RE: Another Skymaster Viper    Gallery
Logged in as Guest
    Search This Thread
Printable Version
Skygate CARF, Viperjet - RTF
Seller:  snobird
Details:   $9,600.00   |  6/6/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> RC Jets >> RE: Another Skymaster Viper
Page: <<   < prev  1 [2] 3 4 5 6 7 8 9 10   next >   >>
Login
RE: Another Skymaster Viper - 4/28/2009 8:56 AM
jet time
Score: 120
Last Login: 6/19/2013
Status: online
Ali, the pilots look great! I'll get some more out to you and also find out about the military version. You sure make 'em look good!
Talk to you soon,
Lowell
_____________________________
Lowell Wexler
RC Jets Direct, Fly Eagle, Global Jet Club, Jet Cat
Hide Signatures
(in reply to sideshow)
       Post #: 26
RE: Another Skymaster Viper - 4/28/2009 9:22 AM
jetpilot
Score: 110
Status: online
We finished up Joey Tamez Viper Jet and took it out this weekend for the maiden.
Very uneventful and we were surprised that the gear seemed to work no problem(we have seen some struggle). We used BVM high flow valve and two air tanks. Worked great. One door did manage to depart in flight.
We installed a P200 since we had one available and we used a BVM P200 bypass and a BVM F100F tailpipe I had from a F100. They dropped right in, perfect fit. Very low temps, in the low 4's.
The airplane is very nice, just a bunch of little aggravating issues that are easily corrected.
Couple of things to look out for:
MOST IMPORTANT!! After only 4 flight the wing retaining aluminum sleeves were nearly pulled out of wings. Couple more flights and the wing might have slipped off!!! Wing gap kept growing after each flight.
Wing tubes and stab dowels can slide into wings unevenly. We glued the stab dowels permanent.
Been mentioned here ALOT, but there are many hard points missing in flying surfaces.
Cockpits look great but are made out of some low grade plastic and wont last. Before the first flight they were pretty beat up.
canopy glass very low grade soft plastic
fin missing most of glue inside and main former was detached. We changed to pull pull with solid carbon plate through rudder.
cockpit started deforming in sun
Landing gear mounts are insufficient. One wing had a broken former glued in place. No support at all. We added carbon support braces.
Some of the pro version work was a little sloppy and our white version had white spray paint covering the proversion work done. Fit was good, but whats up with the white pray paint?
Nose gear door cylinder was just glued to fuse wall with no support. Popped off before was even flown.
Winglet holes too big on one side so when tightened they gapped really big.
Tanks create alot of back pressure when installed per plans. Have to pump very slow. Bottom tank want to start balooning.
Intakes glued very sloppy and look nasty(INSIDE). They are very rigid though and feel very solid.
PROS:
plane comes out CG perfect with little to no weight with batteries in nose.
Big and pretty
Wings stabs and fin fit to fuse and front to aft fit perfect. Overall excellent fitment of all parts. Canopy little off.
Nice gear, struts wheels and brakes
BIG!
Flies beautiful and very stable. Very wide envelope.
Breeze to land.
Easy to assemble.
Overall very nice aircraft, would probably fly great even with P120, Joey took off half power and flew there the whole flight. Half power take off climbed out very nice. She needs alot of flap deflection to slow down well for landing.
Hope to get it in the air again this weekend.
Scott
< Message edited by jetpilot -- 4/28/2009 8:16 PM >
Scott Marr
Hide Signatures
       Post #: 27
RE: Another Skymaster Viper - 4/28/2009 10:09 AM
Joe C
Score: 100
Last Login: 6/20/2013
Status: offline
Congrats on the maiden Scott, I flew mine at Cal jets, they are nice jets. Take Care. Joe C!!
BEST IN THE WEST JET RALLY
www.bestinthewestjetrally.com Oct. 16th-20th, 2013
Hide Signatures
(in reply to jetpilot)
       Post #: 28
RE: Another Skymaster Viper - 4/28/2009 12:18 PM
pilot tw
Score: 103
Status: offline
quote:
ORIGINAL: jetpilot
Been mentioned here alot but there are many hard points missing in flying surfaces.
fin missing most of glue inside and main former was detatched. We changed to pull pull with solid carbon plate through rudder.
Landing gear mounts are insufficiant. One wing had a broken fromer glued in place. No support at all. We added carbon support braces.
Nose gear door cylindrer was just glued to fuse wall with no support. Popped of before was even flown.
Intakes glued very sloppy and look nasty. They are very rigid though and feel very solid.
Scott
Hi, Scott
Thank you very much for the review with suggested, I will meeting with my staffs as soon, and we will check out all your points..and I will promise to you for Improve these points ....Thank you again.
Best regards
Anton
< Message edited by pilot tw -- 4/28/2009 12:30 PM >
owner - Skymaster Jet
X-Treme Jets
Hide Signatures
       Post #: 29
RE: Another Skymaster Viper - 4/29/2009 5:54 PM
FalconWings
Score: 121
Status: online
Scott/JT,
Did you had to do any major structural mods, specially for the wing/stab attachment?
I have a friend who asked me to post the question, he is building one right now.
Thanks guys,
David
Buying Jet Legend? Read here: http://www.rcuniverse.com/forum/m_11372496/mpage_1/key_/tm.htm
Hide Signatures
(in reply to pilot tw)
       Post #: 30
RE: Another Skymaster Viper - 5/5/2009 5:55 AM
heraldoboldrin
Score: 100
Last Login: 6/17/2013
Status: offline
Ali
I did 2 flights last weekend with the Viper that i bought from you..
I have to agree with you.. the jet is amazing and i recommended for every pilot and very easy to fly....
Thanks again for everything...
Regards
Heraldo
Click to see fullsize image.
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 31
RE: Another Skymaster Viper - 5/5/2009 7:20 AM
ravill
Score: 125
Last Login: 6/6/2013
Status: offline
OMG the vipers are reproducing!!!
Snakes on a plane!!!
Darn nice airplanes too...
Raf
RAVjets Demo team. All We Do Is Fly.
Hide Signatures
(in reply to heraldoboldrin)
       Post #: 32
RE: Another Skymaster Viper - 5/5/2009 3:31 PM
jclittle
Score: 100
Last Login: 6/9/2013
Status: offline
Scott can you please explain how you repaired this? I've noticed one of mine after 8 flights is loose
Hide Signatures
       Post #: 33
RE: Another Skymaster Viper - 5/5/2009 3:50 PM
jclittle
Score: 100
Status: offline
I would just add a few more points to what Scott has said about the build:
1) Watch your live hinge lines on the flaps and ailerons carefully. Both of mine have "stuck" due to cracks during flight. I've had to cut back the wing surface twice to prevent this. I think air pressure pushes them tight and the control surface catches a small part of the wing surface. Cut back enough skin to prevent this. The plastic used on the live hinge cracks very easy and will stick up just enough to get stuck on the wing skin.
2) Recheck the glue holding the front windshield in place. Mine blew into the fuse on the 8th flight and made the plane very difficult to fly. Upon inspection there was only 1/16" of an inch of windshield holding it in place. The windshield was cut so close to the opening size it just did not have enough surface to glue to the fuse. Sitting out in the sun made it weak and I nearly lost a plane because of it. I have always cut canopies 1/4" more minimum around the edge to make sure enough glue is used.
3) Hysol a piece of 1/4" aircraft ply directly under the existing landing gear plate and use blind nuts instead of wood screws to hold the gear. The wood screws will easily tear out with a hard landing and take the plates out with it.
4) The glue joints holding the main gear doors air cylinders in place are very weak. Put some Hysol around them and they will stay put.
It flies great! I'm sure Anton will make the changes so it flies many times.
Hide Signatures
(in reply to jclittle)
       Post #: 34
RE: Another Skymaster Viper - 5/5/2009 9:29 PM
jetpilot
Score: 110
Status: online
I had to cut out a box surrounding the aluminum sleeve, then I glued in some plywood and sandwiched the sleeve back in. There was very little glue and nothing else holding them in. They had nothing to hold on to except a little of that brittle glue.
Scott
Scott Marr
Hide Signatures
       Post #: 35
RE: Another Skymaster Viper - 5/5/2009 11:50 PM
norbert montenegro
Score: 100
Last Login: 6/19/2012
Status: offline
hi,
jclittle and Scott
You can document with a photograph of the items noted, because I'm building two Vipers and I am interested in these issues
Thanks again for these comments very interesting
Regards
Norbert
http://nmjets.blogspot.com/
Hide Signatures
       Post #: 36
RE: Another Skymaster Viper - 5/6/2009 12:11 AM
jclittle
Score: 100
Status: offline
quote:
ORIGINAL: norbert montenegro
hi,
jclittle and Scott
Regards
Norbert
Norbert - is there something specific you want a photo of? I think the words in the posts are pretty easy to follow. Please let me now.
Hide Signatures
(in reply to norbert montenegro)
       Post #: 37
RE: Another Skymaster Viper - 5/6/2009 2:02 AM
JTs Hobby
Score: 100
Status: offline
some pics
pic one is wing sleeve repair
pic two is carbon plate to reinforce landing gear mount
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 38
RE: Another Skymaster Viper - 5/6/2009 2:04 AM
JTs Hobby
Score: 100
Status: offline
pics
pic one is internal of rudder showing no glue and former not attached
pic two is fitment of bvm bypass and tailpipe
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to JTs Hobby)
       Post #: 39
RE: Another Skymaster Viper - 5/6/2009 2:10 AM
JTs Hobby
Score: 100
Status: offline
pic
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 40
RE: Another Skymaster Viper - 5/6/2009 2:20 AM
schroedm
Score: 103
Status: offline
Nice. Make sure you glue the ventral fins in properly. You'll love getting this jet looooow!
Click for fullsize
Hide Signatures
       Post #: 41
RE: Another Skymaster Viper - 5/6/2009 3:11 AM
norbert montenegro
Score: 100
Status: offline
Excuse my English jclittle is not very good and it's hard for me to understand certain techniques,but with the photographers of JTs Hobby I understand the two main problems. Apply the reforms in the model quickly, you step photos of my work at the moment.
Regards
Norbert
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 42
RE: Another Skymaster Viper - 5/6/2009 4:42 AM
jclittle
Score: 100
Status: offline
Norbert - nice building! In case anyone is wondering if the wing attach mod needs to be done, here is a photo of the tab and all the glue that was holding it in place. It was loose and probably would have pulled out in another flight or two.
Click for fullsize
Hide Signatures
       Post #: 43
RE: Another Skymaster Viper - 5/6/2009 7:07 AM
heraldoboldrin
Score: 100
Status: offline
First Flight...
http://www.youtube.com/watch?v=Uo96Cv3zZxs
Regards
Heraldo
Hide Signatures
       Post #: 44
RE: Another Skymaster Viper - 5/6/2009 7:33 AM
erbroens
Score: 105
Status: online
Well done, congrats!
SM is making really nice stuff..
Hide Signatures
       Post #: 45
RE: Another Skymaster Viper - 5/7/2009 7:01 AM
RonLongAZ
Score: 120
Last Login: 3/27/2013
Status: offline
very nice
Ron
Hide Signatures
(in reply to erbroens)
       Post #: 46
RE: Another Skymaster Viper - 5/9/2009 12:19 AM
JetsRC
Score: 100
Status: offline
Congrats Heraldo... Nice flying...
JetsRC / Skymaster Jets / Xtreme Jets / Jet Central
www.jetsrc.com
Hide Signatures
(in reply to RonLongAZ)
       Post #: 47
RE: Another Skymaster Viper - 5/9/2009 2:01 AM
norbert montenegro
Score: 100
Status: offline
Hola amigos
Thank you very much for the pictures Jclittle, it is now clear.This weekend, will make corrections because the viper is almost finished, maybe next week is the premiere.
Regards
Saludos
Norbert
Hide Signatures
       Post #: 48
RE: Another Skymaster Viper - 5/18/2009 3:49 PM
jclittle
Score: 100
Status: offline
I've heard of issues with the vertical stab coming loose; it’s understandable because it’s held in place with only one clamp on the main carbon fiber rod.  There is nothing supporting the area towards the leading edge.  So I removed the stab and cut a hole through the skin on the bottom of the stab just in front of the 2nd carbon rod.  I glued in a thick hardwood block that fit the cut out with hysol.  After the hysol set, I temporarily placed the stab back on the fuse, then from inside the fuse I drilled into the hardwood block.  Then removing the stab I tapped the hole for a 4-40 hex screw.  Then you can place the stab back on the fuse, clamp down the main screw, then install a 4-40 bolt into the wood block - its solid now and should not come loose or have any movement in the air.
< Message edited by jclittle -- 5/18/2009 6:00 PM >
Hide Signatures
(in reply to jet time)
       Post #: 49
RE: Another Skymaster Viper - 5/18/2009 8:13 PM
RCI/Skymaster
Score: 100
Last Login: 4/20/2010
Status: offline
I did the same to my Viper vertical and it works great. I also drilled a small hole on the underside of my stab so I could access the clamp bolt.
I needed a way to remove mine for transport reasons and this setup works great.
Jeff Tolomeo
RCI/Skymaster-USA/BVM/JETCAT-USA/SMART-FLY
Hide Signatures
       Post #: 50
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.063RCU1
