jeffs555
Mike, The best LiPoly for the Feda/DragonFly/Hummingbird , is currently the E-tec 1200mAh two cell packs. You should be able to fly about 15 to 20 minutes. You will also need a LiPoly charger. The main problem now is going to be finding somewhere that has the battery packs and chargers in stock. Everywhere I check seems to be out of stock. To get the shortest charging times you need a charger that can charge at the capacity of the pack, so for the E-tec 1200mAh, you will want a charger with a 1200mA setting. I don't have any recommendation for the charger, but [url]www.b-p-p.com[/url] seems to have a very good selection of chargers and battery packs, if only they could keep them in stock. For most of the chargers, you will also need a DC wall transformer that will supply about 12 to 15 volts at around 1.5 amps. Jeff ps. The LiPoly packs are so light that you will have to move them very far forward to balance the heli.
