Aggdaddy
[QUOTE]Originally posted by RS4RACER speaking of tuning, when i go to adjust the shift time on my 2 speed, which set screw should i turn? there are two holes with set screws, one has a spring and a ball inside the hole, though... [/QUOTE] This is for everybody with an RS4 SS. Make sure that your two speed set screw is to the right of the shaft set screw when your car is facing away from you. If the two speed set screw is to the left, then that cam is backwards. very easy to do, since HPI didn't focus on that in the manual. Otherwise, it should shift two turns out and your motor is tuned properly.
