Saito 100 crank shaft size
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Glow Engines >> Saito 100 crank shaft size
Page: [1]
Login
Saito 100 crank shaft size - 3/26/2002 8:28:28 AM
Blackie
Status: offline
I ordered a Tru Turn aluminum spinner from tower hobbies along with an adapter kit and the adapter is to small to fit the shaft threads. When I originally placed the order I ordered what the spec called for and was labeled Saito 100. I called TH and spoke with a rep, explained the problem and she replied that the part I had was what Saito sent them to be the right size, so she sent out another part with the same number and I mentioned that it might also be to small, she replied you may be right but this is what her specs called for and that it could be machined wrong.
I received the new part today and guess what its the same as the first one. My question is does anyone know what TruTurn adapter kit # I should order or what size the shaft threads are for my Saito FA 100 ?
Edit in: the kit part number I have now is TT-0717-A
Randy
_____________________________
Please visit my web site below.
       Post #: 1
Saito 100 crank shaft size - 3/26/2002 10:44:09 AM
Mikeswlee
Status: offline
Saito uses metric system and 100 has M8x1.25 thread.
Below is what I found from [url]www.horizonhobby.com[/url]
Saito FA-100 Specifications
Bore: 29.0 mm
Stroke: 26.0 mm
Displacement: 1.0 cu. in. (17.1cc)
Weight w/o muffler: 19.2 oz
Weight w/ muffler: 20.8 oz (550g)
Cylinder: AAC
Crank Thread: 8x1.25mm
Propeller: APC 14x8
RPM: 15% Fuel, 2100-9300
HP: 1.8
Fuel: Cool Power 30% Heli Fuel
Towerhobbies has one that fits.
LXNV04 Tru Turn Double Adapter Kit Saito 1.20-3.25
They got wrong information on their site.
Seems this is what you received.
LXNV03 Tru Turn Double Jam Adapter Kit Saito
This kit is for 50~91 not 50~100.
FYI,
FA50~91: M7x1
FA100~180: M8x1.25
Be careful, there are two types of thread per each dia. For example, M8 has 1.25(coarse) and 1.00(fine) and Saito uses coarse one.
YS 4 cycle uses M-fine thread and OS 4 cycle uses UNF(inch system fine) so none of them can share nuts.
< Message edited by Mikeswlee -- Mar 26 2002 6:21AM >
(in reply to Blackie)
       Post #: 2
Saito 100 crank shaft size - 3/26/2002 4:30:11 PM
Blackie
Status: offline
Great!
Thanks a bunch Mikeswlee
Randy
       Post #: 3
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.844RCU3
