JonKBMW
PA, USA Status: offline
First and foremost I received my parts from RC-Mall.net - excellent service! Here is what I've got Lots of stuff! HOWEVER! I am having issues with two things. Firstly, the GPM center gear mount: I am trying to install this part: Onto my HPI RS4 3 EVO+, and I am having trouble doing so because of the brake. Maybe I am missing something, but if you look close the brass colored inserts go through the two brake plates, with the brake disc between. However, it seems that the brake disc is either too tight, or I am doing something wrong because I cannot get the brake disc between the two plates without the brake being on full-time. Secondly - I got the lower arm kit too - it comes with a bunch of flat washers (very thin) that I don't know what to do with! I know the circlips hold the rods in, do the washers go between the circlips and the arms? Doesn't seem like there'd be enough room but maybe there is. I dunno - can anyone help with either of these two issues? Also - where can I get wheel spacers from?
