RE: Another Skymaster Viper    Gallery
Logged in as Guest
    Search This Thread
Printable Version
AMT Netherlands Pegasus HP - RTF
Seller:  thunderbolt-RCU
Details:   $3,000.00   |  5/18/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> RC Jets >> RE: Another Skymaster Viper
Page: <<   < prev  59 60 61 62 63 64 [65] 66 67 68   next >   >>
Login
RE: Another Skymaster Viper - 10/23/2010 5:55 AM
johnzqh
Score: 100
Last Login: 5/21/2013
Status: offline
Hi Rainer
Sorry for the trouble.We already checked out you got the wrong nose retract.We already asked our supplier Mr. Li Kai to send new nose retract.Please send your address and phone number information to us via e-mail.Meanwhile,please disassemble the current nose retract and sedn back to Mr. Li Kai.I sent Mr. Li's address to you.Please check your mail.
Best regards
John
Skymaster Jet
Hide Signatures
(in reply to RamsesCH)
       Post #: 1601
RE: Another Skymaster Viper - 10/23/2010 10:27 PM
3DAV8R
Score: 100
Last Login: 10/26/2012
Status: offline
Rudder Question:
I know that some of you have supported the hinges with brass tubing, Duncan I believe. Take a look a what I'm thinking of and let me know what you think. The brass tube will be notched before being inserted into the fin. Also, do you think any square supports will be needed on the fin where the hinge point will go in ? Any suggestions/help will be fantastic.
Steve
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
_____________________________
Cash, VISA, MC, AMEX, what ever it takes !
Hide Signatures
(in reply to johnzqh)
       Post #: 1602
RE: Another Skymaster Viper - 10/24/2010 1:58 AM
ww2birds
Score: 105
Last Login: 5/22/2013
Status: offline
I have done that technique before with some warbirds having similar control surface geometry. It is a nice way to support the exposed part of the shaft that sticks out.
You can also use the Robart hinge point pockets to achieve the same effect, the advantage there is that the rudder surface is removable .. a nice bonus. But this is good thinking on your part...
See: http://www.robart.com/store/control-hinges?page=1
Dave
Hide Signatures
(in reply to 3DAV8R)
       Post #: 1603
RE: Another Skymaster Viper - 10/24/2010 6:02 AM
Selleri
Score: 100
Status: offline
Mine looked something like this and held up in all my flights.
Sverrir G. - Icelandic Volcano Yeti
Hide Signatures
(in reply to ww2birds)
       Post #: 1604
RE: Another Skymaster Viper - 10/24/2010 7:09 AM
3DAV8R
Score: 100
Status: offline
Looks like you put just a small flare at the end of the tube to get it a bit closer to the pivot point, great idea, just what I had in mind.
Steve
Hide Signatures
(in reply to Selleri)
       Post #: 1605
RE: Another Skymaster Viper - 10/24/2010 7:29 PM
Selleri
Score: 100
Status: offline
Yes, worked very well.
Hide Signatures
       Post #: 1606
RE: Another Skymaster Viper - 10/24/2010 10:58 PM
Duncan
Score: 110
Last Login: 4/13/2013
Status: offline
Steve, just square off one end as mentioned and they will be perfect. I roughed up the brass to give the hysol something to key into.
Cheers
Duncan
Aero-creative - Vinyl Design & Application
www.aero-creative.com
Hide Signatures
       Post #: 1607
RE: Another Skymaster Viper - 10/25/2010 4:26 AM
3DAV8R
Score: 100
Status: offline
Selleri, Duncan, thank you for the info on the hinges. Duncan, I used your idea on the ram's for the main gear doors, big difference. I now have very good mechanical advantage on the doors, I also did something similar on the nose gear door. I will post a few pics soon. Thanks again.
Steve
Hide Signatures
(in reply to Duncan)
       Post #: 1608
RE: Another Skymaster Viper - 10/26/2010 2:05 AM
3DAV8R
Score: 100
Status: offline
Has anybody found that they had to relieve the underside of the wing skin so as to get a bit more aileron throw ? (down aileron)
Steve
Hide Signatures
       Post #: 1609
RE: Another Skymaster Viper - 10/26/2010 5:33 AM
Selleri
Score: 100
Status: offline
Steve check the counterbalance and the paint line(were the paint stops on the vipers) had minor conflicts there with mine but not on the wingskin.
Hide Signatures
       Post #: 1610
RE: Another Skymaster Viper - 11/2/2010 8:02 PM
Jim Cattanach
Score: 100
Last Login: 5/23/2013
Status: online
After losing my first large Viper to some electric power lines a while back, I got the offer of another unbuilt early version kit. Maidened it today. I had forgotten how relaxing it was to fly. I dialled in quarter inch of crow. It is amazing how slow it will land. Using a Wren 160. Dry weight is 39Lbs.
Must try to take better care of this one.
JET FLYING:- Resistance is futile. You will be assimilated.
Hide Signatures
       Post #: 1611
RE: Another Skymaster Viper - 11/12/2010 2:46 AM
zl1wn
Score: 100
Last Login: 4/11/2013
Status: offline
I am just finishing setting up my large Viperejet and have run into a problem with the retracts.
When the wheel are down, the air pressure is very slowly decreasing, so there must be a small leak.
However when the wheels are in the up position, the air pressure drops very quickly, so there is quite a large leak.
Ideas please on how to find the leak/s and fix it, if it is in the cylinders on the wheels how do I stop them leaking?
Ross
Hide Signatures
(in reply to Jim Cattanach)
       Post #: 1612
RE: Another Skymaster Viper - 11/12/2010 3:30 AM
Springbok Flyer
Score: 100
Status: offline
Mate,
Take a pair of pinchers and bloke one airline at one point at a time. Obviously you only need to concentrate, either on the up or the down side of the system at a time. However, don't forget to check the filler line too. Once you've isolated the leaking component, you can then set out to solve the problem.
But, don't be surprised to find more than one leak.................
Cheers
Jan
''''It is always pilot error.''''
Hide Signatures
(in reply to zl1wn)
       Post #: 1613
RE: Another Skymaster Viper - 11/12/2010 4:13 AM
zl1wn
Score: 100
Status: offline
Jan,
Thanks for the comments, yes I have tried that it is in the up part of the left wing retract.
Now how do I fix the leak in that cylinder.
Ross
Queensland, isn't that where NFL players like dogs????
Hide Signatures
(in reply to Springbok Flyer)
       Post #: 1614
RE: Another Skymaster Viper - 11/12/2010 7:06 AM
Springbok Flyer
Score: 100
Status: offline
Mate,
If you know it is a cylinder that leak, just replace it.
Cheers
Jan
Hide Signatures
(in reply to zl1wn)
       Post #: 1615
RE: Another Skymaster Viper - 11/12/2010 11:31 AM
Duncan
Score: 110
Status: offline
The nose cylinder leaked on my viper. I used a syringe to put some BVM lube into the cylinder and worked it in and out for a while. It seemed to bed the o ring in and fixed the leak.
Duncan
Hide Signatures
       Post #: 1616
RE: Another Skymaster Viper - 11/12/2010 4:16 PM
erbroens
Score: 105
Status: offline
Same problem here. but as I don´t like pneumatics I simply got rid of of them and installed servos for actuating the gear doors. Pity this this was a pro version, with the pistons installed... oh fezes.
Enrique
Hide Signatures
       Post #: 1617
RE: Another Skymaster Viper - 11/12/2010 6:54 PM
Jim Cattanach
Score: 100
Status: online
quote:
ORIGINAL: erbroens
Enrique
I think it is the retract cylinder that is giving problems, not a gear door cylinder.
Solution is to inject some silicon grease into the cylinder, work it back & forth, then leave it overnight & if that doesn't work, strip down the cylinder, check the O ring for damage & replace it with a new one from a hydraulics shop.
Hide Signatures
(in reply to erbroens)
       Post #: 1618
RE: Another Skymaster Viper - 11/12/2010 7:26 PM
erbroens
Score: 105
Status: offline
Ok, thanks.
I tried this already but even so two of three gear door cilinders didn´t worked as required and jammed the gear during the test.
It was faster to put the servos rather than waiting new pistons from China!
Hide Signatures
       Post #: 1619
RE: Another Skymaster Viper - 11/12/2010 7:35 PM
Jim Cattanach
Score: 100
Status: online
quote:
ORIGINAL: zl1wn
Jan,
Ross
My last answer was for your problem.
Hide Signatures
(in reply to zl1wn)
       Post #: 1620
RE: Another Skymaster Viper - 11/22/2010 7:48 PM
3DAV8R
Score: 100
Status: offline
Quick CG question: In the instructions it mentions 220mm-250mm from the leading edge at the root. 1st, Leading edge at the root I would assume is where the wing panel joins the fuselage, aft from that point? 2ed, what CG has everybody found that works well?
Thanks, Steve
Click for fullsize
Hide Signatures
       Post #: 1621
RE: Another Skymaster Viper - 11/23/2010 1:05 AM
NightSwan
Score: 100
Last Login: 4/5/2013
Status: offline
I've got it balanced on the wing-tube, nose slightly down.
(Easy to balance as well, just slide the wings off a bit and loop a string around the wingtube)
:eek:
Hide Signatures
       Post #: 1622
RE: Another Skymaster Viper - 1/15/2011 10:05 PM
i3dm
Score: 100
Status: offline
Hey guys,
WHats the recommended CG for the SM big viper ? the manual calls for 220-250mm..
thanks.
www.liorzahavi.com
www.youtube.com/i3dm
Hide Signatures
(in reply to Ali)
       Post #: 1623
RE: Another Skymaster Viper - 1/16/2011 2:18 PM
i3dm
Score: 100
Status: offline
Im about to maiden my buddy's large SM viper with 160SX. throws are per the manual and CG at about 225mm.
Any special tips or do's and dont's for the maiden ?
Thanks.
www.liorzahavi.com
Hide Signatures
(in reply to sideshow)
       Post #: 1624
RE: Another Skymaster Viper - 1/16/2011 2:58 PM
Duncan
Score: 110
Status: offline
I'm pretty sure the aileron throws where on the low side as per the manual . Rudder needs increasing to 65mm each way as well.
Hide Signatures
(in reply to i3dm)
       Post #: 1625
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.625RCU1
