MAXX owners check this out !! : kick a$$ electric figures 50mph+
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Monster Trucks >> Traxxas Monster Truck forum >> MAXX owners check this out !! : kick a$$ electric figures 50mph+
Page: [1] 2   next >   >>
Login
MAXX owners check this out !! : kick a$$ electric figur... - 6/15/2003 7:15:01 PM
Satans_Phoenix
Status: offline
http://66.93.220.59/hiamplidude/speedtests.htm
Brushless twin B50 8S hacker sys...
       Post #: 1
MAXX owners check this out !! : kick a$$ electric figur... - 6/15/2003 9:40:11 PM
Avalanche
Status: offline
Brushless is kick-ass.....Old news..........
Too bad they dont show how expensive those set ups are. Or how you only get about 10-12 minutes run time on a charge, how expensive the matched battery packs are, or how you have to let the motors cool after every other run. I was looking into a brushless Stampede which is much less expensvie than an E-maxx to set up and maintian and decided it was just a dream for me. ( I couldnt see dropping $700+ on a set up that was so finiky and user unfriendly. You can get 50 out of a T-maxx for $300.
(in reply to Satans_Phoenix)
       Post #: 2
MAXX owners check this out !! : kick a$$ electric figur... - 6/15/2003 10:05:46 PM
Satans_Phoenix
Status: offline
" 50 out of a T-maxx for $300. "
And exactly how are you planning to do that ?
phoenix
       Post #: 3
MAXX owners check this out !! : kick a$$ electric figur... - 6/15/2003 10:38:05 PM
Avalanche
Status: offline
Tha maxx does roughly 40mph as is.....
Siro 3.0 engine $199
Clutch bell and spur gear. $40
$199+$40 = $239 Thats all it will take. And you have $61 left over for a pipe and air filter.
       Post #: 4
MAXX owners check this out !! : kick a$$ electric figur... - 6/15/2003 10:44:43 PM
einlanzeR
Status: offline
How many RPMs can the Sirio pull? On this one forum, people were saying they had their 2.5 Maxxes going 45+, and outcast (Traxxas, RCCA, etc. / Guy with dual BL Maxx) explained that 50+ was impossible because of the RPM maximum the motor could pull, and gearing wouldn't make the T-Maxx faster because of the RPM limit, or something. Blah, don't really remember but 50+MPH is harder then dropping in a new motor. outcast BL motors rate to like .40 or .60 in an engine, plus a large cell count.
       Post #: 5
MAXX owners check this out !! : kick a$$ electric figur... - 6/15/2003 10:50:33 PM
Satans_Phoenix
Status: offline
WELL THIS ONE IS AN E-MAXX DOING THOSE BLASING SPEEDS ..which is done with a ntiro that to modfiied ....
I am sure this IS a kick as stuff ! for an E-maxx
       Post #: 6
MAXX owners check this out !! : kick a$$ electric figur... - 6/15/2003 10:52:43 PM
Avalanche
Status: offline
Max RPM of the enigne isnt the deciding factor, its just a variable. You can gear you truck, any truck, for more top end however you would like, thats what the clutch bell and spur gear are for. The Siro has enough power to spin a a 50 mph set up.
       Post #: 7
MAXX owners check this out !! : kick a$$ electric figur... - 6/15/2003 10:59:06 PM
einlanzeR
Status: offline
Some direct quotes of outcast (Talking about the 2.5):
[QUOTE]According to GPS, perfectly tuned its 38mph. They all vary, and some may do 40mph out of the box. 50mph is not possible with a stock T-maxx. You will be hard pressed to pull 50mph with a .21 maxx. Trust me, I have been on the quest for MPH for a while now.[/QUOTE]
[QUOTE]nope, still no dice. We have diferent pipe here, and long straights. RPM is RPM, you can only get so much out of it. It doesnt have the HP to pull the RPM with high gearing. 40mph is insanely fast, I dont think you guys realize that. Buy a GPS and check your actual MPH and you will see what it takes to get 40mph. It took me dual brushless and 16 cells per motor to reach 50mph. It was still no easy task. 31/54 gearing. Each one of my motors is equal to a .60 four stroke. Just think about that for a few.......[/QUOTE]
[QUOTE]engine is tuned right dude. I HAVE tried it, so now is your turn. Trust me, is it could be done traxxas would have 50+ MPH on the box in a heart beat. So, TRY IT. Buy a GPS unit and see what you are actually doing, it will hit you with a dose of reality for sure. I would have never guessed it without running a GPS on my truck. I would be you are I the mid 30s with your truck, the majority of the 2.5 trucks seem to be. Its easy to go from 30mph to 35mph. It gets alot harder and takes alot more HP to get to 40mph. 45mph takes some serious HP and 50 is just insane. If my electric was nitro, it would have the equivilent of TWO .60 engines on it. I am barely hitting 50 and I have 50,000RPM to play with, all the gearing in the world, and plenty of room.[/QUOTE]
       Post #: 8
MAXX owners check this out !! : kick a$$ electric figur... - 6/15/2003 11:13:01 PM
Satans_Phoenix
Status: offline
einlanzeR
whats the RPM like on this ...80,000 or more ..
       Post #: 9
MAXX owners check this out !! : kick a$$ electric figur... - 6/15/2003 11:22:44 PM
Avalanche
Status: offline
[QUOTE]Originally posted by einlanzeR
Some direct quotes of outcast (Talking about the 2.5): [/QUOTE]
Nobody here is talking about a stock Tmaxx.
       Post #: 10
MAXX owners check this out !! : kick a$$ electric figur... - 6/15/2003 11:29:28 PM
Satans_Phoenix
Status: offline
well it all started with an E-MAXX !!!!!!!!!!
       Post #: 11
MAXX owners check this out !! : kick a$$ electric figur... - 6/15/2003 11:55:44 PM
einlanzeR
Status: offline
[QUOTE]Originally posted by Avalanche
Nobody here is talking about a stock Tmaxx. [/QUOTE]Sirio is pretty close to the 2.5. And if a Dual Brushless on 32 Cells can barely hit 50MPH, what makes you think a .18 can?
       Post #: 12
MAXX owners check this out !! : kick a$$ electric figur... - 6/16/2003 12:38:59 AM
Avalanche
Status: offline
Simple physics. Just think about it like this........The Nitro Rustler hits 52 mph with the same stock 2.5 as the maxx. The Siro has almost 1/2 hp more than the 2.5, nowhere near "real close". So your gearing and RPM theory are out the window. I'm not a big Tmaxx fan so I' not interested in talking it up and I'm certianly not interested in changing your mind about something you obviously have no experience with. The point is that brushless is cool but not practical and WAY to expensive. Geared properly a dual brushless set up and go much faster thsan 50
       Post #: 13
MAXX owners check this out !! : kick a$$ electric figur... - 6/16/2003 1:58:46 AM
einlanzeR
Status: offline
Dunno about the other stuff, but do you really believe those HP numbers? It's a joke. All companies use different dynos under different settings/circumstances so how is it possible to compare one engine to another (Brand wise)? It's impossible unless you use the same Dyno for all the engines, but that would never happen.
That's why RB Concepts doesn't release HP numbers.
       Post #: 14
MAXX owners check this out !! : kick a$$ electric figur... - 6/16/2003 2:20:29 AM
Avalanche
Status: offline
