RE: Fead Dragonfly Li-Poly?
Tower Hobbies
Logged in as Guest
  Printable Version
Miniature Aircraft USA Ion-X - RTF
Seller:  1surfer
Details:   $5,000.00   |  10/5/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Helicopters >> Electric RC Helis >> RE: Fead Dragonfly Li-Poly?
Page: <<   < prev  1 [2]
Login
RE: Fead Dragonfly Li-Poly? - 9/24/2003 10:22:08 PM
kenru
Status: offline
Yes. I had to move the Li-Polys a little forward to maintain CG. Work out well however. Set at that angle (which it just naturally falls into), the batteries tuck nicely under the canopy. Reducing the weight of the heli also makes the bird a little more responsive and easier to fly.
I am using one of the little cheepie chargers. I couldn't find the exact one but there are several choices available from http://www.hobby-lobby.com/chargers_lipoly.htm, http://www.b-p-p.com/apache2.htmor http://www.helihobby.com/html/batteries.html
(in reply to mikefoy6)
       Post #: 26
RE: Fead Dragonfly Li-Poly? - 9/24/2003 11:10:54 PM
jeffs555
Status: offline
Here is another charger to consider.
http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXCTZ5&P=FR
http://www.hobbico.com/chargers/hcap0290.html
It is only $50, and charges Nicad, NIMH, and LiPoly. It has two separate outputs, so will charge 2 different packs at a time. It is a field charger, so you will need a 12 or 15 volt power supply to use it at home, but most of the cheaper Lithium only chargers also need a separate power supply. I don't have one, but if I were buying one now, that is what I would get. Someone who has one may have a different opinion, but I have seen several good reports.
Jeff
< Message edited by jeffs555 -- 9/24/2003 11:15:10 PM >
       Post #: 27
RE: Fead Dragonfly Li-Poly? - 9/25/2003 10:31:43 PM
Gazoo
Status: offline
Don't forget about lightflightrc for battereis and chargers
http://www.lightflightrc.com/
This is how I have mine mounted and it balances perfectly with an Acro280BB motor. Just use rubber bands to hold them. Some people use velcro. There are other ways. Most important, I found the best way to learn was to experiment.
http://www.ldsource.com/hummingbird/battery.htm
(in reply to jeffs555)
       Post #: 28
RE: Fead Dragonfly Li-Poly? - 9/25/2003 10:39:36 PM
jarose
Status: offline
Thanks Jeff for the info.. I ordered two 2-cell e-tech li-poly battieries and charger from helihobby.com . When I practice it is so frustrating because I only have maybe 7 minutes I need more time or I will try to rush it. Thanks again this thread has been very helpful.
< Message edited by jarose -- 9/25/2003 10:39:57 PM >
       Post #: 29
RE: Fead Dragonfly Li-Poly? - 9/28/2003 4:59:04 PM
Intertracker
Status: offline
What's the tube you have strapped to one of the skids, Gazoo?
(in reply to Gazoo)
       Post #: 30
RE: Fead Dragonfly Li-Poly? - 9/29/2003 4:53:08 AM
Gazoo
Status: offline
The tube is a deans micro antenna. Works great!
(in reply to Intertracker)
       Post #: 31
RE: Fead Dragonfly Li-Poly? - 10/8/2003 7:54:10 AM
engwerda
Status: offline
what about 3 e-tech cells? the only charger i have supports 3 cells only i think.
-Josh
       Post #: 32
RE: Fead Dragonfly Li-Poly? - 10/8/2003 8:36:33 AM
Banished Outside
Status: offline
Just seen a 4 cell li-poly 2 sreies, 2 parallel
8v 2400mA at the same weight of the stock battery pack.
I know part of the extra time gained from is supposedly the saving in weight, but has anyone tried one of these packs?
http://www.eflightdesigns.com/cgi-bin/products.cgi?CAT=19
(in reply to engwerda)
       Post #: 33
RE: Fead Dragonfly Li-Poly? - 10/11/2003 1:39:35 AM
Intertracker
Status: offline
Thanks Gazoo. I had thought it might be a battery charge indicator. Is there any advantage over the usual wire antenna do you think?
(in reply to Gazoo)
       Post #: 34
RE: RE: Fead Dragonfly Li-Poly? - 2/9/2004 6:17:44 PM
milton elliott
Status: offline
hi i have got a 7 cell 8.4v ni-mh for a dragonfly does anyone know how long you have to charge them for.
THANKS .....oliver
       Post #: 35
Jump to:
Google
Search | Marketplace |
