RE: OFFICIAL RS4 RTR 3 thread!!!!!!!Also type SS and others    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC On Road Nitro Cars >> RE: OFFICIAL RS4 RTR 3 thread!!!!!!!Also type SS and others
Page: <<   < prev  227 228 [229] 230 231 232 233 234 235 236   next >   >>
Login
RE: OFFICIAL RS4 RTR 3 thread!!!!!!!Also type SS and ot... - 4/27/2012 3:55 AM
fdjizm
Score: 110
Last Login: 5/17/2013
Status: offline
I didn't swap the shafts, just the cups from the front to back. shafts stay the same.
_____________________________
HPI Super nitro RS4 RB .28-HPI RS4 Nova flash 21
HPI RS4-3 RB Xenon-R .21-HPI Racer 2 OS .18-HPI R40 OS .18
Hide Signatures
(in reply to Car-Tune)
       Post #: 5701
RE: OFFICIAL RS4 RTR 3 thread!!!!!!!Also type SS and ot... - 4/27/2012 4:08 AM
mtz57
Score: 100
Last Login: 5/14/2013
Status: offline
I made a dubble break on my nitro mt same gear box not really need but waa cool to do
MTZ57
Hide Signatures
       Post #: 5702
RE: OFFICIAL RS4 RTR 3 thread!!!!!!!Also type SS and ot... - 4/27/2012 4:38 AM
Car-Tune
Score: 110
Last Login: 5/20/2013
Status: offline
Show pic mtz
Hide Signatures
(in reply to mtz57)
       Post #: 5703
RE: OFFICIAL RS4 RTR 3 thread!!!!!!!Also type SS and ot... - 4/27/2012 10:24 PM
fdjizm
Score: 110
Status: offline
Finished the linkage for the brake swap and the slide carb, was a little tricky but it's all perfect now!
Hide Signatures
       Post #: 5704
RE: OFFICIAL RS4 RTR 3 thread!!!!!!!Also type SS and ot... - 4/28/2012 4:01 AM
Car-Tune
Score: 110
Status: offline
That looks good. Why not swapping your break/throttle servo around so you can get link for your break.
Hide Signatures
(in reply to fdjizm)
       Post #: 5705
RE: OFFICIAL RS4 RTR 3 thread!!!!!!!Also type SS and ot... - 4/28/2012 12:45 PM
fdjizm
Score: 110
Status: offline
Then the throttle linkage would be so short I probably couldn't put the spring on it lol.
Came out perfect as pictured
Hide Signatures
       Post #: 5706
RE: OFFICIAL RS4 RTR 3 thread!!!!!!!Also type SS and ot... - 4/28/2012 1:43 PM
Car-Tune
Score: 110
Status: offline
Ok. I did mine and it's coming out good. I went to my LHS and purchases a throttle link set for a savage and it comes with the throttle, break and throttle return spring. Well the break link is long enough. Longer than what you have but not too long, just perfect to be able to use 1in of fuel tube.
Now what I have to do is cut the carbon fibber off. I also had to move my servo at an angle so the disk break won't cut the wireing from the steering servo.
That small plastic part that I said mines open at a 135 degree angle, well it comes with the straight piece too.
I don't know how you came up with this bit I think that it's a great idea. Some if the rear weight is now moved toward the front.
Hide Signatures
       Post #: 5707
RE: OFFICIAL RS4 RTR 3 thread!!!!!!!Also type SS and ot... - 4/28/2012 5:37 PM
fdjizm
Score: 110
Status: offline
Yea it works well now.
Glad you got it figured out!
I did it only to fit the big block in there but the weight is a plus.
I just got the exhaust finished I used a savage header it fits perfect with my CVEC drag pipe.
Hide Signatures
       Post #: 5708
RE: OFFICIAL RS4 RTR 3 thread!!!!!!!Also type SS and ot... - 4/28/2012 6:11 PM
Car-Tune
Score: 110
Status: offline
BEAST!!!!
Hide Signatures
       Post #: 5709
RE: OFFICIAL RS4 RTR 3 thread!!!!!!!Also type SS and ot... - 4/28/2012 10:27 PM
Evo Obsession
Score: 100
Last Login: 5/2/2013
Status: offline
NEED HELP!
Just started racing my RS4 3 Evo+, I'm racing on asphalt. I keep spinning out coming off turns and sometimes during straight ways. My setup is carbon fiber shocks with stock shocks and shock oil. Im running the hpi x-pattern rubber tires (I have nitro shoes coming in 42 front and 40 rear). What can I do to improve handling as far as shock oil, angle of shocks, springs, etc. Please help. Thanks.
Hide Signatures
(in reply to Allan Aguilar)
       Post #: 5710
RE: OFFICIAL RS4 RTR 3 thread!!!!!!!Also type SS and ot... - 4/29/2012 2:08 AM
Car-Tune
Score: 110
Status: offline
Have you locked your front differential? Does your front diff have the lock spring in it?
Mark sure You do hace that spring inside the diff so your wheel can lock a bit more and to improve the locking of your front wheels add diff lock grease.
I'm using 80w shock oil for high speed runs but I normally use 40f 35r I think. Springs are purple front and I think it's pink in rear. Lock at my pictures so you can see the exact colors.
Fdjizm
I ran my car today with that front break set up and I thing it gives me a smoother breaking than it did before. It's pretty awesome. Make sure you post up some pics with that BEAST running.
Hide Signatures
(in reply to Evo Obsession)
       Post #: 5711
RE: OFFICIAL RS4 RTR 3 thread!!!!!!!Also type SS and ot... - 4/29/2012 3:48 AM
Evo Obsession
Score: 100
Status: offline
No I havent locked the front differential. I will take it apart and see. Should the lock spring come stock with the car or is it a mod. Thanks for the input I appreciate it. Ive always been a street basher so I dont have real experience in fine tunning the suspension. I will try out your suggestions. The springs you're refereing to are HPI make? Ive checked for HPI pink and havent found it online. Are there any other makes you recommend. How are the Tamiya springs that come in a set of three?
Hide Signatures
       Post #: 5712
RE: OFFICIAL RS4 RTR 3 thread!!!!!!!Also type SS and ot... - 4/29/2012 3:55 PM
Car-Tune
Score: 110
Status: offline
I don't know about tamiya. I would think that some pretty stiff springs are needed because the rs4 3 is a pretty heavy car.
Hide Signatures
       Post #: 5713
RE: OFFICIAL RS4 RTR 3 thread!!!!!!!Also type SS and ot... - 5/1/2012 7:36 PM
fdjizm
Score: 110
Status: offline
I was testing out the car yesterday this CVEC pipe is a nightmare to tune.
I only got to 84mph before it started sounding weird and boggy and stopped pulling I may just throw a regular tune pipe on but then I need a different body. damn.
Hide Signatures
       Post #: 5714
RE: OFFICIAL RS4 RTR 3 thread!!!!!!!Also type SS and ot... - 5/2/2012 12:30 AM
Evo Obsession
Score: 100
Status: offline
I just purchased some sway bars. What combination of colors are you guys using. Whats the advantage of having it stiffer on one end compared to the other. Thanks.
Hide Signatures
       Post #: 5715
RE: OFFICIAL RS4 RTR 3 thread!!!!!!!Also type SS and ot... - 5/2/2012 2:32 AM
Car-Tune
Score: 110
Status: offline
I believe that the stiffest should go on the back. So when you take a turn the rear tire doesnt lift up on the air and it's always compressed down onto the road.
Hide Signatures
       Post #: 5716
RE: OFFICIAL RS4 RTR 3 thread!!!!!!!Also type SS and ot... - 5/2/2012 2:42 AM
AutoXRacer943
Score: 100
Last Login: 11/19/2012
Status: offline
In real cars, you want stiff on the front and less stiff in the rear... If you put more stiff in the rear, you will over-steer...
Axial SCX10 Dingo
HPI RS4 3SS all aluminum
Hide Signatures
       Post #: 5717
RE: OFFICIAL RS4 RTR 3 thread!!!!!!!Also type SS and ot... - 5/2/2012 3:47 AM
Evo Obsession
Score: 100
Status: offline
Both sound right to me. I thought by stiffining the rear then the rear of the car will be more planted to the ground especially during turns thus preventing spin outs which is my biggest concern.
Hide Signatures
(in reply to AutoXRacer943)
       Post #: 5718
RE: OFFICIAL RS4 RTR 3 thread!!!!!!!Also type SS and ot... - 5/10/2012 2:24 AM
rx7devil210
Score: 105
Status: offline
Alright i just put in the suspension stiffeners just wondering what do they do to the car??
Hide Signatures
       Post #: 5719
RE: OFFICIAL RS4 RTR 3 thread!!!!!!!Also type SS and ot... - 5/12/2012 6:31 PM
fdjizm
Score: 110
Status: offline
Trying out some new taller tires on my ride!
Went to 92mph with the 65mm foams, these are 74mm.
Engine is a modified RB xenon-r 21.
Hide Signatures
(in reply to rx7devil210)
       Post #: 5720
RE: OFFICIAL RS4 RTR 3 thread!!!!!!!Also type SS and ot... - 5/12/2012 8:45 PM
rx7devil210
Score: 105
Status: offline
Why do you have zip ties on your engine heatsink?
Hide Signatures
       Post #: 5721
RE: OFFICIAL RS4 RTR 3 thread!!!!!!!Also type SS and ot... - 5/12/2012 9:36 PM
fdjizm
Score: 110
Status: offline
Incase I flip the car the zip ties take most of the damage, which has already happend 3 times.
And I won't be able to find a replacement head for that engine.
Hide Signatures
       Post #: 5722
RE: OFFICIAL RS4 RTR 3 thread!!!!!!!Also type SS and ot... - 5/12/2012 9:40 PM
Car-Tune
Score: 110
Status: offline
Sway bars:
Ok the way they work, when you come to a turn, no matter how sharp our car will lean to the opposite side that you are turning. Right? With the sway bars it pushed down on both wheels so when you come to a turn the other tire will not lose contact to the ground and will be pushed down ward too.
If you put I. The sway bars and remove the shocks you will be able to see how it works. So there I do believe that the stiffer one goes to the front scence the front tire is the one that goes up in the air. You will be able to tell if you take a pic will the car is speeding at a turn.
Zip ties are to protect the engine if the car were to flip upside down.
Fdjizm. Where do you get those wheels?
Hide Signatures
       Post #: 5723
RE: OFFICIAL RS4 RTR 3 thread!!!!!!!Also type SS and ot... - 5/12/2012 9:57 PM
fdjizm
Score: 110
Status: offline
They are RC4LESS dirt oval foams in 45 shore.
http://www.rc4less.com/product_info.php?cPath=4&products_id=27&osCsid=2fdd6874cc3cda3b966e208a607436dd
I cut them down to 24mm, though.
You just take off the hexes and drill out the hole with a reamer just a bit and they slide right on the pin.
Hide Signatures
       Post #: 5724
RE: OFFICIAL RS4 RTR 3 thread!!!!!!!Also type SS and ot... - 5/12/2012 11:00 PM
rx7devil210
Score: 105
Status: offline
good idea i also flipped the car should i do it?
Hide Signatures
       Post #: 5725
Jump to:
Google
SITE MAP!   : :   FORUM RULES
2.156RCU1
