Juice
ON, CANADA Status: offline
I fired up my RCV90-SP for the first time over the weekend. I'm using Wildcat fuel... 10% nitro, 18% total oil (80:20 synthetic/castor mix). I put on a 16x14 2 blade prop as recommended by the people at BlackFly Aero. I'm going to use Otto's break-in procedure, which is four 15 minute runs at 1500 RPM, then four 15 minute runs at 2000, then four 15 minute runs at 2500, etc, etc, until max RPM is reached. I set the high-end needle 2 turns open at the start of the first run. I started the engine and had it running between 2000 - 2500 RPM for the first 5 minutes. After that I was able to get it down to between 1500 - 2000 RPM for the next 10 minutes. Throughout the run, I was continually setting the high-end needle richer and richer because I didn't notice any "slobery wetness". I kept the glow igniter on and the throttle setting was constant throughout the whole run, but the engine kept speeding up and slowing down in 500 RPM swings. Is this normal? I set the high-end needle 4 turns open at the start of the second run. The engine was running a much more consistently between 1450 and 1500 RPM. Questions to Otto, or anyone, about the break-in procedure... When do I start to lean out the high-end needle? Do I keep it very rich for the whole duration of the break-in period (which is quite long)? Is it correct NOT to rev the engine at high RPMS during the break in procedure? In other conventional engines, you run the engine over it's entire RPM range during break in, right? But not these RCV? Thanks, Juice (Later tonight, I'll post video of the first run on my web site)
