Aluminum finish?
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Tips & Techniques >> Aluminum finish?
Page: [1]
Login
Aluminum finish? - 3/26/2002 7:13:57 AM
CaptainHook
Status: offline
What is the name of the aluminum finish that some of you guy's apply to your warbirds. I know itis applied by rubbing in by hand. It's what I need for this one.
Click to see fullsize image.
Click for fullsize
       Post #: 1
Aluminum finish? - 3/26/2002 9:48:09 PM
lov2flyrc
Status: offline
PRESTO!
_____________________________
Owner/President: Dreamworks Model Products LLC
www.dreamworksrc.com 386-852-4793
(in reply to CaptainHook)
       Post #: 2
Aluminum finish? - 3/26/2002 10:03:06 PM
blkbird
Status: offline
Hello CHOOK,
If you want a really impressive metal finish on your bird IMO FLITE-METAL is the best. These are REAL SHEETS of .015" aluminum with an adhesive backing. Gives an authentic finish!! Check their website: [url]www.flitemetal.com.[/url] See-ya!!!
ac
Fly man!!!!............Fly!!!!
       Post #: 3
Aluminum finish? - 3/26/2002 10:56:30 PM
Steve Collins
Status: offline
BVM has a new aluminum finishing system which is superior to the two already mentioned. It can be found on their website at:
bvmjets.com
       Post #: 4
Presto and others - 3/27/2002 5:26:13 AM
CaptainHook
Status: offline
I believe presto was the stuff I was thinking of, .015 aluminum a bit heavy at .21# per sq. ft, but sounds neat. I will check into the BVM stuff also. Thanks guys!
Carey
       Post #: 5
Aluminum finish? - 3/28/2002 12:12:41 AM
G.F. Reid
Status: offline
It's possible that you are talking about a product called "Skinny Dip" marketed by IMP. It's an aluminized paste that's actually rubbed onto the surface like a paste wax. I've read that the results look great but that it has to be constantly maintained as it picks up fingerprints and such. They were out of business for quite a while but recently ran across their new website. Evidently, they are back up and running.
       Post #: 6
Aluminum finish? - 4/17/2002 2:57:18 AM
k_sonn
Status: offline
Carey:
I have just finished a top flight .60 P-47 with flite metal. I believe it wieghs less than if I would have painted it. The reasoning behind this is you do not have to prime the surface. All you have to do is prepare the surface the same as if you were painting. So, you get the surface as smooth and perfect as you can, then you draw on the panel lines, and place the flite metal on according to the supplied instructions. The P-47 does not have the engine or radio equipment installed but it does have the retracts installed and it was glassed with 3/4 oz cloth and West Marine epoxy resin. In this configuration it wieghs 6.5 pounds. Here is a picture:
Click for fullsize
       Post #: 7
Aluminum finish? - 4/17/2002 2:57:57 AM
k_sonn
Status: offline
Here is another showing a bit of the detail.
Click for fullsize
       Post #: 8
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.563RCU3
