RE: NEW H9 P51 Mustang 60 ARF    Gallery
Logged in as Guest
    Search This Thread
Printable Version
AZ Model Aircrafters 1/4 Scale Albatross D.V - RTF
Seller:  Dumb Thumb
Details:   $2,500.00   |  5/16/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> RC Warbirds and Warplanes >> RE: NEW H9 P51 Mustang 60 ARF
Page: <<   < prev  64 65 66 67 68 [69] 70 71 72 73   next >   >>
Login
RE: NEW H9 P51 Mustang 60 ARF - 3/15/2012 3:45 AM
BreakingPoint
Score: 105
Last Login: 4/7/2013
Status: offline
I recommend using the ones it recommends. I had two different brands of nice retract servos and neither one fit due to the very small area. I ended up buying the RT88's and they fit perfectly. Some other servos might fit, but not sure. The RT88 servos seem to have plenty of power in my plane on 6 volts.
Hide Signatures
(in reply to chaos2984)
       Post #: 1701
RE: NEW H9 P51 Mustang 60 ARF - 3/15/2012 3:46 AM
BreakingPoint
Score: 105
Status: offline
Hide Signatures
       Post #: 1702
RE: NEW H9 P51 Mustang 60 ARF - 3/15/2012 1:41 PM
chaos2984
Score: 100
Last Login: 2/26/2013
Status: offline
the spektrum ones im looking at have about the same dimensions for length and width.  The only difference is height.  Im wondering if they will fit.  they are .10in higher.  The only reason i ask is that they have 246oz/in of tq
Hide Signatures
       Post #: 1703
RE: NEW H9 P51 Mustang 60 ARF - 3/15/2012 2:17 PM
BreakingPoint
Score: 105
Status: offline
One of the ones I tried was the JR791 and although it was nearly the same size as the RT88, the height was off just a little and wouldn't fit. There is almost no room for the servo to be off in there. I think those Rt88's must have been specifically designed for these retracts.
Hide Signatures
       Post #: 1704
RE: NEW H9 P51 Mustang 60 ARF - 3/16/2012 3:02 AM
chaos2984
Score: 100
Status: offline
yea ill just stick with the rt88's   what servos are you all using for the plane  how much tq?
Hide Signatures
(in reply to BreakingPoint)
       Post #: 1705
RE: NEW H9 P51 Mustang 60 ARF - 3/16/2012 3:42 AM
tclaridge
Score: 100
Last Login: 5/22/2013
Status: offline
Standard digitals will work everywhere (70 to 80 in-oz torque) except the retracts. I used Hitec low profile for the retracts at 6V, and it was barely enough. I recommend sticking with the rt88s.
_____________________________
AMA 896196
Hide Signatures
       Post #: 1706
RE: NEW H9 P51 Mustang 60 ARF - 3/16/2012 4:04 AM
hook124
Score: 100
Last Login: 5/25/2013
Status: offline
quote:
ORIGINAL: chaos2984
Spektrum; "The A7000 features adjustable travel which makes installation easy and hassle free, no more difficult adjustments with retract linkages to get the proper throw needed to go lock to lock. The A7000’s incredible 260 oz-in of torque can rotate up to nearly 180 degrees. When paired with the DX8 or other transmitters with a servo speed function, the travel speed of the A7000 can be slowed to actuate the gear at slower speeds for a scale look."
This is the servo I'm using on my mustang and they work great. Only a minor issue, when using the rubber grommets with the servo the end that mounts up to the outboard side of the wing was tight, length wise. Height and width no problems.
Gregory
Hide Signatures
       Post #: 1707
RE: NEW H9 P51 Mustang 60 ARF - 3/17/2012 2:57 AM
chaos2984
Score: 100
Status: offline
ok i ordered the spectrum retracts. I should have enough in by next wednesday to start the build.  Stupid thing is that i have to work late that wednesday so i can't start till thrusday  lame.  lol
Hide Signatures
(in reply to hook124)
       Post #: 1708
RE: NEW H9 P51 Mustang 60 ARF - 3/19/2012 3:25 AM
tclaridge
Score: 100
Status: offline
The Spektrum A7000 looks great. Wished I had used them.
AMA 896196
Hide Signatures
       Post #: 1709
RE: NEW H9 P51 Mustang 60 ARF - 3/22/2012 10:29 AM
kiwibob72
Score: 110
Status: online
As per the quote from specktrums website "The A7000 features adjustable travel which makes installation easy and hassle free" ...... setting up these factory retracts is an utter walk in the park, I have never built a plane before (helis yes, planes no), and it was nothing but totally simple to do (just ensure that the servo arm is inline and the rest is easy), so there is no need for adjustable retract servos, just ones that FIT!
Raptor 50 Nitro heli - OS50 Hyper
56" Yak54 w/ ASP.61 2 stroke, H9 P51 blue nose in progress (with DLE20)
Hide Signatures
(in reply to tclaridge)
       Post #: 1710
RE: NEW H9 P51 Mustang 60 ARF - 3/26/2012 3:25 AM
chaos2984
Score: 100
Status: offline
 i used the spektrum a7000 for retracts and they work awesome.  I would deff recomend these over the rt88's
Hide Signatures
(in reply to kiwibob72)
       Post #: 1711
RE: NEW H9 P51 Mustang 60 ARF - 4/9/2012 2:39 PM
R/C Foolish
Score: 105
Last Login: 5/4/2013
Status: offline
I haven't read the entire thread but was wondering if anybody put a DL-20 in this plane?
R/C Foolish
Hide Signatures
       Post #: 1712
RE: NEW H9 P51 Mustang 60 ARF - 4/9/2012 6:10 PM
chaos2984
Score: 100
Status: offline
are you talking about the dle-20cc gas enigne if so yes alot of people have used them.  Im building one right now.  Not quite finished but almost there.  Engine fits fine
Hide Signatures
(in reply to R/C Foolish)
       Post #: 1713
RE: NEW H9 P51 Mustang 60 ARF - 4/11/2012 10:11 AM
R/C Foolish
Score: 105
Status: offline
Anybody know of a lhs that has one and can ship to me?
R/C Foolish
Hide Signatures
       Post #: 1714
RE: NEW H9 P51 Mustang 60 ARF - 4/11/2012 4:06 PM
chaos2984
Score: 100
Status: offline
i got mine from amainhobbies and they had 25 box off and free shipping
Hide Signatures
       Post #: 1715
RE: NEW H9 P51 Mustang 60 ARF - 4/13/2012 12:30 AM
hook124
Score: 100
Status: offline
Getting closer, thanks to Callie @ Callie Graphics great work yet again!
Saito 125
DS 821(s)
Spektrum a7000(s) retracks
Onboard glow
Keleo Exhaust
10 lbs
any guesses on which bird? and thanks to all for the great information here!
Hide Signatures
       Post #: 1716
RE: NEW H9 P51 Mustang 60 ARF - 4/13/2012 3:03 AM
Chad Veich
Score: 265
Status: offline
quote:
ORIGINAL: hook124
...any guesses on which bird? and thanks to all for the great information here!
Karl Dittmer's "Dopey Okie" I would guess. Nice choice.
Hide Signatures
       Post #: 1717
RE: NEW H9 P51 Mustang 60 ARF - 4/13/2012 5:03 AM
hook124
Score: 100
Status: offline
yes sir
Hide Signatures
(in reply to Chad Veich)
       Post #: 1718
RE: NEW H9 P51 Mustang 60 ARF - 4/13/2012 4:20 PM
jet22b
Score: 110
Status: offline
hook123 & Chad Veich;
Looking at the picture of Karl Dittmer's Dopey Okie, to me it look like Hangar 9 model their plane like this one. Now when they come back in-stock, I will pickup another one. Now if someone would bring out a "A" model P-51, that would be sweet!!
Sonny
aka
jet22b
Spitfire Brotherhood #12
P-40 Brotherhood #52
Hide Signatures
       Post #: 1719
RE: NEW H9 P51 Mustang 60 ARF - 4/13/2012 7:09 PM
chaos2984
Score: 100
Status: offline
looks very nice.  Im close on mine as well. i have the engine all tuned in and all electronics all set up for the most part.  All i have left is order a pitts muffler and fit the cowl and she's ready to fly.  Im gonna do some taxing testing before i fly it and see how it acts on the ground before i fly it so i know what its going to do or not do on the ground.
I added support to the tail wheel but i still do not like the factory wheel.  what kind are you guys going with 2 in durbro rubber or something along those lines ?
Hide Signatures
(in reply to jet22b)
       Post #: 1720
RE: NEW H9 P51 Mustang 60 ARF - 4/13/2012 10:59 PM
hook124
Score: 100
Status: offline
Jet22b,
H9 did the scheme after Maj. Preddy's Cripes a mighty 3rd. However, if you look into Cripes, she didn't have full Normandy Invasion Stripes. She had only the black stripes under the side star and bar. The same with Dittmer's Doppey Okie, as I go along I plan to cover the white parts under my side stars with aluminum paint and re-add panel lines.
Chaos2984,
I will do the taxi test as well, and I agree that stock tail setup has left me thinking.....For now I will go with it. I have followed all the great advice here; beefed up all the wood in the lander gear spots, CG is at 4.5", actually a little further forward of that mark and so on. And if the weather holds off tomorrow she will be taxi tested, and maybe flown! I will have access to Herington, KS' airport all to the rc types all day!
Gregory
edit;
Jet22b I agree an "A" would be closer to the prototype which would allow for a 3 blade set up, I agree, H9 "A?"
Hide Signatures
       Post #: 1721
RE: NEW H9 P51 Mustang 60 ARF - 4/14/2012 3:55 AM
jet22b
Score: 110
Status: offline
hook123,
Back in tghe 70's Top Flite had a model "A" P-51 kit. I wanted to buy and build one so bad, but at that time my building skill was not up to that level yet.
Sonny
aka
jet22b
Hide Signatures
       Post #: 1722
RE: NEW H9 P51 Mustang 60 ARF - 4/14/2012 3:56 AM
Chad Veich
Score: 265
Status: offline
quote:
ORIGINAL: hook124
You may already be aware but, at one point in time, all of these aircraft carried full invasion stripes. There may not be any photographic record of it but the stripes were put all the way around to begin with and then were removed at some point after the invasion. Often, as with these two Mustangs, the stripes were removed from just the top sides first to make them less conspicuous from above. As time permitted they were eventually removed completely in most cases. Just FYI in case anybody was wondering.
< Message edited by Chad Veich -- 4/14/2012 8:03 AM >
Hide Signatures
       Post #: 1723
RE: NEW H9 P51 Mustang 60 ARF - 4/14/2012 4:05 AM
CH Ignitions
Score: 420
Last Login: 5/6/2013
Status: offline
Hi Chad,
How hard will be....based on your P51D design to change it and make  a B model ?
Just a thought. I can furnish you the material for p51B.
Adrian
www.ch-ignitions.com
Hide Signatures
       Post #: 1724
RE: NEW H9 P51 Mustang 60 ARF - 4/14/2012 12:39 PM
chaos2984
Score: 100
Status: offline
yea i beefed up the rear tail mount.  I put a piece of plywood down and mounted a tail wheel bracket for a .60 size plane and just had to drill the hole a little bigger.  That seems to help some but still looks a little weak.  I will have to see on the taxi test.  It was just so bad factory it wanted to fold over.  Atleast this way it doesn't want to fold over as bad.  But we will see today
Hide Signatures
(in reply to CH Ignitions)
       Post #: 1725
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.172RCU1
