Crash King
Joined: 12/18/2001 From: Dallas, TX, USA Status: offline
Went to the field this am to try the above mentioned. 1) I notice at high RPM (full Throttle) the engine will not hold a steady RPM. It will hit 10200, 10180 then drop to 9800 then back to 9990 and back up to 10200 again. 2) When idling at low rpm it will drop down to 1990, 2K, 2150, 2300, 2480 etc. Again, It will never hold an rpm for any amount of time. I have richened it up to the point it will die, and it still surges. Per the instructions and YS Power website this should indicate a lean condition. However when I try and transition to full throttle it just loads up and dies. Too Rich.! 3) I have played with the regulator and have moved it in a complete turn in and out. I will retune the top end and then retune the low end. In between. I flew 2 tanks today in between dead sticks and surging RPM. The engine in its current condition will barely get the Tiger off the runrway, it takes a good 50 feet to get airborne. 4) BTW checked the valves (using a 1$ bill) and the gap looks good. 5) The only reason I have stuck with it is YS is closed until next week, Might as well work on it until I ship it out,
_____________________________
Thanks, Crash
