OFFICIAL RS4 RTR 3 thread!!!!!!!Also type SS and others
Tower Hobbies
Logged in as Guest
  Printable Version
More Resources on the
RS4 3 RTR
  • 3 Active Classified Ad(s)
  • See User Ratings
  • Suggest Compatible Equip.
  • Check for Retailers
  • Discussions on this Product
  • All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC On Road Nitro Cars >> OFFICIAL RS4 RTR 3 thread!!!!!!!Also type SS and others
    Page: <<   < prev  3 4 [5] 6 7 8 9 10 11 12   next >   >>
    Login
    OFFICIAL RS4 RTR 3 thread!!!!!!!Also type SS and others - 7/7/2003 6:59:45 AM
    otterball21
    Status: offline
    Definitely has sniffing too much nitro...... I dumped my nitrous oxide money into Nitro RC cars.. :-\ betta be worth it! .. or grrrrrrrr!
    _____________________________
    [img]http://www.danasoft.com/vipersig.jpg[/img]
    muahahaha!!!!!! I know you!!!
    (in reply to RS4RACER)
           Post #: 101
    OFFICIAL RS4 RTR 3 thread!!!!!!!Also type SS and others - 7/7/2003 7:11:40 AM
    gmac4826
    Status: offline
    my cars are worth their weight in gold for all the stuff ive bought for them.
    Who needs brakes?? All they do is slow you down.
           Post #: 102
    OFFICIAL RS4 RTR 3 thread!!!!!!!Also type SS and others - 7/7/2003 7:56:16 AM
    Allan Aguilar
    Status: offline
    Needed a psychiatrist...... :
    Allan
    Sponsored by : MY SECOND JOB ! ! !
           Post #: 103
    OFFICIAL RS4 RTR 3 thread!!!!!!!Also type SS and others - 7/7/2003 8:47:03 AM
    gmac4826
    Status: offline
    no, not needED. need, not past tense present.
           Post #: 104
    Slide carb linkage and stuff. - 7/7/2003 7:29:11 PM
    Aggdaddy
    Status: offline
    Has anybody installed a slide carb on their rs4 3? Does it work or did you have to make any mods?
    How about engine, you guys that has changed over to a no-pull start engine, what motor mounts have you used and does it fit well? My exhaust pipe with stock exhaust manifold rubs against the chassis. Not good.
           Post #: 105
    OFFICIAL RS4 RTR 3 thread!!!!!!!Also type SS and others - 7/7/2003 8:00:21 PM
    gmac4826
    Status: offline
    you shopuld get this pipe and manifold:
    http://www.dynamiterc.com/Products/Detail.aspx?ProductID=DYN6608
    the stock stuff is crap like many other things on the rs4. on the dynamite products page i think the polished one will fit your car.
           Post #: 106
    OFFICIAL RS4 RTR 3 thread!!!!!!!Also type SS and others - 7/7/2003 8:03:18 PM
    Aggdaddy
    Status: offline
    That manifold doesn't look like it will fit a side -ehaust system on the rs4 3.
           Post #: 107
    OFFICIAL RS4 RTR 3 thread!!!!!!!Also type SS and others - 7/7/2003 8:16:21 PM
    gmac4826
    Status: offline
    that is built FOR the side exhaust and the rs4. and all other hpi cars with side exhaust. anyway for your non pull start there si a mount you can buy but i cant seem to find it right now. ill post a link if i do find it.
           Post #: 108
    OFFICIAL RS4 RTR 3 thread!!!!!!!Also type SS and others - 7/7/2003 8:26:52 PM
    Aggdaddy
    Status: offline
    the rs4 3 engine is on the otherside of the chassis as opposed to a previous edition rs4. Look at the link that you posted and visualize the way that that will have to fit. It won't fit onto an rs4 3 chassis. There aren't many if any aftermarket side-exhaust manifolds for the nitro RS4 3 that I have seen.
           Post #: 109
    OFFICIAL RS4 RTR 3 thread!!!!!!!Also type SS and others - 7/7/2003 8:46:26 PM
    Rex2342
    Status: offline
    Aggdaddy is right the Rs4 3 chassis is setup reallt strange compared to alot of others.I've had a few different tuned pipes on mine andthe pressure fitting is alway up side down on the pipe.Get the THS pipe/header set that was designed for the Rs4 3 and you won't be disapointed.I have it on mine and it's the best pipe i've had and if fit right so I didn't have to modifie anything.
    Aggdaddy......
    I have a slide carb on my Rs4 3 SS and I had to buy the slide linkage kit from HPI and I had to turn the carb a little bit to make it work right i'll post a pic in a minute so you can see what I mean.
    I DON"T NEED NO INSTRUCTIONS TO KNOW HOW TO ROCK!!!!!!!
           Post #: 110
    OFFICIAL RS4 RTR 3 thread!!!!!!!Also type SS and others - 7/7/2003 8:51:05 PM
    Aggdaddy
    Status: offline
    [QUOTE]Originally posted by Rex2342
    Aggdaddy......
    [/QUOTE]
    cool .. thanks for the info. Actually I used that little plastic piece that HPI suggested in the manual but I turned my throttle servo around to get a more direct push/pull effect onto the slide carb throttle. But I had to custom bend a piece of piano wire for the brake linkage. Hpi manual sucks in this regard.
    THS pipe header? Is that available through Tower Hobbies?
           Post #: 111
    OFFICIAL RS4 RTR 3 thread!!!!!!!Also type SS and others - 7/7/2003 8:55:39 PM
    Rex2342
    Status: offline
    Yeah the brake linkage sucks but it works...not well...but it works.I was gonna bend mine to make it work better but I have gotten to it yet.The THS pipe/header set is available from tower.I ordered mine from Ebay because tower was taking to long to get them back in stock but they are awesome
           Post #: 112
    OFFICIAL RS4 RTR 3 thread!!!!!!!Also type SS and others - 7/7/2003 8:58:27 PM
    Rex2342
    Status: offline
    Heres the THS setup on mine...
           Post #: 113
    OFFICIAL RS4 RTR 3 thread!!!!!!!Also type SS and others - 7/7/2003 9:19:12 PM
    Aggdaddy
