maoy
CA, USA Status: offline
If it is not shifting gear, here is a trick that you can pull. Take the two speed out and check the 2 speed cam or 2 speed clutch. Take a hex screw driver or something that is small enough to poke at the cam arm. If you take the hex screw and press on one side of the cam arm, the other side that comes out during high rpm should be able to lift up. If it is able to lift up easily, the car should shift fine. If you have to poke hard at it before it comes out, then you have it set tight. If it does not lift up, you have it completely in and should loosen it. Hope this helps.
