RE: OFFICIAL RS4 RTR 3 thread!!!!!!!Also type SS and others
Tower Hobbies
Logged in as Guest
  Printable Version
More Resources on the
RS4 3 RTR
  • 2 Active Classified Ad(s)
  • See User Ratings
  • Suggest Compatible Equip.
  • Check for Retailers
  • Discussions on this Product
  • All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC On Road Nitro Cars >> RE: OFFICIAL RS4 RTR 3 thread!!!!!!!Also type SS and others
    Page: <<   < prev  167 168 [169] 170 171 172 173 174 175 176   next >   >>
    Login
    RE: OFFICIAL RS4 RTR 3 ... - 5/7/2008 6:52:34 AM
    maoy
    Status: offline
    So what you are saying is the rear exhaust header for the RS4 should fit regardless whether it is short or long. I am saying this because HPI makes two different rear manifold for the RS4. They make the short and long one. As mentioned before the part numbers for the short and long manifold are as follows:
    short - HPI86162
    long - HPi86163
    I plan to get the high performance pipe from HPI as well to accomendate this setup. The exhaust comes with the coupler, which should be good.
    (in reply to ferrarimk13)
           Post #: 4201
    RE: OFFICIAL RS4 RTR 3 ... - 5/7/2008 1:27:20 PM
    phoenex1
    Status: offline
    Just a bit of advise don't hit that bump again -It's gonna get expensive. Just my opinion
    (in reply to maoy)
           Post #: 4202
    RE: OFFICIAL RS4 RTR 3... - 5/7/2008 4:12:01 PM
    ferrarimk13
    Status: offline
    what motor will u use maoy? i would tell you to get the short one, because the longer is wider, and might hit the tire.
    _____________________________
    press Alt+F4 for a good time.
    (in reply to phoenex1)
           Post #: 4203
    RE: OFFICIAL RS4 RTR 3... - 5/7/2008 4:36:37 PM
    maoy
    Status: offline
    phoenex1 , yea you are right. I was trying to avoid that bump but on that day, somebody parked in the middle of the parking lot. I should have just stayed away from that side of the parking lot but I wanted to clear the whole parking lot and that is when I hit the bump. Stupid idea. I might get a new chassis because mine is a sort of bent. It still works fine but I want something lighter and stronger. Any ideas?
    ferrarimk13, I will be receiving a Fantom FR18 shortly. That is why I am trying to get the rear exhaust.
           Post #: 4204
    RE: OFFICIAL RS4 RTR 3... - 5/7/2008 9:08:51 PM
    phoenex1
    Status: offline
    Well if you want to continue to play with that bump you might consider something else from the HPI Family Like the Baja SSI just ordered mine and that thing will tame most bumps. HPI is pretty durable so for the money a stock replacement chassis is probably the cheapest.
    Good luck-You should post a picture of that bump -LOL
    (in reply to maoy)
           Post #: 4205
    RE: OFFICIAL RS4 RTR 3... - 5/7/2008 11:49:35 PM
    ferrarimk13
    Status: offline
    quote:
    ORIGINAL: maoy
    oh, i wanted that engine badly. Its a rear exhaust? pullstart or no? and where did you get it?
    (in reply to maoy)
           Post #: 4206
    RE: OFFICIAL RS4 RTR 3... - 5/8/2008 2:10:28 AM
    maoy
    Status: offline
    Post a picture of the bump, hahaha. It will be call the bump of many filps.
    Ferrari, I have been tracking that engine down for the past couple of weeks. I finally found it on ebay. The engine is a non-pull start. It just comes with a backplate and needs a pullstart. I am going to see if my roto start will fit it, if yes, I will definitely use it as always. The engine is a rear exhaust and comes with 1.95HP @ 39000 rpm. Probably the strongest small block, too bad it is no longer available. I think the one I bought is the newer version before Fantom discontinued the engine (which means it is turbo plug). Damn it, turbo plugs. I want the original standard plug head. Let's see how things work out. Also, it is SG shaft which means I will have to go buy a clutch nut. Any recommendations?
    Also, what rear exhaust would you recommend? Should I just stick w/ the hpi rear headers and the hpi tuned pipe or should I change over to inline tuned pipe?
    If so, which is a reasonable one in your opinion?
    < Message edited by maoy -- 5/8/2008 5:55:13 AM >
           Post #: 4207
    RE: OFFICIAL RS4 RTR 3... - 5/8/2008 9:23:16 PM
    ferrarimk13
    Status: offline
    stick with an hpi pipe set, because thats the one that will be closest fitting. The TZ is the strongest small block with like 2.3 hp or something, their not completely true numbers though, and i would of still got a fantom. I was acutally thinking of getting the fantom .12, which is a little weaker.
    (in reply to maoy)
           Post #: 4208
    RE: OFFICIAL RS4 RTR 3... - 5/9/2008 8:33:09 AM
    maoy
    Status: offline
    Hey, the FR18 is slide carb. Will this conversion kit work?
    URL:
    http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXRD81
    Also, I can't fit HPi's roto start nor pullstart on the back. The backplate is smaller in diameter compared to my diablo and HPI stuff. How are the tiger drives? There is one for the FR18. I want to know what will I need to drive the tiger drives (drill)?
           Post #: 4209
    RE: OFFICIAL RS4 RTR 3... - 5/13/2008 8:17:00 PM
    maoy
    Status: offline
    Hey everyone, decided not to drop in the FR18. Parts are too scarce, I will just show it off in a case.
    Anybody here knows anything about this -> Picco .21 & Picco .26 are small block crankcases. They should work with small block mounts. I might drop the .26 in my RS4 just to see it fly. Please let me know if anybody here has tried or heard of somebody who tried this conversion?
    (in reply to maoy)
           Post #: 4210
    RE: OFFICIAL RS4 RTR 3... - 5/14/2008 10:20:17 PM
    GYNAIKAS
    Status: offline
    Well if you mount the .26 on it you should be careful not to destroy anything in the transmission due to massive stress!
    PS: POST #3000!!! LOL
    I simply love perfection...do something as good as you can or don't do it at all...
    (in reply to maoy)
           Post #: 4211
    RE: OFFICIAL RS4 RTR 3... - 5/14/2008 10:41:23 PM
    ferrarimk13
    Status: offline
    .26 arent that great, it would be smarter to get a .21, if you can, and onroad .21, that would be outrageous, but mucho stress will be put on your car.
    (in reply to GYNAIKAS)
           Post #: 4212
    RE: OFFICIAL RS4 RTR 3... - 5/15/2008 12:59:06 AM
    GYNAIKAS
    Status: offline
    I agree. A .21 engine will be as effective as the .26 because the lightweight 1:10 cars don't need so much torque. And the .21 has WAY more top end.
           Post #: 4213
    RE: OFFICIAL RS4 RTR 3... - 5/15/2008 2:08:51 AM
