wled123
Joined: 3/20/2002 From: VIRGINIA, VA, USA Status: offline
Don't waste your time on those fancy airfoils. Without going into airfoil theory, L/D curves and Reynolds numbers, go for a standard symmetrical airfoil with about a 12% to 15% thickness ratio, hence a NACA 0012 thru NACA 0015. Easy to cut a foam core or build up from ribs/caps. If you are looking for something easy to stall (i.e. snap roll), go with the thinner airfoil and sharpen the leading edge, you pay for it with higher stall speeds. For good landing characteristics (i.e. GP Ultrasports), go with the thicker airfoil and nice blunt/round leading edges. Something else that is typically done is go with a 12% at the root and 15% at the tip to prevent tip stalling. And then there is washout, but don't worry about that for now.
