can773
AB, CANADA Status: offline
[QUOTE]Originally posted by Crash King Also it is missing badly, I think detonation, but not sure. I hate to run it in its current state. [/QUOTE] This sounds of low pressure or no pressure. Replace or clean check valve, replace tank and all lines. Also remember that the low end is air bleed, so out is lean and in is rich. One other point at idle (<2500 rpm) the engine does not rely on pressure to feed itself, only above this does the fuel start to become injected, if running right at idle or close anyways but above idle it goes bad then you likely have a pressure problem. It will behave lean if you have low pressure. Do the simple things first, valves, plugs, check valve, tank, lines etc. Only after all the has been eliminated dig into the motor. I have too many times seen people to be told to rip the reg apart only to make it worse and in the end discover that their check valve was bad Cloudniner Toward the prop
_____________________________
Chad Northeast
