Re: Hor Stab
Tower Hobbies
Logged in as Guest
  Printable Version
More Resources on the
P-51 Mustang 150
  • 4 Active Classified Ad(s)
  • Read Full Review
  • See User Ratings
  • Suggest Compatible Equip.
  • Check for Retailers
  • Discussions on this Product
  • All Forums >> RC Airplanes >> RC Warbirds and Warplanes >> Re: Hor Stab
    Page: <<   < prev  4 5 [6] 7 8 9 10 11 12 13   next >   >>
    Login
    Re: Hor Stab - 8/3/2003 1:35:30 AM
    Countryboy
    Status: offline
    [QUOTE]Originally posted by airspeed917
    Can someone who already owns this plane tell me if the Hor Stab is fully sheeted or just built up,,,,, I have a friend who has the 60 size and the Hor Stab broke off in flight two inches in from the fuse, on both sides,,,,, its got me worried about the H9 1:50 [/QUOTE]
    airspeed917,
    The stabs are fully sheeted on the 150. They appear to be very rigid & up to the task.
    (in reply to 48chebbie)
           Post #: 126
    Re: Interesting "Very Interesting" - 8/4/2003 12:06:31 AM
    mulligan
    Status: offline
    [QUOTE]Originally posted by Countryboy
    Mulligan,
    I understand your philosophy in what you are trying to accomplish, but what do you propose to do with the retract mounting rails. Are you planning to modify these in any way?
    How are you going to cock the retract, without the outboard part of the retract frame extending past the lower surface of the wing....without modifying the rails?
    Notice in the attached pic,,, if you were to lower the wheel deeper in the wheel well, the outer edge of the retract frame is going to raise proportionally. The five degree tilt angle you propose, will extend the outboard edge of the retract frame about .175 below the skin. How do you plan to compensate for this?
    When you say that a offset yolk can not be used without cutting a slot in the wheel liner, are you referring to the bottom of the liner, or where the side wall and the strut cutout meet?
    [/QUOTE]
    Yes, the retract rails will need to be excavated with a dremel to be at 5 deg. relative to the wing bottom. I will also add some hardwood under the existing rails to beef it up a bit to compensate for the lost material. The outboard edge of the retract will not protrude below the bottom of the wing. Rather, the inboard portion of the retract will be submerged into the wing.
    The slot for the offset yolk will be on the "bottom" of the liner, and it will extend from the outboard side of the liner to the middle of the round wheel section.
    Again, if you look at my drawing in post #111, you can see how the retract is rotated and how the strut penetrates the existing liner geometry. I didn't mention it, but obviously I will have to make a cut-out for the spring hinge of the oleo as well.
    - George
    < Message edited by mulligan-RCU -- Aug 3 2003 7:12PM >
           Post #: 127
    Engine selection - 8/8/2003 6:41:03 PM
    Stagwing
    Status: offline
    After careful consideration, much research and sleepless nights, I have decided to use the RCS F 180 (front induction) engine. The engine weighs 3.5 Lbs., pumps out 4 HP, with a 20 x 8 MenzS at 6800 RPM it is reported to yield 21.57 Lbs static thrust. Should haul the mail....Much thanks to Mike Dooley/RCS for helping me decide which engine to use on the new Hangar 9 P51 big bird.
    As a result of this descision I have two Zenoah engines for sale, no trades.
    G-62 new, un-used with throttle kit....$420 plus shipping in the USA
    G-23 ran 3 times, not strong enough, has AT6 spinner, throttle kit installed, almost new condition....$240 plus shipping in the USA
    Money orders, cashiers checks only
    e-mail [email]dwtaylor12@juno.com[/email]
    Dan
    (Stagwing)
    _____________________________
    dwt
           Post #: 128
    Hangar 9 150 Size P-51 - 8/10/2003 8:18:56 AM
    mulligan
    Status: offline
    Pics of my retract setup...
    Robart 530RS retract & 662R/L struts mounted such that strut retracts 5 deg. into wing...
    - George
    Click to see fullsize image.
    Click for fullsize
           Post #: 129
    Hangar 9 150 Size P-51 - 8/10/2003 8:19:48 AM
    mulligan
    Status: offline
    Pic 2...
    Click for fullsize
           Post #: 130
    Hangar 9 150 Size P-51 - 8/10/2003 8:20:23 AM
    mulligan
    Status: offline
    Last one...
    Click for fullsize
           Post #: 131
    Hangar 9 150 Size P-51 - 8/11/2003 9:57:29 PM
    clayfoushee
    Status: offline
    I also just picked one up and plan on using a Saito 180. Any recommendations on a good 4-blade prop choice and 5" spinner to fit?
    Clay
           Post #: 132
    Hangar 9 150 Size P-51 - 8/11/2003 10:24:32 PM
    clayfoushee
    Status: offline
    I agree that the livery on this machine leaves much to be desired and that there are many more beautiful schemes out there from actual combat aircraft. I would add Gen. (then Capt.) Chuck Yeager's Glamorous Glenn III to the list.
    Has anyone found a good place to purchase decals the right size, so that we can at least partially customize the scheme? With apologies to Freddie Ohr and "Marie," between the 2 H9 P-51 kits, there are too many out there!
    Clay
           Post #: 133
    Hangar 9 150 Size P-51 - 9/2/2003 1:41:12 AM
    LBECKWITH
    Status: offline
    talked to some guys at the Dayton show from Horizon. Got the impression they are working with their manufacturer to improve the retracts on the 1.50 size P-51. Any one else hear anything about this. I hate to shell out big $$$ for air retracts if they will have a fix down the road.
           Post #: 134
    Hangar 9 150 Size P-51 - 9/2/2003 2:48:41 AM
    mulligan
    Status: offline
    Improvements would be a waste of time... unless the "improvement" is to go to some robust pneumatic retracts. I hate to say it, but you might as well assume the cost of the plane to be $250 more for some real reatracts. The silver lining is that the mechanical retracts that you pull out of the plane might be useful for something smaller or not as attractive.
    - George
           Post #: 135
    saito 180 - 9/2/2003 9:10:28 AM
    rckymtn1
    Status: offline
    would the saito 180 be completely enclosed inside the cowl of the Hangar 9 p51 1.50?, or would the heads, etc be shown?
    thanks..
           Post #: 136
    Hangar 9 150 Size P-51 - 9/2/2003 10:50:54 PM
    jmiracle
    Status: offline
    I'm seriously considering one of these birds, but I want to put a gas engine in it as opposed to the saito.
    Can anyone give me a measurment from the firewall to the nose ring? A measurement across the nose of usable space inside the cowl would be nice too.
    Thanks!!
           Post #: 137
    Hangar 9 150 Size P-51 - 9/3/2003 2:59:46 AM
    mulligan
    Status: offline
    Saito 180 heads protrude through the cowl about 1/4".
    Length of cowl (firewall to front of cowl): 6 1/4"
    General dimensions of firewall: 5 3/4" x 8 1/4"
    Approximate maximum height of engine head to remain within cowl: 4 1/4" above centerline
    Usable space within cowl at nose: about 4 3/4" diameter just inside cowl with an additional 1" of air scoop space about 1/2" back.
    - George
           Post #: 138
    Hangar 9 150 Size P-51 - 9/5/2003 3:33:36 AM
    Ken Bridges
    Status: offline
    Hey Guys, I just finished H9 150 p51 last week. I have 10 flights on it. I had to change the retracts to pneumatic spring air with robostruts. This combination is just great.
    The engine I used is a BME 50cc. I am using a three blade prop from zinger with a 5 inch spinner also from zinger.
    This plane is awesome. I love it. Flys like a real warbird.
    Check my gallery. Will try to post some pictures.
    - Ken
           Post #: 139
    Hangar 9 150 Size P-51 - 9/5/2003 7:37:28 AM
    clayfoushee
    Status: offline
    That's great Ken. Haven't gotten around to starting mine, but what type of retracts did you use. Based upon what I've heard here, I'm definitely not going to use the factory supplied retracts. Everyone on this forum disses them.
    Clay
