NismoGTR
quote:
ORIGINAL: maoy Yes, OS engines are good. Everybody that I know recommends them. I personally don't have experience with them. I would recommend a Fantom FR18 but they are discontinued. The only difference between the fr18 and the OS .18tz is the FR18 will rev higher. They are basically equivalent. As mentioned before in this forum, there was a dyno done on the OS .18 that pop out 2.28hp. I can't say anything about that because I believe that was the modified/ported version of the .18tz not the regular version (it is on their website). Also, keep in mind that the .18tz is turbo plug, which means you will be paying more for glow plugs. Keep on looking, you might find an engine that meets your needs. So far, .18tz is the best choice. If you go w/ the .18tz, get it from RCPlanet because it is like $20 cheaper than tower. Look at the link below. Also, take a look at the video below, you might want a .12 engine. .18tz RCPlanet: http://www.rcplanet.com/O_S_18TZ_TX_w_Rotary_Carb_p/osm11943.htm sirio .12: http://youtube.com/watch?v=WSYSPCjL4e4 That Sirio .12 has Crazy torque! Ok guys, I understand more rpm means more speed and obviously not torque. How can I tell if an engine has torque like the Sirio .12?
