RE: Hangar 9 150 Size P-51
Tower Hobbies
Logged in as Guest
  Printable Version
More Resources on the
P-51 Mustang 150
  • 4 Active Classified Ad(s)
  • Read Full Review
  • See User Ratings
  • Suggest Compatible Equip.
  • Check for Retailers
  • Discussions on this Product
  • All Forums >> RC Airplanes >> RC Warbirds and Warplanes >> RE: Hangar 9 150 Size P-51
    Page: <<   < prev  6 7 [8] 9 10 11 12 13 14 15   next >   >>
    Login
    RE: Hangar 9 150 Size P-51 - 9/15/2003 3:27:17 AM
    Asanders
    Status: offline
    Nice photo Capt G ! I love it !
    (in reply to Capt G)
           Post #: 176
    RE: Hangar 9 150 Size P-51 - 9/17/2003 2:47:21 PM
    pettit
    Status: offline
    BTW, this plane "is available". Complete, no receiver.
    Email please
    Click to see fullsize image.
    Click for fullsize
    Click for fullsize
    < Message edited by pettit -- 9/17/2003 9:49:33 AM >
    _____________________________
    Dick Pettit
    Associate Editor, R/C REPORT Magazine
    "You Can Buy Better,
    But You Can't Pay More"
    (in reply to pettit)
           Post #: 177
    RE: Hangar 9 150 Size P-51 - 9/17/2003 2:56:55 PM
    P-51B
    Status: offline
    quote:
    ORIGINAL: pettit
    Email please
    What is the settup you ended up with?
    In order to think "outside the box", one must first accept there IS a box.
           Post #: 178
    RE: Hangar 9 150 Size P-51 - 9/17/2003 2:57:10 PM
    pettit
    Status: offline
    I live in Durham, NC. I can deliver within 150 miles, if the Hurricane doesn't deliver it sooner!
    Dick Pettit
           Post #: 179
    RE: Hangar 9 150 Size P-51 - 9/17/2003 3:04:46 PM
    P-51B
    Status: offline
    Never mind, I found it back in the posts I was looking at (you know the old forest for the trees routine!)
    Century jets with a saito.
           Post #: 180
    RE: Hangar 9 150 Size P-51 - 9/17/2003 3:06:04 PM
    pettit
    Status: offline
    By "setup" I assume you mean equipment and performance.
    I used the Saito 200 Inline Twin turning an APC 18-6 wide prop at 8500 static. Exhaust is Saito flex pipes. Uses Century Jet retracts with stock wheels and adjustable air valve. Hitec HS-425BB servos all around (except HS-55 on air valve) 1650 mah NiMH 5 cell battery Tru-Turn 5" spinner, JHM DGS-2 on-board glow lighter, graphics, pilot and dash by Cajun.
    Flies just fine. Weighs just over 16 pounds dry. Not absolute vertical, but good enough for 2 victory rolls. Lands fine with or without flaps. Sounds like no other engine I have ever heard. Not like an opposed twin, more like, well, an inline 6!
    Duplication cost would be well over $2000.00
    Bottom line? Knock off 30%. No trades.
    May consider without engine and on-board glow, but you'd need another chin cowl, or use the same engine. For this, knock off 50% from duplication cost
    < Message edited by pettit -- 9/17/2003 10:10:46 AM >
    Dick Pettit
    (in reply to P-51B)
           Post #: 181
    retract - 9/18/2003 1:43:48 AM
    rckymtn1
    Status: offline
    Countryboy..., in response to your post no. 120 on the century jet retract.., is the p/n, etc you used as per century's site as follows:
    Hargar 9 P-51 150 with 1/2" Struts
    Product #: 35388
    "These landing gear are specifically designed for the new 77" wing span Hangar 9 P-51 150. They come with 2 upper mechanism, two 1/2" diameter stainless steel oleo struts, axles, and air system".
    Were you able to put the doors on, and how are they working out for you so far? Easy modification to install? Was the above P/N what you installed?
    thanks...
           Post #: 182
    RE: retract - 9/18/2003 8:04:25 PM
    oriole
    Status: offline
    Hey Pettit,
    Why are you selling this aircraft? It's only been on the market a couple of months?
    Oriole
    (in reply to rckymtn1)
           Post #: 183
    RE: retract - 9/19/2003 4:44:36 AM
    LBECKWITH
    Status: offline
    I am getting some spring loaded struts from Canada to replace the supplied 9forever bending) wires that come with the H9 P-51 1.50. Due to some time out of time out of town I won't get to fly with them until after 10-1. I'll post a report then. PS: I tried heat treating the supplied wires but they got so brittle that one snapped in half. Horizon told me today that they are ready to take orders for some new titanium wires for this bird but shared some concern that a bad landing could cause some damage to the retract support rails.
    (in reply to oriole)
           Post #: 184
    RE: Hangar 9 150 Size P-51 - 9/19/2003 7:13:07 PM
    krkenned
    Status: offline
    Just got mine in yesterday. Stole it for $355 NIB. This is a great looking plane. Any ideas on where I can find black 4-blade props?
           Post #: 185
    RE: retract - 9/19/2003 11:33:26 PM
    limitlss
    Status: offline
    I epoxied and fiberglassed in some 1/4" aircraft grade ply under the rails. It really seems to have helped.
    (in reply to LBECKWITH)
           Post #: 186
    RE: retract - 9/20/2003 12:44:45 AM
    Countryboy
    Status: offline
    quote:
    retract (in reply to pettit) Contact Moderator | (Post No. 182)
    Product #: 35388
    thanks
    rckymtn1,
    Yes, that is the correct p/n for the retracts. To install the retracts in the stock mounting rails is very easy, with only minor trimming necessary. The drawback.... the wheels will not be fully in the well. The back side of the tire will be exposed outside the wheel well. The strut will also not be recessed enough to install the doors flush with the skin.
    The only way to remedy this is to modify the mounting rails to get the gear deeper into the wing. This will hold true for other retracts of similar style to the Century Jet retract. Witness that Mulligan went through the same problems while installing Robart gear.
    Hope this has helped in answer to your questions.
           Post #: 187
    RE: retract - 9/20/2003 2:53:22 AM
    rckymtn1
    Status: offline
    thanks countryboy..., that answers it....
    how have they been working out for you so far?
    (in reply to Countryboy)
           Post #: 188
    RE: p51 - 9/20/2003 1:55:43 PM
    hawk103
    Status: offline
    I have the hanger 9 p51 150 size. Ive flown it 11 times, and 11 times she nosed over on landing. how do I resolve this??????????
    are the wires flexing back and breaking cg?? people suspect at the field.
    can any one help??. and its a grass field.
    thanks hawkman103
           Post #: 189
    RE: Hangar 9 150 Size P-51 - 9/20/2003 9:01:39 PM
    skyking650
    Status: offline
    Hello,
    Flown 5 flights on mine.....very easy to assemble and flys perfectly.
    Engine: Saito 180, 18x6 prop
    Radio: Futaba 9ca
    Servos: All 3004s except rudder Hitec 585 metal gear, retracts Hitec 75BB
    Battery: 1400MAH NMHi
    Ran a tank of 15% through it on the ground at 4000 rpms or less, then took to the sky. The engine runs flawlessly and is still slightly rich. Control throws are aggressive on high. Flaps work! No crazy ballooning..you can run out and catch the thing landing with flaps!
    Using Dave Brown Aluminum spinner. Balanced at 6.375" required 8 OZ lead attached inside of engine compartment. Total weight is 15lbs
    Using factory retracts, the retracts work perfectly..but the wire is soft and bends regardless of how soft you land (I fly off of grass) The airplane has no tendancy to nose over during takeoff or landing. One NOTE: I had to strengthen the stringers that hold the landing gear in place as they cracked after the first landing....be aware of this.
    I am going to try a set of Robart 660 struts with a pair of cut off 3/16 grade 8 hardness bolts (using the long shank as a wire). This should cure the only problem that this airplane seems to consistantly display.
    Otherwise, it is easy and fun to fly, gets crowd appeal, and looks awesome along side of my GS Corsair, 1/3 scale pitts and F-16 at the flying field.
    Best of luck
