Different plane types
Tower Hobbies
Logged in as Guest
  Printable Version
The Amazing FLAMING DOOFUS Mini Flying Wing RTF!
Seller:  EASYTIGER
Details:   $89.00   |  11/6/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> 3D Flying! >> Different plane types
Page: [1]
Login
Different plane types - 3/25/2002 11:32:49 AM
rvd
Status: offline
Can somebody explain what seperates a 3D,pattern,aerobatic plane into their classes?
Aren't they all really aerobatic? what is the difference between these 3 types of planes?
thank you
       Post #: 1
Different plane types - 3/25/2002 6:40:55 PM
swill
Status: offline
here's my take...
3D - most/all maneuvers are flown below the stall speed of the aircraft, with the engine's thrust keeping the plane up/moving forward. the control surfaces on these types of planes tend to be HUGE. usually, the elevator surface area is very big, with counterbalances. typically use a thicker wing section.
pattern - sleeker, with smaller control surfaces to fly maneuvers precisely...constantly flowing (i.e. not hanging on the prop or doing harriers).
you are starting to see a cross between these two types of planes... and something called "freestyle". I feel my G-Trick is a blend of the two types of planes.
hope that helps,
Scott
Click to see fullsize image.
Click for fullsize
(in reply to rvd)
       Post #: 2
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.328RCU3
