Popcyclical
Joined: 5/30/2003 From: Laguna Hills, CA, Status: offline
Hi wildebeast. I'm very familiar with the loss of MR blade performance, with that low-pitched 'Fluttering' sound. I spent a day troubleshooting my HB once, blaming batteries, motors, everything . Then, after glancing over to the HB assy/op manual (PDF doc), here's this picture of how to bend the HB (plastic) blades to increase pitch -- I did that and WHAM! the bird almost hits the ceiling : So, if you can increase the pitch on those MS CF blades, by all means, try it. There's a thread on one of the other forums containing a 3 min Video of Steve from OK flying his HB with the CF Hornet blades outdoors so they work fine once they're set-up. He mentions that he used a tubing type shim in installing those blades. I think the Hornet CF blades' mount holes are reasonably smaller than the HB's Rotor Hub's blade interface features. You might be losing some needed blade pitch in your installation. 'Don't know, but rather doubt that you can bend the CF blades for pitch increase the way you can with the HB plastic blades? I've found I needed to do this every few days to keep the HB lifting-off easily. Surely there's someone on this forum who can jump-in and advise you on the CF blade mod. Good Luck J.R.
