RE: RE:    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> Twin & Multi Engine RC Aircraft >> RE: RE:
Page: <<   < prev  41 42 [43] 44 45 46 47 48 49 50   next >   >>
Login
RE: RE: - 3/1/2012 9:20 AM
AmishWarlord
Score: 121
Last Login: 6/14/2013
Status: offline
Sounds good but the Gremlins will get into your plans and redraw the parts differently again.
You'll be like, "Damn it! I traced these parts from the parts that I used! Why are they the wrong size now"?
Hide Signatures
(in reply to Thisstrangeengine)
       Post #: 1051
RE: RE: - 3/1/2012 11:58 AM
bps
Score: 100
Last Login: 6/7/2013
Status: offline
I can feel your pain on the parts fit issue. I am digitizing the files for laser cutting and it is a huge task as many steps are involved. First draw the part and then compare it to the plans sheets, then make adjustments until the fit looks perfect. Once I am happy with that then print the part out full size and compare to the plans, more adjustments and check for fit once again. After all that the part can be cataloged for the parts sheet. Last step is to redraw the part allowing for the laser kerf. So I wind up with two files, one the on size drawing file and one the laser cut file. Last step is to cut the part and build from that, meaning more adjustments might be needed.
On the issue of the wing ribs. I caught that early on that the sizes on the parts sheets just did not match. The major area of concern for me is the placement of the spars and the way they line up. Choose either the vertical alignment or with the airfoil. This means that either the top of the spar will need to be sanded or the vertical alignment will be off meaning that any sheer webbing will not be in full contact with the vertical faces of the spars.
I really wish I could get my hands on a Nosen kit to have something to compare to. Just missed on Ebay a while ago. Perfect time to do this while I recover from a hip replacement.
Keep the pictures coming builders, this is inspiring to say the least!
_____________________________
JEB
Giant Scale P-47, Knight Twister, 33% BD-8, 40% Gee Bee Z, 25% Dr1, 25% Clip Wing Cub, #45 Bud Nosen 310 Club
Hide Signatures
       Post #: 1052
RE: RE: - 3/1/2012 1:32 PM
Thisstrangeengine
Score: 100
Last Login: 12/26/2012
Status: offline
I found out about the spars as well after my dry fitting. I'm using spruce spars and I was thinking about adding some thin balsa stock to the top of the spars to bring them up to level with the ribs and then sanding the excess off to the rib shape. I want full contact with the sheeting because I'm anal like that! Definately doing shear webs throughout the wing even if it's overkill. Small amount of weight gain but adds lots of strength! I'll probably start building the wing tomorrow after fitting the ply rib doublers. I just want to see some progress for all the work I've done up until now...
Nosen Cessna 310 Club Member #54
Hide Signatures
(in reply to bps)
       Post #: 1053
RE: RE: - 3/2/2012 6:51 PM
Thisstrangeengine
Score: 100
Status: offline
Well here is what I got done today. I have all the parts fitting where they should and installed the wing tube sockets to check the alignment. Everything looks good so I'll glue it up tonight. Just thought I would include a photo of the progress.
Hide Signatures
       Post #: 1054
RE: - 3/2/2012 8:16 PM
bps
Score: 100
Status: offline
Look'n good!
JEB
Hide Signatures
       Post #: 1055
RE: RE: - 3/3/2012 1:39 AM
Thisstrangeengine
Score: 100
Status: offline
Thanks, that top spar looks warped, but it's just sitting there for alignment purposes as is the short one in the rear. I eyeball the panel from both sides and back to front before I glue anything. I have to cut the sockets to length also, those are just slid in place. Still have to decide where I'm gonna run the servo wires and cut holes for that. I have some long drill bits for that so that'll be easy.
Another hurdle in my progress...I broke my bandsaw blade, so now I have to get another tomorrow. Luckily Sears is only 5 or so miles from me. I have a few other blades but the one I broke is my wider fine-tooth blade which gives me straighter cuts. Oh geez.
Hide Signatures
(in reply to bps)
       Post #: 1056
RE: RE: - 3/3/2012 11:30 AM
Clavin01
Score: 100
Last Login: 6/15/2013
Status: offline
Looking Good Thisstrangeengine
Keep the updates coming. with Pictures of course.
Nosen Cessna 310 Club #56
Hide Signatures
       Post #: 1057
RE: RE: - 3/3/2012 2:19 PM
mistermnkim
Score: 100
Last Login: 5/24/2013
Status: offline
I got the beautiful box my friend!!! Thanks!!
club saito #625 CG Ultimate brotherhood #19 SPITFIRE brotherhood #91
Hide Signatures
(in reply to dwhorn)
       Post #: 1058
RE: RE: - 3/4/2012 1:54 PM
Thisstrangeengine
Score: 100
Status: offline
Good Morning Everyone,
Just a quick update: I got the right center panel all glued up minus the sheeting, landing gear blocks and wing tube sockets.( leaving sockets loose until I finish the outer panels)
I started fitting the left panel together, cutting the notches for the spars and other parts in the ply rib doublers and have 3 of them glued and drying at this moment. Two more to go then I'll start glueing the left panel together. The reason I am doing the wing first rather than the fuselage is because of the fit to the wing saddle. The ribs from the pattern sheet I cut just dont fit the wing saddle on the fuse drawing, so when the wing is sheeted, I can custom cut the wind saddle (and nacelle sides which are also wrong) and fit them to the fuselage drawing and put everything in else in place.
I will upload more pictures when I have both center panels dry fit together with the dihedral braces in place. Once I'm happy with the joint I am going to add the shear webs to the front and rear spars. then go from there.
Thinking ahead of myself a bit, I might also be adding shear webs to the horizontal stabilizer just for added strength.
Hide Signatures
(in reply to mistermnkim)
       Post #: 1059
RE: - 3/4/2012 6:23 PM
bps
Score: 100
Status: offline
Yes parts fit is an issue with the parts page. I have almost all of the wing ribs redrawn and have them checked against the fuse side view. Thats the bonus in using digital drawing tools. Once I have this finished then then I will be most happy to share them. Please keep the pics coming your doing a great job! I am looking forward to starting mine.
Can you tell me how many balsa sheets are needed for the wing ribs?
JEB
Hide Signatures
       Post #: 1060
RE: - 3/5/2012 5:02 AM
Thisstrangeengine
Score: 100
Status: offline
I got three of the larger ribs from one 3x36 inch sheet. I didnt count the rest but I know I laid them out to minimize my waste.
Hide Signatures
(in reply to bps)
       Post #: 1061
RE: RE: - 3/5/2012 11:11 AM
bps
Score: 100
Status: offline
Thanks. I am just about finished with the digital drawing of the ribs, so a sheet layout it on the horizon.
Here is a full size pdf of rib W1. I have aligned the spars so that sheer webs can be glued to both the front spars and rear spars. This means that the tops of the spars will need to be beveled in order to install the wing sheeting. Outer panels will not have sheer webs so those spars can be tilted to get away from having to bevel the tops of the spars for full sheeting contact.
Click to see the file in new window.Attachment.pdf
< Message edited by bps -- 3/5/2012 5:54 PM >
JEB
Hide Signatures
       Post #: 1062
RE: RE: - 3/5/2012 10:37 PM
Thisstrangeengine
Score: 100
Status: offline
SWEET!!!
I glued the rest of the ply doublers to the ribs this morning after work, so the left wing panel is ready for glueing together. Once that's finished, I will upload some more pictures.
Hide Signatures
(in reply to bps)
       Post #: 1063
RE: RE: - 3/6/2012 5:43 AM
Warbirdguy
Score: 145
Status: offline
bps,
What airfoil did that come out to be?
WBG
Spitfire Brotherhood member #23
Hide Signatures
(in reply to bps)
       Post #: 1064
RE: RE: - 3/6/2012 6:19 AM
Clavin01
Score: 100
Status: offline
Hello All
I was wondering, Does anyone out there is Nosen Land have a set of cowls
They do not intend to use? My 310 is close and I can use my cowls for now
But would like to get a new set as the one's I have are cut up pretty good
by haveing multiple size motors mounted. Let Me know.
Thanks Cliff
Hide Signatures
(in reply to Warbirdguy)
       Post #: 1065
RE: RE: - 3/6/2012 7:12 AM
AmishWarlord
Score: 121
Status: offline
quote:
ORIGINAL: Warbirdguy
bps,
WBG
Yeah what airfiol is one this thing? NACA 2412?
Any one switch to a diffrent one like a Clark-YH, or a NACA-2013?
Hide Signatures
       Post #: 1066
RE: RE: - 3/6/2012 11:04 AM
bps
Score: 100
Status: offline
bps,
WBG
I have no idea what airfoil Bud Nosen used on this plane. This rib is just drawn to best reflect the plans side view, and the rest of the ribs to match the parts sheet. All of the notches in the ribs are now sized correctly and the entire rib profile cleaned up a bit. Still finishing up on this part.
JEB
Hide Signatures
       Post #: 1067
RE: RE: - 3/6/2012 11:25 AM
Bill Diedrich
Score: 123
Last Login: 6/18/2013
Status: offline
quote:
ORIGINAL: Clavin01
Hello All
Thanks Cliff
Give Greg @ G & L Hobbies a call he should be able to ship you a set out fairly quickly
931 528-9312. or you might call Fiberglass Specialties, 479 359-2429, they both have
cowls for the Nosen Cessna 310 available.
http://www.fiberglassspecialtiesinc.com/catalog.htm
http://www.glhobbies.com/acessories/accessories.html
Greg shows a set with the nacelles and tips but I'm fairly sure he will sell just the cowls.........
Bill D.
Founder "Nosen Cessna 310 Club"
Waco Brotherhood #43
Hide Signatures
(in reply to Clavin01)
       Post #: 1068
RE: RE: - 3/7/2012 2:15 AM
Warbirdguy
Score: 145
Status: offline
I have done some research and this is what I came up with. The Cessna 310 used a NACA 23018 for the root and a NACA 23015 for the tip. Here is what the root would look like, profile wise. You be the judge on how close it is
Click to see fullsize image.
Click for fullsize
Hide Signatures
(in reply to bps)
       Post #: 1069
RE: RE: - 3/7/2012 7:16 AM
AmishWarlord
Score: 121
Status: offline
LOL thats funny. I just used the NACA 23018 on the plane I'm building now.
Click for fullsize
Hide Signatures
       Post #: 1070
RE: - 3/7/2012 10:51 AM
bps
Score: 100
Status: offline
Nice work on the research. How much washout if any are you guys planning?
JEB
Hide Signatures
(in reply to AmishWarlord)
       Post #: 1071
RE: RE: - 3/7/2012 1:59 PM
Thisstrangeengine
Score: 100
Status: offline
Washout! What's that? Just kidding... I wasnt planning on any washout myself since there is no mention of it in the instructions. Been thinking about the flaps though and wondering how I might do them. I have to find some pictures of the full scale flaps and try to make them somewhat scale as far as size goes, but I'm thinking of a couple ways of attachment and hinge points. Nothing to share as of yet, but if I come up with something interesting I will post pics. I have one more night at work and then I can get back to work on the left wing panel...
Hide Signatures
(in reply to bps)
       Post #: 1072
RE: RE: - 3/7/2012 2:33 PM
Warbirdguy
Score: 145
Status: offline
On most designs that use a tapered wing, generally speaking, there is no washout. The tapered design is the washout. But, if I was going to put some in reguardless, I would probably do 1 to 2 deg and no more.
About the flap. Im not sure how the full size is. Guess I need to make a trip to the airport lol.
Now, just for fun, can any of you identify this baby? There are hints all over it if you look closely.
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to bps)
       Post #: 1073
RE: - 3/7/2012 2:44 PM
bps
Score: 100
Status: offline
That was my thinking on the washout as well. Thanks for the input.
JEB
Hide Signatures
       Post #: 1074
RE: - 3/7/2012 4:40 PM
bps
Score: 100
Status: offline
What are most folks using for wing tubes and sleeves and where is the best place to purchase? Thanks
JEB
Hide Signatures
(in reply to bps)
       Post #: 1075
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.561RCU1
