RCAddiction
NC, USA Status: offline
I have one in my H9 T-Craft with BME44. It works fine but I didn't follow the directions and didn't use the very large diameter tygon tubing that it came with. The larger the diameter, the longer and more difficult it is for the pump to prime. The 4.8V pack is not enough for this pump. Sullivan indicated it was marginal. Go to 6.0 or 7.2V. I'm using 6.0 because it was handy. The pump has to work pretty hard against the exhaust backpressure. Use ATV or EPA in your radio to set endpoints as needed. I use (2) TME check valves, because the cracking pressure is lower than the stock Sully valve. First check valve is between tank and pump, on the inlet to the pump. This prevents the pump from losing its prime. 2nd check valve is on the engine side of the firewall, between the outlet of the pump and the muffler. Tygon from pump, thru firewall, to checkvalve, then to 3" stub of neoprene line connected to muffler nipple. On my 9C, I set up a mix curve that ties the smoke channel to the throttle. If I have the smoke switch "ON", then at 1/2 throttle, the smoke pump runs at a low rate. The rate increases until it reaches the maximum desired smoke rate at 3/4 throttle. Works just fine and is a real crowd pleaser. My good friend, who is an awesome pilot, did a tailslide with my T-Craft back down into the cloud of smoke, and hung my T-Craft in the cloud of smoke. Way cool.
_____________________________
Lee
