Fead Dragonfly Li-Poly?
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Helicopters >> Electric RC Helis >> Fead Dragonfly Li-Poly?
Page: [1] 2   next >   >>
Login
Fead Dragonfly Li-Poly? - 6/18/2003 5:35:38 AM
mikefoy6
Status: offline
hey everyone
I recently got a dragonfly and am getting quite good with it. The only negative thing is that the stock batteries die with 5 minutes of flying. i have ready li-polys are the way to go. My question is, what exactly i would need to buy to make li-polys work in my dragonfly? I am still quite new to this so any suggestions on what to get, and where to get it would be appreciated.
thanks
mike foy
       Post #: 1
Fead Dragonfly Li-Poly? - 6/18/2003 6:09:42 AM
jeffs555
Status: offline
Mike,
The best LiPoly for the Feda/DragonFly/Hummingbird , is currently the E-tec 1200mAh two cell packs. You should be able to fly about 15 to 20 minutes. You will also need a LiPoly charger. The main problem now is going to be finding somewhere that has the battery packs and chargers in stock. Everywhere I check seems to be out of stock. To get the shortest charging times you need a charger that can charge at the capacity of the pack, so for the E-tec 1200mAh, you will want a charger with a 1200mA setting. I don't have any recommendation for the charger, but [url]www.b-p-p.com[/url] seems to have a very good selection of chargers and battery packs, if only they could keep them in stock. For most of the chargers, you will also need a DC wall transformer that will supply about 12 to 15 volts at around 1.5 amps.
Jeff
ps. The LiPoly packs are so light that you will have to move them very far forward to balance the heli.
(in reply to mikefoy6)
       Post #: 2
Feda Dragon fly batteries - 6/20/2003 7:08:27 AM
cantdeleteaccount
Status: offline
What would happen if you used the same amount of lithiom cells that are in the pack? would it bee too much power? also how in the world did u get you dragonfly to fly???? lol Ive had mine four weeks and have endless problems.
       Post #: 3
Fead Dragonfly Li-Poly? - 6/20/2003 8:43:49 AM
Zflyer
Status: offline
Microman, Ya didn't get that Bird up yet?, What's happening, I know it's not easy but you should be making some progress
_____________________________
Should Your Heli Crash or be captured the Secretary will deny all Knowledge
       Post #: 4
Fead Dragonfly Li-Poly? - 6/20/2003 9:04:30 AM
cantdeleteaccount
Status: offline
Na didn't get it up yet. I got the tail rotor but i got the wrong gear so i glued it on its only a temporary solution but today as i spooled up i found out my tail rotor was blowing the wrong way. I am bout to give up lol there is no end to the problems i have also interfierence on my pcm radio and it spooled up with out my control and rolled along the grass in my yard and i had to go chase after it thank god nothing broke.
       Post #: 5
Fead Dragonfly Li-Poly? - 6/20/2003 1:33:08 PM
Dodgey99
Status: offline
with regards to lipos - you can't use the same number of cells as lipos cells are a much higher voltage than Ni-MH cells. 1 ni-mh cell - 1.2v ..... 1 li-po cell = 4v ish.
Trust me, a FP heli needs a 2 cell lipo. I've tried it. Tonnes of performance and 20 minutes flight times.
       Post #: 6
Fead Dragonfly Li-Poly? - 6/22/2003 11:56:25 PM
mikefoy6
Status: offline
i was very surprised to find out how easy my dragonfly was to fly. i fly it in my 2 car garage and can take off and land on small boxes that i scatter around the garage floor. i have taken it outside a couple of times now( in zero wind) with great results. another gripe that i have is the motors burning out so quickly. i have been flying about 2 months and i am on my third main and second tail motors(i have a stockpile of replacements though). i took off the plastic tubing from the main shaft(helihobby mod) and also added the blue swash plate(very expensive) from hellihobby. this thing flys like a dream now, but for ONLY FIVE MINUTES! hopefully lipolys will fix that though.
       Post #: 7
Fead Dragonfly Li-Poly? - 6/23/2003 12:58:55 AM
Dodgey99
Status: offline
Not hopefully, Li-Pos WILL fix the flight times :-)
       Post #: 8
parts - 6/23/2003 8:08:45 AM
cantdeleteaccount
Status: offline
Does any one know where to get the official feda dragonfly parts!?!?!?!?!?! I have been buying parts from the centruy humming bird and fileing down the part to fit on my dragonfly and then gluing them on because i cant find a place to get the official feda parts. Any help on where to get them would be greatly appreciated.
       Post #: 9
Fead Dragonfly Li-Poly? - 6/23/2003 8:27:48 AM
jeffs555
Status: offline
I don't know of a source in the US, but this place ships worldwide, and only charges $5 shipping to the US. I haven't ordered from him, but he has been posting on the various heli boards for a while, and seems to know his stuff.
http://www.amersfoortairport.com/indexe.html
< Message edited by jeffs555 -- Jun 23 2003 3:37AM >
       Post #: 10
Fead Dragonfly Li-Poly? - 6/24/2003 5:39:15 PM
CrashingDutchman
Status: offline
Jefs555,
Yep, that is correct. We sell parts for the Feda as well as for the Skylark.
Payments accepted through PayPal. Most items are stock. If a certain item is not available, we can have it stock within 2 or 3 days.
Regards,
Jan-Dirk Schuitemaker
The Netherlands
       Post #: 11
Fead Dragonfly Li-Poly? - 6/25/2003 4:55:26 AM
mikefoy6
Status: offline
i get all my extra parts for my dragonfly from helihobby.com. they are great to deal with and have fast shipping. they dont have any offical feda parts, but i just get the hummingbird parts. i have not had a problem at all making them fit on my dragonfly.
       Post #: 12
Another source for parts - 6/25/2003 8:16:35 PM
riderclimber
Status: offline
I bought my dragonfly from [URL=http://www.rc-expert.com]www.rc-expert.com[/URL] . They have been pretty helpful via email for support, and shipping was fast, even though it comes from Hong Kong. They seem to carry all the dragonfly stock parts.
I've had mine for about a month, and I think I damaged the batteries by overcharging. I left them both plugged in overnight on accident and now the main rotor power has gone down the tubes. It will only lift about 3 inches off the ground and that's when the batts are fresh. Has anyone seen this before, before I order a new set of batteries? Could there be another problem?
-brian
       Post #: 13
Fead Dragonfly Li-Poly? - 6/26/2003 11:58:22 AM
CrashingDutchman
Status: offline
Riderclimber,
Most likely you have damaged your batteries. We sell the batteries for US$ 13.00/piece, so not a big investment you have to do to get your heli up again. Wordwide shipping, like jefs555 said, is US$ 5,00.
Regards,
(see link to website below - www button).
< Message edited by jandirks -- Jun 26 2003 7:12AM >
       Post #: 14
Fead Dragonfly Li-Poly? - 6/26/2003 8:59:08 PM
kenru
Status: offline
riderclimber,
[URL=http://www.heli-world.com/Merchant2/merchant.mvc?Screen=PROD&Store_Code=H&Product_Code=CNE050]Century Heli[/URL] has the batteries for $11.95 and I'm sure [URL=http://www.helihobby.com/html/hummingbird_helicopter.html]Heli-Hoby[/URL] has them too. Both are quite close to you and should be faster than ordering off-shore. 1200 mAh Li-Poly batteries make a great upgrade (20 minutes flying on 1 charge).
An easy test for a cooked battery would be to 1) note how high or well the heli flies when the batteries are fresh off of the charger. Then 2) recharge the batteries, take them off of the charger when done and let them sit for a day or so. Try flying the heli now. Is the performance substantially worse? If so, it sounds like a shorted cell in the pack. You can do the same test using a volt meter (VOM, DVM etc.) if you have that available.
The stock motors have be known to be week points. Many people have found big performance gains by changing to GWS370 or Speed 300's and a 9-tooth pinion. Heli-Hobb
