989 and Lipos    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> Radios, Batteries, Clubhouse and more >> Batteries & Chargers >> MRC Charger Product Support (i.e. Super Brain, etc) >> 989 and Lipos
Page: [1]
Login
989 and Lipos - 4/10/2009 3:39 AM
dai2dai996
Score: 100
Last Login: 11/1/2010
Status: offline
Hello,
I am a little confused on charging lipos with my 989. I start the charge and it only charges for about 10 minutes then switches to trickle. Is this what it is supposed to do? Am I supposed to leave it on trickle until it stops or is it not charging correctly.
Tom
Hide Signatures
       Post #: 1
RE: 989 and Lipos - 4/17/2009 6:57 PM
SV27dayton
Score: 104
Last Login: 1/7/2012
Status: offline
I don't mean to double post or hijack a thread but I realized after posting this on the general page that this was probably the better place to do so. I know I need a balancer or maybe two. I don't know how this works and need an education (another education)
I have this charger:
http://www.modelrec.com/search/product-view.asp?ID=6863 (SB989)
And plan on getting these Lipos.
https://www.hobbycity.com/hobbycity/store/uh_viewItem.asp?idProduct=8578 (5000mah 2S1P, 20C lipos)
I'd plan on charging them 2 at a time. What settings are recommended and what balancer is recomended?
Is there a good general lipo care and feeing mass of information somewhere that I can go soak my head in?
_____________________________
\\\\\ Go fly a boat /////
Hide Signatures
(in reply to dai2dai996)
       Post #: 2
RE: 989 and Lipos - 4/22/2009 10:16 PM
SV27dayton
Score: 104
Status: offline
this thread doesn't have a pulse does it?
Hide Signatures
(in reply to SV27dayton)
       Post #: 3
RE: 989 and Lipos - 4/25/2009 12:41 AM
write2dgray
Score: 101
Last Login: 5/3/2012
Status: offline
MRC doesn't really have a pulse. When was the last time they released anything new? The 989 in '05?
Hide Signatures
       Post #: 4
RE: 989 and Lipos - 4/27/2009 7:01 PM
SV27dayton
Score: 104
Status: offline
So you'd think someone would know how to use it.
Hide Signatures
(in reply to write2dgray)
       Post #: 5
RE: 989 and Lipos - 4/29/2009 9:40 PM
shackwrrr
Score: 100
Last Login: 7/17/2009
Status: offline
What voltage is your lipo showing after it kicks over to trickle? If its around 8.4 volts then the charge is almost done and the charger is tapering off the charge to be nice to the battery
Hide Signatures
       Post #: 6
RE: 989 and Lipos - 8/31/2009 6:22 PM
guver
Score: 174
Last Login: 5/19/2013
Status: offline
quote:
ORIGINAL: SV27dayton
Hi SV27.
You can do them in parallel if they are the same cell count, and should be programmend into memory as a 2sx10000 mah pack. Set capacity to 10,000 , rate to 10 amps, ect. Any balancer should work as they are universal. Make sure to wire/adapt them corectly.
and airplanes were in
Hide Signatures
       Post #: 7
RE: 989 and Lipos - 6/25/2010 10:04 PM
bigedmustafa
Score: 134
Last Login: 5/16/2013
Status: offline
I don't trickle charge my LiPo batteries. Once they reach maximum voltage (2S 8.4v, 3S 12.6v), I just hit "stop" on my SB 989 and disconnect them from the GP Equinox balancing module I use with my SB 989.
Trickle charging the LiPos would only be handy if you charge first and then balance once the battery is topped up. If you balance as you charge, you don't have to trickle charge.
To a tree, balsa wood and MonoKote taste just like chicken!
Hide Signatures
(in reply to guver)
       Post #: 8
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.609RCU1
