RysiuM
Joined: 4/22/2003 From: Elk Grove, CA, USA Status: offline
[QUOTE]Originally posted by goleith are there any other options besides an expensive camcorder. keep in mind it has to be battery powered since there is no outlet at the park. [/QUOTE] I have bought an old "non-working' VHS camcorder on E-bay for six bucks (pus $5 shipping). These old type VHS camcorders (RCA, Panasonic GE) have RCA input integrated with 120V power supply, which can be easy converted to 12V (just bypass 120V impulse transformer circuit). I didn't care for camera part and I was hoping VCR part is working. Hopefully it turned out that the "non-working" meant "dirty head" It's not a perfect setup, but it works OK and it's cheap. If you have enough space in your car, you can also take you home VCR (they a so inexpensive now) and power it using 12/120V inverter (I have powered my camera that way, before I hack it's power supply to run from 12V). They run OK and don't disturb RF link. RysiuM
