OFFICIAL RS4 RTR 3 thread!!!!!!!Also type SS and others
Tower Hobbies
Logged in as Guest
  Printable Version
More Resources on the
RS4 3 RTR
  • 2 Active Classified Ad(s)
  • See User Ratings
  • Suggest Compatible Equip.
  • Check for Retailers
  • Discussions on this Product
  • All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC On Road Nitro Cars >> OFFICIAL RS4 RTR 3 thread!!!!!!!Also type SS and others
    Page: <<   < prev  2 3 [4] 5 6 7 8 9 10 11   next >   >>
    Login
    OFFICIAL RS4 RTR 3 thread!!!!!!!Also type SS and others - 6/29/2003 10:59:14 PM
    Rex2342
    Status: offline
    I like the graphite stuff.It's almost just as stiff as the alloy stuff but it's lighter and cheaper.It is more fragile but it won't bend like some of the cheaper alloy stuff and it's pretty cheap to replace if it does brake.
    _____________________________
    I DON"T NEED NO INSTRUCTIONS TO KNOW HOW TO ROCK!!!!!!!
    (in reply to RS4RACER)
           Post #: 76
    OFFICIAL RS4 RTR 3 thread!!!!!!!Also type SS and others - 6/29/2003 11:39:47 PM
    brainleak
    Status: offline
    Any one have a REALLY easy way to get these damn stock turnbuckles off? they are giving me hell. and im trying to replace every one of them. Any help would be great
    Brainleak
           Post #: 77
    OFFICIAL RS4 RTR 3 thread!!!!!!!Also type SS and others - 6/30/2003 6:29:44 AM
    gmac4826
    Status: offline
    about the fail safe, if a cop car or something like that drives by then you will have this prob. usually wont make the car beserk but triggers fail safe for some reason.
    Who needs brakes?? All they do is slow you down.
           Post #: 78
    OFFICIAL RS4 RTR 3 thread!!!!!!!Also type SS and others - 7/3/2003 8:49:18 AM
    Allan Aguilar
    Status: offline
    What happened here, this thread will be buried, keep on pouring your replies and post to this thread. Afterall, this is an "OFFICIAL RS4 RTR 3 thread!!!!!!!Also type SS and others", am I right ?
    Allan
    Sponsored by : MY SECOND JOB ! ! !
           Post #: 79
    OFFICIAL RS4 RTR 3 thread!!!!!!!Also type SS and others - 7/3/2003 5:38:46 PM
    RS4RACER
    Status: offline
    yeah it is. anyway, heres a problem. when I put on the glo igniter and pull the pullstart, a whitish vapor comes from around the cooling head-no kidding. The needle valve is at 2 turns, 20% blue thunder fuel.
    -RS4RACER
           Post #: 80
    OFFICIAL RS4 RTR 3 thread!!!!!!!Also type SS and others - 7/3/2003 6:51:22 PM
    gmac4826
    Status: offline
    if it is vapor and not fuel it isnt real dagerous. when i run my car for a while i have vapor comin off the cooling head but not when i pul the pull start. maybe it is the type of glow plug u r usin.
           Post #: 81
    OFFICIAL RS4 RTR 3 thread!!!!!!!Also type SS and others - 7/3/2003 7:20:19 PM
    Aggdaddy
    Status: offline
    [QUOTE]Originally posted by RS4RACER
    speaking of tuning, when i go to adjust the shift time on my 2 speed, which set screw should i turn? there are two holes with set screws, one has a spring and a ball inside the hole, though... [/QUOTE]
    This is for everybody with an RS4 SS. Make sure that your two speed set screw is to the right of the shaft set screw when your car is facing away from you. If the two speed set screw is to the left, then that cam is backwards. very easy to do, since HPI didn't focus on that in the manual.
    Otherwise, it should shift two turns out and your motor is tuned properly.
           Post #: 82
    OFFICIAL RS4 RTR 3 thread!!!!!!!Also type SS and others - 7/4/2003 3:54:20 AM
    RS4RACER
    Status: offline
    my first body-painting work: [IMG]bodyfront.jpg[/IMG]
    -RS4RACER
           Post #: 83
    OFFICIAL RS4 RTR 3 thread!!!!!!!Also type SS and others - 7/4/2003 10:59:50 PM
    otterball21
    Status: offline
    I think you might be missing the gasket... ?! from the cooling head to the top of the engine..
    [img]http://www.danasoft.com/vipersig.jpg[/img]
    muahahaha!!!!!! I know you!!!
           Post #: 84
    OFFICIAL RS4 RTR 3 thread!!!!!!!Also type SS and others - 7/4/2003 11:07:54 PM
    otterball21
    Status: offline
    ALmost forgot, I really don't know what the heck my HPI is.... It's a shaft driven 4wd... it has a .15 FE engine on it.. however it has two speed transmission.. and the previous owner had RS4 3 ss all over the black comaro body.. so what do I really have? gah!..
           Post #: 85
    OFFICIAL RS4 RTR 3 thread!!!!!!!Also type SS and others - 7/4/2003 11:16:55 PM
    HPIRS4-3SS
    Status: offline
    but the rs4 ss dosent have a 15fe engine
           Post #: 86
    OFFICIAL RS4 RTR 3 thread!!!!!!!Also type SS and others - 7/4/2003 11:37:12 PM
    Rex2342
    Status: offline
    Mybe for some reason the person you bought it off of thought the 15FE was faster than the 12RSS Or maybe it was an RTR with a 2speed added and a Type SS decal sheet.
           Post #: 87
    OFFICIAL RS4 RTR 3 thread!!!!!!!Also type SS and others - 7/5/2003 12:00:29 AM
    otterball21
    Status: offline
    gah ergh
           Post #: 88
    OFFICIAL RS4 RTR 3 thread!!!!!!!Also type SS and others - 7/5/2003 3:22:25 AM
    RS4RACER
    Status: offline
    The camaro body says, camaro ss. that is the type of car(body). it is an rtr 3 with an aftermarket 2 speed. I have the same setup.
    -RS4RACER
