SJ46 + Q500 Pipe = Propeller help??
Tower Hobbies
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Engine Manufacturers Direct Support Forum >> Jett Engineering Support >> SJ46 + Q500 Pipe = Propeller help?? Page: [1]
Login
SJ46 + Q500 Pipe = Propeller help?? - 3/27/2009 10:02 PM
YUKONFLYR
Score: 100
Last Login: 11/6/2009
Status: offline
Hello Bob -
Mounting my Vintage SJ46 with the short Q500 pipe on a q40 Stiletto. The plane has a moulded in section for the pipe, so the reg SJ pipe is too long and would need a spacer to make it fit.
What would be a good starting prop, 8.8x8.25 chopped to 7.8"? Im guessing and need a little help. I did run the engine with a 8.8x8.75 and it seemed to much prop for it.
Thanks in advance for your advice
Richard
_____________________________
<Nitro><Pistons><Castor>
Revver Bro 178
Hide Signatures
       Post #: 1
RE: SJ46 + Q500 Pipe = Propeller help?? - 4/1/2009 4:27 AM
bob27s
Score: 100
Last Login: 11/8/2009
Status: offline
Hi Rich....
The SJ46 with the q-500 pipe still has to hit the rpm targer.
Your setup will run more like the older SS-40 engine. Look for a prop that turns about 18,000 to 18,500 peak rpm on the ground.
Don't get hung up on what the pitch is. You have to get the rpm for the muffler to work.
A 8.8x8.75, 8.8x8.5 or your x8.25 cut to about 8" diameter should get you there. Also look at trying the APC 8.5x7.25 - stock, dont cut it - you have enough ground clearance (you might be surprised )
Bob
Bob Brassell
Jett Engineering - Engine Mfg Support Forum Host
Hide Signatures
(in reply to YUKONFLYR)
       Post #: 2
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.342RCU1
