RE: OFFICIAL RS4 RTR 3 thread!!!!!!!Also type SS and others
Tower Hobbies
Logged in as Guest
  Printable Version
More Resources on the
RS4 3 RTR
  • 3 Active Classified Ad(s)
  • See User Ratings
  • Suggest Compatible Equip.
  • Check for Retailers
  • Discussions on this Product
  • All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC On Road Nitro Cars >> RE: OFFICIAL RS4 RTR 3 thread!!!!!!!Also type SS and others
    Page: <<   < prev  173 174 [175] 176 177 178 179 180 181 182   next >   >>
    Login
    RE: OFFICIAL RS4 ... - 7/6/2008 12:26:44 PM
    GYNAIKAS
    Status: offline
    Simply go to your Local shop and get one! I think the rotostart uses the same backplate nut as the pullstart. So just a get a pullstart tat fits. I think that the 3.0, 18ss and T-15 engine use backplates of the same so any of these pullstarters fit. But I'm not 100% sure!
    _____________________________
    I simply love perfection...do something as good as you can or don't do it at all...
    (in reply to NismoGTR)
           Post #: 4351
    RE: OFFICIAL RS4 ... - 7/8/2008 9:31:12 PM
    phoenex1
    Status: offline
    I was just surfing around and found this link http://www.rchardware.com/index.html This is a great little tuning option and there are setup sheets at the site that can be downloaded. I may buy one for each of my cars and trucks-takes a lot of the guess work out of getting that engine right each time.
           Post #: 4352
    RE: OFFICIAL RS4 ... - 7/8/2008 11:32:05 PM
    one-syk
    Status: offline
    wow...its been about 2 years since ive been on this site.
    i think its time i get back into HPI nitro on-road car's, and some more nitro drifting.
    does anyone remember a tuned pipe that was made of stainless steel, and had a burnt finish on it? i think it was a team pipe, but i cant remember who makes it.
    < Message edited by one-syk -- 7/9/2008 12:03:21 AM >
    2008 HPI Savage X 4.6, HPI pullstart...
    (in reply to phoenex1)
           Post #: 4353
    RE: OFFICIAL RS4... - 7/9/2008 4:34:15 PM
    maoy
    Status: offline
    Hey phoenex1, I saw that before and thought it was cool. However, I don't think it is necessary. If you break your engine in properly by temperature, you will get a good setting. From there, you can make minimal adjustments for your day to day weather changes.
    Hey one-syk, I can't help you there. Won't stainless steel add weight onto your car? Burnt finish? Or do you mean flare (multicolor burn)? It would be cool to have a flare exhaust tip.
    (in reply to one-syk)
           Post #: 4354
    RE: OFFICIAL RS4... - 7/9/2008 6:03:15 PM
    one-syk
    Status: offline
    yeah, it add's a little weight, but nothing major that anyone will notice....its stainless with the natural stainless finish, has the bluing around the weld's.
    im waiting to hear back from fantom racing.
    (in reply to maoy)
           Post #: 4355
    RE: OFFICIAL RS4... - 7/9/2008 8:45:11 PM
    phoenex1
    Status: offline
    I understand the concept completely but,If you look back through this thread at how many tuning questions and discussions come up I thought it was a good tool to pass along and it isn't like it weighs a pound-LOL
    (in reply to maoy)
           Post #: 4356
    RE: OFFICIAL RS4... - 7/9/2008 10:02:53 PM
    one-syk
    Status: offline
    its a quality pipe....sounds pretty sick too.
    ill post up pictures once i find one for sale.
           Post #: 4357
    RE: OFFICIAL RS4... - 7/10/2008 12:39:03 AM
    losifiend
    Status: offline
    Mr. Brown just dropped off my RS4 Evo+. I got the Cuda body becasue I didnt like th eother ones.....It looks awsome sitting on top of my big screem .
    Installing a reciever so I can run it with my DX3R tomorrow. Going to power it with an OFNA 800 MAH battery. I have a spare one from my CRT.5. I'm going to add some springs in between the break pads so that they dont drag. I also noticed that the fuel line coming out of the bottom of the tank is hitting on the pinion gear and awfully close to the two speed! It need a filter too.
    Does any one know where to find that clear under body liner? I get really anel about getting the bottom of my rad cars beat.
           Post #: 4358
    RE: OFFICIAL RS4... - 7/10/2008 1:06:36 AM
    one-syk
    Status: offline
    the underside is going to get beat up no matter what you do, if you use it.
    to space the gas tank up a little higher add a washer, or o-ring between the gas tank and the post it sits on, then put the screw back in.
    the first mod's i would do is a better brake disc, port the manifold, tuned pipe, fuel filter, longer fuel line from the tank to the carb, and the primerless fuel tank.
    < Message edited by one-syk -- 7/10/2008 1:07:35 AM >
    (in reply to losifiend)
           Post #: 4359
    RE: OFFICIAL RS4... - 7/10/2008 2:06:07 AM
    losifiend
    Status: offline
    Thanks. What disk is reccomended? Are the pads ok to leave?
    Also, what pipe are people using to wake up the .18?
    Rafael
           Post #: 4360
    RE: OFFICIAL RS4... - 7/10/2008 3:04:19 AM
    one-syk
    Status: offline
    the stock plastic/"graphite" disc is garbage...get the brown kevlar or carbon one from HPI..it grip's awesome!..the pad's are fine...maybe scuff them with some fine grit sand paper if you want, but i think most leave them alone.
    i personally like:
    fantom racing pipe
    cvec pipe
    O.S. pipe
    but they all basically do the same thing...the cvecc is tunable, the O.S. is just a basic pipe, but its made in japan, and the fantom is great quality, and noticable gain's throughout the rpm range.
    its all personal prefrence really...get what you like, and what fits your budget.
           Post #: 4361
    RE: OFFICIAL RS4... - 7/10/2008 3:37:15 AM
    all-out
    Status: offline
    can you link to the phantom please?
           Post #: 4362
    RE: OFFICIAL RS4... - 7/10/2008 4:17:29 AM
    losifiend
    Status: offline
    Do you know anything about the HPI polished tuned pipe?
    Thanks!
    (in reply to all-out)
           Post #: 4363
    RE: OFFICIAL RS4... - 7/10/2008 4:27:38 AM
    one-syk
    Status: offline
    the hpi aluminum tuned pipe works good too...i had one on my
