RE: OFFICIAL RS4 RTR 3 thread!!!!!!!Also type SS and others
Tower Hobbies
Logged in as Guest
  Printable Version
More Resources on the
RS4 3 RTR
  • 3 Active Classified Ad(s)
  • See User Ratings
  • Suggest Compatible Equip.
  • Check for Retailers
  • Discussions on this Product
  • All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC On Road Nitro Cars >> RE: OFFICIAL RS4 RTR 3 thread!!!!!!!Also type SS and others
    Page: <<   < prev  164 165 [166] 167 168 169 170 171 172 173   next >   >>
    Login
    RE: OFFICIAL RS4 RTR 3 thr... - 4/16/2008 10:24:47 AM
    GYNAIKAS
    Status: offline
    quote:
    ORIGINAL: mokee1218
    My rs4 is old its a type 3 ss. And hpi is only selling parts for the rs4 18ss, do i share the same parts with this model specially the chassis? IF the bent in my chassis is not that big, does it still affect the handling of my car? I don''''t know what to do i can''''t make the car run straight. It is fine when you push it. But when you actually run it. Its handling is kinda wild for an unmodified car. I have changed to new tires already.
    Yeap! No affection at all. In fact if you get the 18ss heavy duty cups it will be much better than now!
    _____________________________
    I simply love perfection...do something as good as you can or don't do it at all...
    (in reply to mokee1218)
           Post #: 4126
    RE: OFFICIAL RS4 RTR 3 thr... - 4/16/2008 12:52:34 PM
    GALAXY
    Status: offline
    I finished my porting on the header pipe last night,I thought my previous port job was plenty but I must''ve gave up halfway through because it wasn''t much of an improvement over stock...now it will flow.I''ll get pics of that up this afternoon along with a few de-anodized parts.
    Breakin out the old car with a new motor and more nitro!!!
    (in reply to GYNAIKAS)
           Post #: 4127
    RE: OFFICIAL RS4 RTR 3 th... - 4/16/2008 2:49:19 PM
    GYNAIKAS
    Status: offline
    I''ve done header porting too on the stock manifold...and sleeve porting...and crankshaft modification...now the 18ss engine screams with 25% racing fuel!!!
    (in reply to GALAXY)
           Post #: 4128
    RE: OFFICIAL RS4 RTR 3 thr... - 4/16/2008 9:59:39 PM
    jjjjjoey
    Status: offline
    quote:
    ORIGINAL: viper6913
    joey. im not sure about the evo's but my .12 type ss doesnt have reverse. and i dont think that any rs4 has reverse. but i could be mistaken
    I see.
    Well here's how it looks in my instruction booklet...
    The first switch says it a a Reverse Switch (ST.REV), and it's set to "R". When I set it to "N" nothing happens
    When I flip the bottom switch (TH.REV) to "N", the car takes off full throttle.
    Now maybe I'm just confused about what these two switches are for. Can someone help?
    Click to see fullsize image.
    Click for fullsize
    < Message edited by jjjjjoey -- 4/16/2008 10:00:50 PM >
    (in reply to viper6913)
           Post #: 4129
    RE: OFFICIAL RS4 RTR 3 th... - 4/16/2008 10:22:07 PM
    GYNAIKAS
    Status: offline
    No these things reverse the servo rotation!!! If you reverse it then while braking the throtle applies. That's the reason that when you turn it the servo gets a new neutral position in wich carburator is open...so rpm increase.
    (in reply to jjjjjoey)
           Post #: 4130
    RE: OFFICIAL RS4 RTR 3 th... - 4/16/2008 10:37:38 PM
    ferrarimk13
    Status: offline
    yes, its just flips it around, if youre lefty or something, or want to change it around, no reverse though.
    Viper, a direct drop in that could kill the .12 is the O.S. 18CVR, great cheap monster.
    press Alt+F4 for a good time.
           Post #: 4131
    RE: OFFICIAL RS4 RTR 3 thre... - 4/16/2008 10:48:40 PM
    GYNAIKAS
    Status: offline
    quote:
    ORIGINAL: viper6913
    crazy idea. could i fit a savage .25 motor on my rs4? probably not. anyone got any suggestions for an engine that will give me more power than my .12 but be a direct drop in. or perhaps require minor mods.
    Get a nitro star 18ss or CVR-X or an LRP z-.18s. If you need more power get one of them and modify, or simply mount an OS .18 tz on it.
           Post #: 4132
    RE: OFFICIAL RS4 RTR 3 thre... - 4/17/2008 1:54:59 AM
    viper6913
    Status: offline
    ya i needd to get something new. my .12 cant hold a tune to save its life. what would be the most direct fit engine. without major upgrades.
           Post #: 4133
    RE: OFFICIAL RS4 RTR 3 th... - 4/17/2008 2:56:14 AM
    GYNAIKAS
    Status: offline
    I believe the nitro star 18ss...but I'm not 100% sure about that. You should check the 18ss manual to see if it needs the same engine mounts, flywheel (and flywheel nut) and clutchbell as the ones you currently use.
           Post #: 4134
    RE: OFFICIAL RS4 RTR 3 th... - 4/18/2008 1:01:35 AM
    Dakota_2878
    Status: offline
    GYNAIKAS see you pic made "shot of the moment" again today Lookin sweet. well done
           Post #: 4135
    RE: OFFICIAL RS4 RTR 3 th... - 4/18/2008 2:31:15 AM
    viper6913
    Status: offline
    can someone tell me the difference between the os cvr, cvrx, tz and the nitro star g3.0 and the t3.0
    (in reply to Dakota_2878)
           Post #: 4136
    RE: OFFICIAL RS4 RTR 3 thread!!!!!!!Also type SS and o... - 4/21/2008 1:55:56 PM
    Customiza
    Status: offline
    I have done extensive research and I found that the 200mm HPI Porsche Carrera GT body with HPI's GT adjustable nylon wing gives maximum downforce with maximum speed potenial. ( just remember not to put the stock wing on !) Just some friendly advice, will post more when I'm done tweaking and expirimenting.
    (in reply to Allan Aguilar)
           Post #: 4137
    RE: OFFICIAL RS4 RTR 3 th... - 4/21/2008 4:23:23 PM
    ferrarimk13
    Status: offline
    quote:
    ORIGINAL: viper6913
    The CVR and TZ are very similar in internal design, but the TZ is a little better quality, and produces more power, while the CVR is a lot like the HPI .18s, only a little better stock. The X on the end of CVR or the TZ just means its a standard shaft with a pullstart, hope that helps. I dont know much about hpi engines, but gynaikas, who is gone for a while, does.[)]
           Post #: 4138
    RE: OFFICIAL RS4 RTR 3 th... - 4/21/2008 5:24:57 PM
