RE: RE:    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> Twin & Multi Engine RC Aircraft >> RE: RE:
Page: <<   < prev  35 36 [37] 38 39 40 41 42 43 44   next >   >>
Login
RE: RE: - 1/30/2012 1:52 AM
Warbirdguy
Score: 145
Last Login: 5/17/2013
Status: offline
I use popular wood. I get it from Lowe's here locally. Its in the wood section in the back. Wood for cabinet and furniture making. I get the 1/2 x 1 and rip it to what I need. I find it straight, lightweight, and is clean with no knots. Been using it for years and have no issues with it Its fairly cheap too.
Just my two cents and doesnt mean its the gospel.
WBG
_____________________________
Spitfire Brotherhood member #23
Hide Signatures
(in reply to Thisstrangeengine)
       Post #: 901
RE: RE: - 1/30/2012 2:05 AM
Bill Diedrich
Score: 123
Last Login: 5/25/2013
Status: offline
For the wing tube material I would go with the 1/2" aluminum with the phenolic sleeves as it will
fit a lot better than the tube supplied in the old kits, an up grade I will be doing.
The spar material in my "AA" kit looks to be cut from pine, but I will be changing it
out for either spruce or basswood, don't like the grain of pine, it is also heavier than
the spruce or basswood. Laminating balsa with carbon strips is a great way to get
maximum strength with minimum weight, ala control-line model type of spar construction.
Like Warbirdguy I have also used poplar,when you can find it straight grained it is very useful
in model building.
Bill D.
Founder "Nosen Cessna 310 Club"
Waco Brotherhood #43
Hide Signatures
       Post #: 902
RE: RE: - 1/30/2012 2:29 AM
Warbirdguy
Score: 145
Status: offline
Thats definately a need to do upgrade on the wing plug in. The old way was way too sloppy and heavy. Ive gotten tubes from TnT. I think on my next one, Im just using 1 tube and two alignment pins. I think that will be heavy enough to handle it
Thanks again for the file Bill.
WBG
Hide Signatures
(in reply to Bill Diedrich)
       Post #: 903
RE: RE: - 1/30/2012 11:16 AM
Bill Diedrich
Score: 123
Status: offline
quote:
ORIGINAL: Warbirdguy
WBG
I agree on the old tubes, very sloppy and heavy, my plans are to use a single tube up near the main wing spar
and a smaller tube which would extend two wing ribs each side of the outer wing panel seperation line. Also
seriously considering carbon fiber tubes also.
< Message edited by Bill Diedrich -- 1/30/2012 10:15 PM >
Hide Signatures
(in reply to Warbirdguy)
       Post #: 904
RE: RE: - 1/30/2012 5:26 PM
Thisstrangeengine
Score: 100
Last Login: 12/26/2012
Status: offline
I think I am going to use spruce spars since I have plenty of them and I will use the balsa for another project.
Thank You for the replies.
< Message edited by Thisstrangeengine -- 1/31/2012 11:16 AM >
Nosen Cessna 310 Club Member #54
Hide Signatures
       Post #: 905
RE: RE: - 1/31/2012 12:22 AM
Clavin01
Score: 100
Last Login: 5/19/2013
Status: offline
Hello All
Don't want to jump the Gun. But I just came across a deal for a BN 310 with 2 gas motors on it.
I am supposed to pick it up this coming weekend. I know it will need some TLC
But I am excited about it. Once I get it Then I hope to become a member of the Club.
Will Post an update when I get it.
Nosen Cessna 310 Club #56
Hide Signatures
       Post #: 906
RE: RE: - 1/31/2012 11:15 AM
Bill Diedrich
Score: 123
Status: offline
quote:
ORIGINAL: Clavin01
Hello All
Way to go, jump on in, need a set of plans send me an e-mail, glad to help any way I can.
Bill D.
Hide Signatures
(in reply to Clavin01)
       Post #: 907
RE: RE: - 1/31/2012 11:22 AM
Thisstrangeengine
Score: 100
Status: offline
I think I am going to use a pair of FS 1.20s on this. I really don't plan on retracts and such and I will just use Monokote to cover, but I wonder if it will be overpowered with the 1.20s?
Thought about a pair of FS 91s and worried about UNDERpowering it. OH boy! Decisions, decisions...
Hide Signatures
       Post #: 908
RE: RE: - 1/31/2012 11:39 AM
handyman_alw_
Score: 100
Last Login: 2/5/2013
Status: offline
Rob,
I'am flying one of mine on the 120's. they are not over powering but do have enough power to pull mine with retracts & brakes so if you can save some weight you will be fine. when i got it it had 3 blade props on it and it was marginal at best but switched to the 2 blade and have been fine since. this one is monocoated as well so agian i think you will be fine with that choice.
Allen
Nosen 310 Club #5
You Don''t have to be rich to fly a 310 but it sure helps,and one is never enough.
Hide Signatures
       Post #: 909
RE: - 1/31/2012 1:05 PM
thisoldman
Score: 100
Last Login: 2/8/2013
Status: offline
any one have pictures of nose retract on G & L glass fuselage. Im still trying to get mine lined up . been off it so long forgot where i was at.
al
al ryan
Hide Signatures
(in reply to handyman_alw_)
       Post #: 910
RE: RE: - 1/31/2012 2:10 PM
Thisstrangeengine
Score: 100
Status: offline
quote:
ORIGINAL: handyman_alw_
Rob,
Allen
Thank You Handyman, I would rather be safe than sorry...
Hide Signatures
       Post #: 911
RE: RE: - 1/31/2012 10:51 PM
DelRay
Score: 100
Last Login: 2/24/2013
Status: offline
I'm using two Saito 1.20 four strokes on mine, Graupner three blade props, plenty of power to cruise at half throttle , with reserve power left. My 310 weighs right at 38 pounds, retracts, brakes, glassed and painted.
AMA # 173709 Have traveled to the East
I.M.A.A. # 4971 Nosen 310 club # 6
Hide Signatures
       Post #: 912
RE: RE: - 2/1/2012 12:15 AM
AmishWarlord
Score: 121
Last Login: 5/23/2013
Status: offline
I'm still leaning towards Super Tigre 2300's at the moment. I need to get a hold of one and see how well it performs.
I love my Tigre's i just wish they had one between the G-90 and the G2300. .90 to 1.40 is a big jump.
May have to go with OS 108's if the G2300 puts out to much power for the 310.
Hopeing to get 19 pounds static thurst with a 3-blade prop out of the G2300.
Hide Signatures
(in reply to DelRay)
       Post #: 913
RE: RE: - 2/1/2012 3:55 AM
Bill Diedrich
Score: 123
Status: offline
quote:
ORIGINAL: AmishWarlord
Super Tiger 2300's would be a kick in the you know what on the 310, I have one in a quarter scale
Cermark Pitts S2-B and it hauls the mail effortlessly 16/8 3-blade prop on FAI fuel, exhausting through
a Bisson Pitts muffler but it is a little on the thirsty side, cruise around most of the time @ 1/2 throttle.
Hide Signatures
(in reply to AmishWarlord)
       Post #: 914
RE: RE: - 2/1/2012 2:41 PM
Thisstrangeengine
Score: 100
Status: offline
I will go with the 1.20s. I saw a video of a 310 on youtube that has .91s and it flew at 29 lbs but it looked a bit sluggish. I also want to be able to bring her home in the event one engine decides to poop out and I think the 1.20 would be able to do that. The .91 would have a problem.
Anyway I started cutting! Got all of the 1/4" ply pieces done and next I'll do the bulkheads which are 1/8" ply. I hate it when I start gaining momentum and have to stop for work or sleep or meals or potty breaks or paying bills or.... Well you get the idea... I could spend HOURS in the hole just working my tail off.
Time for bed now, work tonight.....
Hide Signatures
       Post #: 915
RE: RE: - 2/2/2012 2:15 AM
FILE IFR
Score: 120
Last Login: 3/31/2013
Status: offline
I have two OS .91s in mine... not sluggish at all IMHO. It cruises nicely at 1/2 to 5/8 power and one engine will certaily extend the shallow decent.... not a problem with the .91
... It's all about the optimun prop selection/pitch as well.
But, the pair of 1.20s would be just a little nicer.
Mike * Intercepting The Localizer* AMA# 365566
Bud Nosen C-310 Club #32 * J.P.O. Member 2302
Hide Signatures
       Post #: 916
RE: - 2/2/2012 3:48 AM
thisoldman
Score: 100
Status: offline
just remeber if you are on the front or back side of ils.
i have two 26cc gas engines im going to try on mine when i get it finished. will see how that goes.
al ryan
Hide Signatures
(in reply to FILE IFR )
       Post #: 917
RE: RE: - 2/2/2012 4:42 AM
Warbirdguy
Score: 145
Status: offline
It was originally designed to fly with two .60 size engines. Two .91s I think would be flyable. One engine out and the other should have enough power to fly it all the way to the scene of the crash LOL
1.20's should be plenty of power.
WBG
Hide Signatures
       Post #: 918
RE: RE: - 2/2/2012 9:08 AM
AmishWarlord
Score: 121
Status: offline
Hey I could fly it on .40's
If I where to make an all balsa, skeletonized open stick structure like an Sig Senior, clear Mica film covering, fixed wire gear, and mini servos.
Click to see fullsize image.
Click for fullsize
Hide Signatures
       Post #: 919
RE: RE: - 2/2/2012 2:20 PM
Thisstrangeengine
Score: 100
Status: offline
Ok, so who's got some pictures or videos to post? I wanna see some more 310's in the air or at least some still shots. I promise you that when I finish this one there will be pics and videos of it.
Hide Signatures
       Post #: 920
RE: RE: - 2/2/2012 2:52 PM
AmishWarlord
Score: 121
Status: offline
Did you see the one props4ever did? Wow!
Hide Signatures
       Post #: 921
RE: RE: - 2/2/2012 3:05 PM
DelRay
Score: 100
Status: offline
Here's a few of mine taken at Ames Ia. Multi- Meet two years ago.
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 922
RE: RE: - 2/2/2012 4:01 PM
handyman_alw_
Score: 100
Status: offline
Del Ray,
That can't be yours it looks to nice.
Allen
Nosen 310 Club #5
Hide Signatures
       Post #: 923
RE: RE: - 2/2/2012 9:01 PM
DelRay
Score: 100
Status: offline
Al, you're such a meanie, I don't know why I even talk to you.[>:] Yup, it's mine, Starla did a good job with the pics. I was hoping to get the strobe lights flashing in one of the pics that day, never did, they do look cool though.
What I should do is take some pics of that other one and post them, that'd make mine look like a real beauty. LOL I'd have to say it was one of your better ones and I bought it from you. LOL GOTCHA !!!!
Hide Signatures
       Post #: 924
RE: RE: - 2/2/2012 10:31 PM
Thisstrangeengine
Score: 100
Status: offline
Nice Delray!!! Thanks. Now guys,THATS the kind of motivation I need. It's not like Im excited enough to have this project in the beginning stages, but...well...
Got home from work this morning and rough cut all the ply formers for the fuselage. Next up will be all the ply wing parts then ribs. It's starting to look like I have a kit sitting here. Feel like a kid in a candy store.
Hide Signatures
       Post #: 925
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.734RCU1
