SCALECRAFT
Joined: 1/7/2002 From: MONTEBELLO, CA, USA Status: offline
I have the 69" BT P-51D. It is true to scale. All the dimensions were taken from the P-51 D at the museum in Duxford. It even has the Laminar flow wing, which makes for minimal gear clearance. Still most immpressive for around $225-250. Epoxy glass fuse, Alum spinner ,bk plate, vac form canopy, drop tanks, glass cowl, glass scoop, plans, laser wing ribs. Air retracts around $300.00 I think. The Fiberclassics is in a class of its own. Its all scale detailed 100% composite. Even has the offset Vstab. It comes in silver. It is also over $2,000 new for basic airframe. Ofcourse, you can make a Taylor look just like a F-classic for a lot less. My 2
