OFFICIAL RS4 RTR 3 thread!!!!!!!Also type SS and others
Tower Hobbies
Logged in as Guest
  Printable Version
More Resources on the
RS4 3 RTR
  • 3 Active Classified Ad(s)
  • See User Ratings
  • Suggest Compatible Equip.
  • Check for Retailers
  • Discussions on this Product
  • All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC On Road Nitro Cars >> OFFICIAL RS4 RTR 3 thread!!!!!!!Also type SS and others
    Page: <<   < prev  13 14 [15] 16 17 18 19 20 21 22   next >   >>
    Login
    OFFICIAL RS4 RTR 3 thread!!!!!!!Also type SS and others - 8/13/2003 9:56:36 AM
    GALAXY
    Status: offline
    Associated makes titanium blue anodized turnbuckles for our car... http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXSF87&P=K and the RPM ends look good.I think thats what I'm gonna go for.
    _____________________________
    Breakin out the old car with a new motor and more nitro!!!
    (in reply to RS4RACER)
           Post #: 351
    OFFICIAL RS4 RTR 3 thread!!!!!!!Also type SS and others - 8/13/2003 9:58:45 AM
    lazoj
    Status: offline
    Will the fantom '03 r12 pullstart/rear exhaust fit on the SS? There isn't musch room between the stock header and the rear tire, so not sure if the rear exhust will pose a problem.
    https://www.ssl-stormerhobbies.com/cgi-bin/seekpart.pl?pn=FAN01012
    HPI RS4 3 SS|HPI Racing Clutch|MIP CVD's (front)|HB Center bulkhead (just for looks!)|HPI sways|HPI graphite towers|HB Top d
           Post #: 352
    OFFICIAL RS4 RTR 3 thread!!!!!!!Also type SS and others - 8/13/2003 10:06:22 AM
    Blackjaxx360
    Status: offline
    The Rpm's are a good move. Just those darned Lunsfords. Unless you like to grind titanium.....................
    After it was all said and done, I've had excellent steering response from them. Almost touchy.
    [b] BLACK-OUT[/b]..........[i]coming soon![/i]
           Post #: 353
    OFFICIAL RS4 RTR 3 thread!!!!!!!Also type SS and others - 8/13/2003 2:12:19 PM
    Rex2342
    Status: offline
    I think I figured out a solution to our lundsford problem.In the "set" for the Rs4 3 their is 4 one inch turnbuckles and two really long ones and two really short ones.I used the two really long ones to replace the steering rod and servo rod and got two extra 1 inch turnbuckles for the read tie rods.It would have been cheaper just to buy them seperatly or get another kind like AE or GPM but now I know and so do you.
    I DON"T NEED NO INSTRUCTIONS TO KNOW HOW TO ROCK!!!!!!!
           Post #: 354
    OFFICIAL RS4 RTR 3 thread!!!!!!!Also type SS and others - 8/13/2003 7:33:09 PM
    Blackjaxx360
    Status: offline
    Yeah, I kinda like doing things the hard way, LOL :
           Post #: 355
    OFFICIAL RS4 RTR 3 thread!!!!!!!Also type SS and others - 8/15/2003 1:22:42 AM
    RallyBoi
    Status: offline
    Bizzzump!
    Don't want this falling of the charts
    Quit kidding yourself... there is no cure.
           Post #: 356
    OFFICIAL RS4 RTR 3 thread!!!!!!!Also type SS and others - 8/15/2003 8:40:48 AM
    otterball21
    Status: offline
    Are turn buckles worth it? they seem so hasslish.. I like the idea that hpi just gave us some plastic parts.. snap them on.. and voila.. they are the same distance.. no need to measure.. etc etc..
    [img]http://www.danasoft.com/vipersig.jpg[/img]
    muahahaha!!!!!! I know you!!!
           Post #: 357
    OFFICIAL RS4 RTR 3 thread!!!!!!!Also type SS and others - 8/15/2003 9:19:02 AM
    GALAXY
    Status: offline
    if you don't think you need em,you probably dont.I like the idea of being able to adjust things though in case the tires arent wearing evenly or something...or I adjust the ride height.
           Post #: 358
    OFFICIAL RS4 RTR 3 thread!!!!!!!Also type SS and others - 8/15/2003 11:07:49 AM
    Blackjaxx360
    Status: offline
    They are worth it if you think you need them. the plastic ones seem to absorb and twist upon heavy usage.
           Post #: 359
    OFFICIAL RS4 RTR 3 thread!!!!!!!Also type SS and others - 8/15/2003 12:05:40 PM
    Rex2342
    Status: offline
    My stock ballends kept popping off so that why I went for the heavy duty ballends.The turnbuckles were just an upgrade I wanted to do.I could have just used the stock turnbuckles and HD ballends but I had the extra cash for the turnbuckles.
           Post #: 360
    OFFICIAL RS4 RTR 3 thread!!!!!!!Also type SS and others - 8/15/2003 4:51:20 PM
    GALAXY
    Status: offline
    Is there a ball cup removal tool?I can see em twist and flex when I take em off and its wearing em out,I wanna be able to use em on the other chassis.
           Post #: 361
    OFFICIAL RS4 RTR 3 thread!!!!!!!Also type SS and others - 8/15/2003 11:33:03 PM
    Blackjaxx360
    Status: offline
    Mine kept popping off too. I was going to just get ball cups also, but I decided to get the turnbuckles then because I figured I was going to get them eventually, so I just killed two birds.........
           Post #: 362
    75 cc fuel tanks ; suspension mods - 8/16/2003 6:33:03 AM
    Richard Freeman
    Status: offline
    Well I was at work and found this web site and read all the notes , ideas and look at the posted photos and could not wait to get home and register and pos replies. I like the forum.
    About the fule tank, I have replaced the stock tank (bottom feed, primer puump) with a top feeder, no primer pump. and have had better luck. I am here in Texas and when running in the 100 + heat on black tops and racing on parking lot race track you get fule foaming and boiling which will cause air bubbles in the fuel feed line causing the car to stop running ! Cured it.
    I have modified the suspention so that:
    1) the rod ends DO NOT POP OFF (front and rear)
    2) the toe and camber can be set
    3) the tie rods and steering links have hemis on both ends that can not pop loose.
           Post #: 363
    OFFICIAL RS4 RTR 3 thread!!!!!!!Also type SS and others - 8/16/2003 7:03:54 AM
    lazoj
    Status: offline
    Galaxy,
    Any pics of your car yet?
