big bird is a little overkill.
    I've got the 1/4 scale Pacific Aeromodels Laser, which is a big bird with a gasser, and I only have around $900.00 in it. I am aware that there is no comparison between it and the mustang, but still, a plane is a plane. The quality of my laser is great, so quality is no longer an issue. All planes "should" be of good quality anyway.
    I am no tightwad when it comes to planes, my wife will tell you that, but I just think this 'stang is a little to harsh on the pocketbook. I think $399.00 is about the "max" that should be charged for this bird. I think I'll wait for the price to come down a little before I purchase it, and I'm quite sure it will come down.
    John
           Post #: 113
    Hangar 9 150 Size P-51 - 8/2/2003 12:43:22 AM
    P-51B
    Status: offline
    Yard-Dart,
    I was able to get one at my LHS for $370.00. I also called Doug's hobby shop in Waldorf, MD., they had them for either $390 or $370 (I can't remember which). You can find their advert in RCM.
    I already have a saito 180 (...unless I decide to go gas) and radio gear. I will have to get a spinner for it though.
    In order to think "outside the box", one must first accept there IS a box.
           Post #: 114
    Retracts - 8/2/2003 2:53:12 AM
    airspeed917
    Status: offline
    I have been talking with Robart,, They got themselves the wing for this plane and figured out the best pair of retracts for it. Here is what I was Told. This is the actual reply.
    Ron:
    The powers that be have decided the Robart 551RS 85 deg Retract mechanisms will work, but this means converting to a pneumatic system rather than mechanical. They also suggest the 660 Robostruts with a 3-1/4 wheel. There will not be any major modifications to the wing with these suggestions. Hope this helps.
    Sincerely
    Gary Ernst
    Robart Mfg.
