B-26
Tower Hobbies
Logged in as Guest
  Printable Version
Ziroli P-61 Black Widow - Kit
Seller:  topgun600
Details:   $575.00   |  11/6/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> Twin & Multi Engine RC Aircraft >> B-26
Page: [1] 2   next >   >>
Login
B-26 - 6/15/2003 9:55:28 PM
Cessna26
Status: offline
Does anyone know of a kit or any plans to a B-26. Price is not a factor. I would like a kit better because i am an intermediate builder.
_____________________________
T. Buhler
Cessna26
       Post #: 1
B-26 - 6/15/2003 10:17:28 PM
William Robison
Status: offline
Cessna26:
Which B-26?
The "Real" Martin Marauder B-26, or the Douglas A-26 that was also designated B-26 (for a while, then back to A-26)?
And also, how big?
Quuite a few kits and plans for the Douglas A/B-26 in a good variety of sizes, but for the Martin pickings are slim.
Bill.
Real Airplanes have Two Engines
AMA 25139 - More than 40 years.
(in reply to Cessna26)
       Post #: 2
B-26 - 6/15/2003 10:46:49 PM
Cessna26
Status: offline
I do not care what model really but the b-26B (i think the b is for berkley i do not remember) but i was thinking under 100" wingspand.
T. Buhler
Cessna26
       Post #: 3
B-26 - 6/15/2003 10:54:25 PM
TLH101
Status: offline
Jerry Bates has a nice set of plans for a Martin B-26 at about 101"
Terry
"Old Fart" in training. (not to be an R/Cer, but to be an "Old Fart")
       Post #: 4
B-26 - 6/15/2003 11:00:11 PM
Cessna26
Status: offline
I just looked at those plans. Do you know anyone that could cut the balsa and other stuff form me. I do no have any tools to do it or i would do it myself.
T. Buhler
Cessna26
       Post #: 5
Which B-26 - 6/15/2003 11:22:12 PM
William Robison
Status: offline
Cessna26:
The "B" model would still be a Martin, the first "Short wing" version, 65' span. The B-26C was the first 71' airplane.
And if you really don't care which one you might as well get an AeroCommander. They are all high wing planes with wing mounted engines, but otherthan being conventional airplanes they look entirely different.
Picture of the Martin plane attached. I'll try to find a Douglas picture and post that also. You can decide which you want after that.
Bill.
Click to see fullsize image.
Click for fullsize
       Post #: 6
B-26 - 6/15/2003 11:34:10 PM
TLH101
Status: offline
Heres a link to all the info, including kit cutters;
http://www.scaleaero.com/jerrybates.htm
The B-26 is under Group IV.
I have seen two that were built from "Precision Cut Kits", and they are both very nice.
http://www.precisioncutkits.com/
Terry
       Post #: 7
B-26 - 6/15/2003 11:50:19 PM
Cessna26
Status: offline
Bill the Martin was the one i was looking at. Do you know of any plans for that?
T. Buhler
Cessna26
       Post #: 8
Douglas version - 6/16/2003 12:15:43 AM
William Robison
Status: offline
The caption on the picture says A-26A, but before they were sent to Thailand they were the B-26K.
In the early days of the Viet Nam war Thailand didn't want any bombers based there, so the USAF changed the B(omber)-26K to the A(ttack)-26A. If you're a politician it makes sense, to a sane human being it's ridiculous.
Bill.
Click for fullsize
       Post #: 9
B-26 - 6/16/2003 12:44:43 AM
William Robison
Status: offline
Cessna26:
Just checked "Precision Cut Kits," they have these two "In stock,"
quick shipment upon your order:
B-26 MARAUDER J. BATES 106.5" span
B-26 B. MARAUDER PALMER 71" span
These probably are "Short" kits, meaning just the cut wood parts. You will have to supply all the stock wood sheets and blocks, hardware, etc. And the plans also have to be purchased separately.
Usually either the kit cutter or the plans supplier will have fiberglass cowlings, the clear plastic for the canopies, so forth available. And for the popular ones you can count on Robart to have (expensive) retracts for sale.
You would be well advised to make a complete listing of everything you'll need, these things get expensive in a hurry. It's easy to spend $10K before you know it.
And please, figure a twin trainer in your cost. A plane like this is WAY too hard to fly to have it as your first twin. The maiden flight could easily last no more than a few seconds, and end with a multi-thousand dollar pile of trash at the end.
But it's your time and your money, bear in mind the value of free advice. Haw.
Bill.
       Post #: 10
B-26 - 6/16/2003 1:30:51 AM
JohnBuckner
Status: offline
MARTIN
the USAAS designations of the production varients of this aircraft were:
B-26
B-26A
B-26C
B-26F
B-26G
AT-23 Training varient
TB-26 Target tow varient
There was a wide variety of experimental versions including one modified B-26G known as the "Middle River Stump Jumper' with tandem bicycle main gear for a failed Martin project (XB-51). The technology which ended up being used by Boeing for the B-47 and B-52.
DOUGLAS
The USAAF/USAF designations of the production varients of this aircraft are:
A-26B
A-26C
FA-26A
In 1948 with the changeover to the USAF and redesignation, with the martin airplanes no longer in service the still in service A versions became:
B-26B
B-26C
In 1962 a much modified attack version by On Mark engineering
was designated:
A-26A and later a COIN version became the:
B-26K
Like the Martin aircraft there were many one off experimentals and the most interesting here was the XA-26F with a General Electric J-31 turbojet in the fuselage that reached 413 mph with a payload. Wouldn,t this make an interesting scale project.
John
"Keep your controllines tight"
       Post #: 11
B-26 - 6/16/2003 1:33:29 AM
rryman
Status: offline
Here's a pic of the model of the one Bill postsed a picture of. Personally, I'm partial to the B-26K/A-26A version by On Mark. There were only 40 of those made. On Mark Engineeering converted them from original B-26 airframes.
Randy
Click for fullsize
       Post #: 12
B-26 - 6/16/2003 1:49:00 AM
William Robison
Status: offline
Randy:
Pretty airplane.
I also think the Douglas plane is the prettier of the two, so long as it's the "Glass" nose version. The "K" model just looked like a bulldog, and while well suited to the purpose, they're not terribly good looking.
I have a picture of a beautiful Douglas glass nose, I'll try to compress it to the point of being able to post it, then come back and do it.
Bill.
       Post #: 13
B-26 - 6/16/2003 1:53:31 AM
William Robison
Status: offline
JohnBuckner:
I think there were also a very few Martin B-26B models, the last ones with the 65' wing. The Martin "C" had the 71' wing.
And didn't we have a conversation a while back about these planes?
Bill.
       Post #: 14
Glass Nose A/B-26 - 6/16/2003 2:04:22 AM
William Robison
Status: offline
Here's a nice nose on a Douglas.
Bill.
Click for fullsize
