RE: NEW H9 P51 Mustang 60 ARF    Gallery
Logged in as Guest
    Search This Thread
Printable Version
Scale Mustang Exhaust - Kit
Seller:  tony-howard
Details:   $35.00   |  5/1/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> RC Warbirds and Warplanes >> RE: NEW H9 P51 Mustang 60 ARF
Page: <<   < prev  64 65 66 67 68 69 70 71 [72] 73   next >   >>
Login
RE: NEW H9 P51 Mustang 60 ARF - 11/10/2012 5:49 PM
jet22b
Score: 110
Last Login: 5/22/2013
Status: offline
quote:
ORIGINAL: bboytab
My flaps now is installed but i dont know how to make it move in the same direction. It works now like an aileron when i deploy.
Yes, race track is still here, i live a mile away. A lot of people still go there but they no longer have races. Thanks
bboytab.
In one of your post, you said you have a 8ch Tx. You can hook one of the flap to the flap channel and hook the other one to a open channel. Then you must go into the tx and mix and or slave that channel to the flap channel. Now you have to change from the Y-Harness to servo extension for both flaps servos. Check your Tx manual to see how this is done or ask one of your club member for help. I have this setup for the flaps on my H9 Jackal 50 and did have this setup on my H9 P-51. She die hard!! Thanks for the info on the track!! Let me know if this help!!
Sonny
aka
jet22b
_____________________________
Spitfire Brotherhood #12
P-40 Brotherhood #52
Hide Signatures
(in reply to bboytab)
       Post #: 1776
RE: NEW H9 P51 Mustang 60 ARF - 11/11/2012 1:34 PM
bboytab
Score: 100
Last Login: 5/11/2013
Status: offline
It did work.... Thanks sonny aka jet22b!
Hide Signatures
(in reply to jet22b)
       Post #: 1777
RE: NEW H9 P51 Mustang 60 ARF - 11/12/2012 4:09 AM
paladin
Score: 250
Last Login: 5/21/2013
Status: offline
bboytab, you need a reversing y
http://www.horizonhobby.com/products/super-cub-dsm-rtf-EXRA325
Joe
If it don't fly it wont ketch my eye.
Hide Signatures
       Post #: 1778
RE: NEW H9 P51 Mustang 60 ARF - 11/13/2012 4:39 PM
bboytab
Score: 100
Status: offline
quote:
ORIGINAL: paladin
Joe
Thanks joe, i was able to make it work by plugging the flap servos to aux 1 and aux 2 on my 8 channel receiver. I have a Spektrum DX8. It now works but i notice that both the flap servos makes a buzzing sound at normal position. It would go away if i touch the flaps or give it a little load. I did check and there is no binding on both.
Hide Signatures
(in reply to paladin)
       Post #: 1779
RE: NEW H9 P51 Mustang 60 ARF - 11/13/2012 6:13 PM
jet22b
Score: 110
Status: offline
bboytab.
Like I said before, I have this set up on my H9 Jackal 50 and my flaps servos are doing the same thing!! Buzzing like bees!! I took the control rods off and the buzzing would stop. Put the rods back on and the buzzing would start again!! I also check for binding and proper center on both servos, but still could not stop the buzzing. So I fly with the buzzing and had no problem putting the flaps up or down!!
Sonny
aka
jet22b
Hide Signatures
       Post #: 1780
RE: NEW H9 P51 Mustang 60 ARF - 11/14/2012 12:15 AM
paladin
Score: 250
Status: offline
bboytab,
air pressure will take care of the deployed side. I take care of the clean side by reducing the servo travel one click at a time in the TX ATV function till it stops. usually the delta is noticeable.
i have a 9503 so idk how to do this on your radio.
Joe
Hide Signatures
       Post #: 1781
RE: NEW H9 P51 Mustang 60 ARF - 11/15/2012 7:26 PM
bboytab
Score: 100
Status: offline
quote:
ORIGINAL: paladin
bboytab,
Joe
thanks.....what prop size do most people use with the blue nose P51 - DLE 20 setup? im thinking of a 15x10 or a 16x8
< Message edited by bboytab -- 11/15/2012 9:22 PM >
Hide Signatures
       Post #: 1782
RE: NEW H9 P51 Mustang 60 ARF - 11/16/2012 1:14 AM
tailskid
Score: 199
Status: offline
I'm currently running a 16/8 on mine, but tomorrow I'm going to try a 15/8 which I've heard is a good combo for the DL20.
# 93 in Club Saito
Carl Goldberg Ultimate Brotherhood # 12
Hide Signatures
       Post #: 1783
RE: NEW H9 P51 Mustang 60 ARF - 11/16/2012 3:48 AM
bboytab
Score: 100
Status: offline
quote:
ORIGINAL: tailskid
i have a 15x8 on hand but was thinking on getting a 16x8. pls let me know the outcome tomorrow if i'll keep this prop...
Hide Signatures
(in reply to tailskid)
       Post #: 1784
RE: NEW H9 P51 Mustang 60 ARF - 11/16/2012 7:13 AM
tailskid
Score: 199
Status: offline
Will do! Actually I found TWO NIB 15/8 props today......gotta go thru the inventory more often
# 93 in Club Saito
Hide Signatures
       Post #: 1785
RE: NEW H9 P51 Mustang 60 ARF - 11/17/2012 4:51 PM
tailskid
Score: 199
Status: offline
Sorry, it was a Master Airscrew 15/6 and it flew not so good....way too much RPM as I tacked it at 10836 sitting on the ground. I'll keep looking for a 15/8 as I've heard they work the best with the DLE20.
# 93 in Club Saito
Hide Signatures
       Post #: 1786
RE: NEW H9 P51 Mustang 60 ARF - 11/26/2012 2:34 AM
Johnysza
Score: 100
Last Login: 5/16/2013
Status: offline
 Hi there, Are you still looking for canopy for the mustang?
I have extra canopy and some other spear parts like spinner tail,rudder etc.
thanks
john
Hide Signatures
(in reply to F-16WpnsTech)
       Post #: 1787
RE: NEW H9 P51 Mustang 60 ARF - 11/26/2012 3:18 AM
Johnysza
Score: 100
Status: offline
Shick looking setup.
quote:
ORIGINAL: Jason Lewis
Cockpit
Hide Signatures
(in reply to Jason Lewis)
       Post #: 1788
RE: NEW H9 P51 Mustang 60 ARF - 11/26/2012 3:32 AM
Jason Lewis
Score: 100
Status: offline
Thank you
Hide Signatures
(in reply to Johnysza)
       Post #: 1789
RE: NEW H9 P51 Mustang 60 ARF - 11/26/2012 11:19 PM
bboytab
Score: 100
Status: offline
Finally, maiden flight last week was good. Half a gallon now to the new DLE20. On the ground, plane noses over easily and on take off run. It was a lot better after moving the battery behind the servos. I still have to hold up-elevator while taxiing and for the 1st part of the take off, slowly releasing once airborne. Once in the air, it flies really good, i just keep the speed up to avoid any chance of stalling, landing was also a bit challenging, have to apply up-elevator on touch down.
Anyone have this lying around? Need one for the RIGHT landing gear, I may have thrown mine in the trash.
< Message edited by bboytab -- 11/27/2012 4:05 PM >
Hide Signatures
       Post #: 1790
RE: NEW H9 P51 Mustang 60 ARF - 11/27/2012 12:20 AM
Chris Nicastro
Score: 123
Status: offline
I can see from your photo of plane that the gear is too vertical. The way these warbirds like to work best is if the axle is in front of the wing leading edge. From the top view or side view the wheel should be ahead of the wing.
One way to fix it might be to shim the back fo the retract mech with a washer or wood shim. Do not bend the strut to fix this.
Once you adjust this geometry the plane will be very stable in all respects when taking off or landing.
Also another trick is to add a small amount of toe out at the wheels. What this does is to help keep the plane tracking straight and stable. The wheels will pull in opposite directions and this settles the plane when landing. If you touch down on one wheel first it will not provoke the plane to roll over on to its wing tip. Toe in will do this and zero toe causes some nervouse tracking behavior. You can usually adjust this at the trunion in the mechanism by filing the strut flat spot position or carefully twisting the wire strut, either way.
Like a midget in a urinal I knew I had to stay on my toes...
Hide Signatures
       Post #: 1791
RE: NEW H9 P51 Mustang 60 ARF - 11/27/2012 12:45 AM
ALWAYSPDG
Score: 101
Last Login: 5/1/2013
Status: offline
Hey Chris.
You said, "You can usually adjust this at the trunion in the mechanism by filing the strut flat spot position", how do you do this exactly?
Mike
Hide Signatures
(in reply to Chris Nicastro)
       Post #: 1792
RE: NEW H9 P51 Mustang 60 ARF - 11/27/2012 2:24 AM
Chris Nicastro
Score: 123
Status: offline
In a lot of cases there is a set screw that tightens on to a flat on the strut wire. You can file the flat slightly to change the toe angle. If your not comfortable with this then put the strut wire in a vise at the spring coil if it has one. Twist the strut axle just a little bit and do the opposite to the other one. If the axle is the type thats assembled then the flat on the strut can be filed instead. It just depends on how the H9 struts are built.
I just looked closer at the struts in the photo, are those Robo Struts or did H9 supply those?
Are the retracts stock H9 or are they Robart?
When Ive done this with H9 mechanical retracts and Robo Struts I made the toe angle prior to filing the flats on the mucis wire stub. You can use a Sharpie marker to paint black on the music wire. Using the set screws in the strut you can set the angle and mark the wire. Then you file the flat and adust it as needed until you remove about 0.5-0.75mm to make the flat. This is pretty easy to do and since it requires cutting the supplied music wire struts you will have spare material to make another one if its wrong.
Hide Signatures
(in reply to ALWAYSPDG)
       Post #: 1793
RE: NEW H9 P51 Mustang 60 ARF - 11/27/2012 4:10 AM
bboytab
Score: 100
Status: offline
quote:
ORIGINAL: Chris Nicastro
I will definitely try shimming the retract this time, I have maximum toe out with the stock strut flat spot, will also need to file to get more toe out. Thanks Chris!
Hide Signatures
       Post #: 1794
RE: NEW H9 P51 Mustang 60 ARF - 11/27/2012 8:33 AM
kiwibob72
Score: 110
Status: offline
quote:
ORIGINAL: bboytab
Finally, maiden flight last week was good. Half a gallon now to the new DLE20. On the ground, plane noses over easily and on take off run. It was a lot better after moving the battery behind the servos. I still have to hold up-elevator while taxiing and for the 1st part of the take off, slowly releasing once airborne. Once in the air, it flys really good, i just keep the speed up to avoid any chance of stalling, landing was also a bit challenging, have to apply up-elevator on touch down.
Nice to hear that it flys really well (when flown with the speed up).
How did you go with throttle cable positioning and what route did you take? .... are you able to post pics of the direction you took? (was considering a pivot arm myself, but can't see on on yours)
Raptor 50 Nitro heli - OS50 Hyper
56" Yak54 w/ ASP.61 2 stroke, H9 P51 blue nose in progress (with DLE20)
Hide Signatures
       Post #: 1795
RE: NEW H9 P51 Mustang 60 ARF - 11/27/2012 4:11 PM
bboytab
Score: 100
Status: offline
quote:
ORIGINAL: kiwibob72
quote:
ORIGINAL: bboytab
I just have the setup in the manual, just needed to cut the plastic clevis shorter so I will achieve full throttle/travel by not hitting the firewall.
Hide Signatures
(in reply to kiwibob72)
       Post #: 1796
RE: NEW H9 P51 Mustang 60 ARF - 11/27/2012 10:18 PM
Johnysza
Score: 100
Status: offline
I seen your throttle setup.get a TBM troybuiltmodels carburetor throttle arm for dle-20 its a great buletproof gadget
you need to cut off the length of the arm some to fit it perfect
the chep chinese arm got complitlly came got loose from vibration after 10-15 flights.
quote:
ORIGINAL: bboytab
quote:
ORIGINAL: kiwibob72
quote:
ORIGINAL: bboytab
Click to see fullsize image.
Click for fullsize
Hide Signatures
       Post #: 1797
RE: NEW H9 P51 Mustang 60 ARF - 12/3/2012 1:36 AM
bboytab
Score: 100
Status: offline
Any tips on how to avoid this? http://youtu.be/SIXEEpc7OHw
My blue nose is only 2 weeks old but has been flying really good except its hard/impossible to make a smooth scale like take since i needed to hold elevator and should release at the right time to prevent nosing over. I almost crashed today during my 1st take off, just like on the video, luckily i was able to save it. I think i needed more power/speed during take off and release a bit of elevator at the right time. There was also a bit of crosswind today.
Hide Signatures
       Post #: 1798
RE: NEW H9 P51 Mustang 60 ARF - 12/3/2012 6:10 AM
Johnysza
Score: 100
Status: offline
Need more speed on take off
the plane should lift up its own.
Go to the far end of that field so you won't run out of runway.
also on that video the engine sound like a small nitro
bedt setup Dle-20 jtec raparound muffler
a light 16x8 prop.(powerhouse)
unless saito 125 (more unforgiving you add more weight to the plane
good luck!
Hide Signatures
       Post #: 1799
RE: NEW H9 P51 Mustang 60 ARF - 12/3/2012 6:15 AM
Johnysza
Score: 100
Status: offline
also recomend to add clips or steal wire on your fuel line ends ,sumertime the get loose also replace not just the throtle arm also the cheap h9 plastic horn to a dubro ball link conector
Hide Signatures
       Post #: 1800
Jump to:
Google
SITE MAP!   : :   FORUM RULES
2.484RCU1
