RE: OFFICIAL RS4 RTR 3 thread!!!!!!!Also type SS and others    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC On Road Nitro Cars >> RE: OFFICIAL RS4 RTR 3 thread!!!!!!!Also type SS and others
Page: <<   < prev  228 229 [230] 231 232 233 234 235 236 237   next >   >>
Login
RE: OFFICIAL RS4 RTR 3 thread!!!!!!!Also type SS and ot... - 5/13/2012 1:20 AM
Jackedman
Score: 105
Last Login: 5/22/2013
Status: offline
the ty wrap trick works great i have it done to my off road ones.
Hey does anyone have the hpi .15 fe engine??
_____________________________
Youtube Id Jackedman23 Check it out
RUN HER TILL SHE BLOWS
Hide Signatures
(in reply to rx7devil210)
       Post #: 5726
RE: OFFICIAL RS4 RTR 3 thread!!!!!!!Also type SS and ot... - 5/13/2012 1:33 AM
Car-Tune
Score: 110
Last Login: 5/23/2013
Status: offline
What do you need with the .15 engine?
Hide Signatures
(in reply to Jackedman)
       Post #: 5727
RE: OFFICIAL RS4 RTR 3 thread!!!!!!!Also type SS and ot... - 5/13/2012 2:38 AM
Jackedman
Score: 105
Status: offline
I dont need it. My brother in law has one in his rs4 and we cant get it running. I had mine out and it got him going to get his running again. so i was just wondering if anyone has one and could give some pointers. I know how to tune an engine but this one is bad and too top it off it has roto stat on it
Hide Signatures
(in reply to Car-Tune)
       Post #: 5728
RE: OFFICIAL RS4 RTR 3 thread!!!!!!!Also type SS and ot... - 5/14/2012 5:55 AM
Limeaway510
Score: 100
Last Login: 6/11/2012
Status: offline
***click me***
http://www.youtube.com/watch?v=n6Co_D7QUss&feature=youtu.be
^video of my rs4 at "idle"
Sup guys, I'm having problems getting my car to actually idle. I have the idle screw set pretty much as low as it can be. Back the screw out any more the engine cuts out. Today was the second day that I ran the car since rebuilding it, so the clutch (HPI A885) is pretty fresh. Initially, I was having the same idle problem yesterday and I was thinking that maybe the clutch was engaging early. I did not cut any clutch material off when I installed. I asked for some input on another forum it was suggested that if I felt the idle was set correctly, that I should just go ahead and run the car to allow the clutch to break in some rather than cutting any material off. I've put the car through about 3-4 tanks now and you can see pretty clearly how high it's still idling, lol.
Another suggestion was made to me that I should lean the low-end a bit, anyone else have some input as to what can remedy this? Thanks
Hide Signatures
       Post #: 5729
RE: OFFICIAL RS4 RTR 3 thread!!!!!!!Also type SS and ot... - 5/22/2012 3:11 AM
rx7devil210
Score: 105
Last Login: 5/14/2013
Status: offline
Does anyone have problems stripping their front axles? I was running mine today any it popped out and locked the whole system i thought i broke something major but it ended up being one of the front axle. I was just wondering if anyone had problems stripping that?  I put another o ring in the diff and it fixed it.
Hide Signatures
(in reply to Limeaway510)
       Post #: 5730
RE: OFFICIAL RS4 RTR 3 thread!!!!!!!Also type SS and ot... - 5/22/2012 4:31 AM
jamesc43
Score: 105
Last Login: 5/19/2013
Status: offline
Limeaway510,
Can you take a picture of the carb barrel when the engine is running at idle? It sounds like the engine is running to
fast for an idle. The clutch is engaged as a result. You might need to adjust the low end needle to get it to slow down.
Hide Signatures
       Post #: 5731
RE: OFFICIAL RS4 RTR 3 thread!!!!!!!Also type SS and ot... - 5/22/2012 5:54 AM
Limeaway510
Score: 100
Status: offline
@jamesc43 I've fixed the problem since that post! The servo horn was set in a position that pushed the throttle linkage just a little bit too far forward, thus giving me that false idle as the carb opening was bigger than 1mm. Just needed to rotate the horn a bit and problem solved. Appreciate the help though!
@rx7devil210 I think that's a problem with all rs4s (dogbones popping out). It's happened to me a couple times, and you're correct in adding another o-ring to fix the problem. It may be different for you, but I found that adding two o-rings to both of the diff outdrives caused the dogbones to be too tight. You do want a LITTLE bit of play, but as you've discovered too much play leads to the bones popping out.
Instead of two o-rings on each side, I used one on each side, then I sliced up some thinner 'o-rings' using some extra fuel line. This removed a majority of the dogbone slop, but didn't cause any binding and also prevented the bones from popping out.
Hide Signatures
(in reply to jamesc43)
       Post #: 5732
RE: OFFICIAL RS4 RTR 3 thread!!!!!!!Also type SS and ot... - 5/22/2012 8:53 PM
rx7devil210
Score: 105
Status: offline
Thanks for the input limeaway. What about the rear dogbones do they pop out??
Hide Signatures
       Post #: 5733
RE: OFFICIAL RS4 RTR 3 thread!!!!!!!Also type SS and ot... - 5/23/2012 1:45 AM
rx7devil210
Score: 105
Status: offline
Alright i was bashing today and for some reason the car wouldnt roll forward when i gave it throttle. So i turned it off and checked it at my work table to see that the servo wasnt working and was frozen. Luckily it wasnt at full throttle when it froze or i would of had some major damage. I called hpi and they are sending me a free replacement. Anyone had any problems with there stock servo going out??
Hide Signatures
       Post #: 5734
RE: OFFICIAL RS4 RTR 3 thread!!!!!!!Also type SS and ot... - 5/23/2012 1:50 AM
fdjizm
Score: 110
Status: online
Yea my stock throttle servo went out as well. never thought too much of it, HPI is just going to send you one? might give them a call lol
HPI Super nitro RS4 RB .28-HPI RS4 Nova flash 21
HPI RS4-3 RB Xenon-R .21-HPI Racer 2 OS .18-HPI R40 OS .18
Hide Signatures
       Post #: 5735
RE: OFFICIAL RS4 RTR 3 thread!!!!!!!Also type SS and ot... - 5/23/2012 2:29 AM
Car-Tune
Score: 110
Status: offline
HPi has replaced a few of my parts without askIng for my replacements. They are good people
Hide Signatures
(in reply to fdjizm)
       Post #: 5736
RE: OFFICIAL RS4 RTR 3 thread!!!!!!!Also type SS and ot... - 5/23/2012 2:56 AM
rx7devil210
Score: 105
Status: offline
@ car-boy what have they replaced??
Hide Signatures
       Post #: 5737
RE: OFFICIAL RS4 RTR 3 thread!!!!!!!Also type SS and ot... - 5/23/2012 5:40 AM
Car-Tune
Score: 110
Status: offline
One way diff for my sprint 2 flux. Motors bearing went out inside and ruined piston and sleeve
Hide Signatures
       Post #: 5738
RE: OFFICIAL RS4 RTR 3 thread!!!!!!!Also type SS and ot... - 5/29/2012 2:13 AM
rx7devil210
Score: 105
Status: offline
Alright guys im waiting for my throttle servo to come in and had a couple questions.  Ive never installed a servo before so i was wondering how to install it to make it perfect? I dunno what to do? How to install where the servo is striaght? Meaning that it wont have the carb open when i install it so it does have a perfect idle. Basically i thought about turning on the reicever and controller and making that the install point where the carb has enough opening so it will idle good. You guys get it??
Hide Signatures
       Post #: 5739
RE: OFFICIAL RS4 RTR 3 thread!!!!!!!Also type SS and ot... - 5/30/2012 3:15 AM
SerpentCT4S
Score: 100
Last Login: 5/20/2013
Status: offline
I am looking for a different pipe for my RS4.
I am running an OS18 CV-RX with a Vantage pipe now. What is another pipe that will perform nicely with the OS engine?
Hide Signatures
       Post #: 5740
RE: OFFICIAL RS4 RTR 3 thread!!!!!!!Also type SS and ot... - 5/30/2012 6:00 AM
Car-Tune
Score: 110
Status: offline
I used the carbon fiber vintage pipe before and I didn't like it. Now I use O.S pipe on my 18tz.
Hide Signatures
(in reply to SerpentCT4S)
       Post #: 5741
RE: OFFICIAL RS4 RTR 3 thread!!!!!!!Also type SS and ot... - 5/30/2012 11:51 AM
Jackedman
Score: 105
Status: offline
quote:
ORIGINAL: SerpentCT4S
Try the ths setup. i've ran that on my mt2 18ss for as long as i can remember and the pipe is great.
Hide Signatures
       Post #: 5742
RE: OFFICIAL RS4 RTR 3 thread!!!!!!!Also type SS and ot... - 5/30/2012 1:42 PM
SerpentCT4S
Score: 100
Status: offline
Carboy, do you have a link to the OS pipe?
Jacked, i had the THS pipe in my MT2 and i didnt really like it. The stinger is kind of small and i think that restricts air flow and power.
Any other suggestions? How is the HPI pipe?
Hide Signatures
       Post #: 5743
RE: OFFICIAL RS4 RTR 3 thread!!!!!!!Also type SS and ot... - 5/30/2012 2:17 PM
Car-Tune
Score: 110
Status: offline
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXHGK6&P=7
Hide Signatures
       Post #: 5744
RE: OFFICIAL RS4 RTR 3 thread!!!!!!!Also type SS and ot... - 5/30/2012 3:35 PM
SerpentCT4S
Score: 100
Status: offline
I notice they also make a R70 pipe, which has a larger stinger.
Do you have a link to that one?
Hide Signatures
       Post #: 5745
Jackedman
Score: 105
Status: offline
I have the new stock pipe on my car and it seems to be pretty good
Hide Signatures
       Post #: 5746
RE: OFFICIAL RS4 RTR 3 thread!!!!!!!Also type SS and ot... - 5/30/2012 3:49 PM
Car-Tune
Score: 110
Status: offline
If the stinger is bigger you will lose top end on your motor. That's why I didn't like the vantage carbon fiber pipe, the stinger was too big. I think it was only good for drag racing with a ported engine. But if you get a small stinger it will work good with your engine because these engines work on high rpm's. On a on road race or bash you hardly idle then launch.
Hide Signatures
       Post #: 5747
RE: OFFICIAL RS4 RTR 3 thread!!!!!!!Also type SS and ot... - 5/30/2012 4:34 PM
SerpentCT4S
Score: 100
Status: offline
Thanks for the info.
I am going to my shop tomorrow. Im pretty sure they have the THS pipe, so i will probably get that.
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXPNB9&P=ML
Hide Signatures
       Post #: 5748
RE: OFFICIAL RS4 RTR 3 thread!!!!!!!Also type SS and ot... - 5/30/2012 9:40 PM
Car-Tune
Score: 110
Status: offline
I'm pretty sure that it's pretty good but if you go aftermarket it's better.
Hide Signatures
       Post #: 5749
RE: OFFICIAL RS4 RTR 3 thread!!!!!!!Also type SS and ot... - 5/30/2012 11:10 PM
SerpentCT4S
Score: 100
Status: offline
I just wish the THS pipe had a bigger stinger. I have the THS pipe on my Super Nitro with an OS18 and it is so quiet.
Hide Signatures
       Post #: 5750
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.781RCU1
