hauckf
AL, USA Status: offline
Juice Man: I followed your link to your previous thread and found some mis-information. The only manufacturer that I have found that blends by weight is Byron (not Morgan). Since oil (both synthetic and castor) is heavier (denser, actually) than methanol, blending by weight results in less oil in a gallon than blending by volume using the same percentages. The same is true of nitro; it is also heavier than methanol. Bottom line, Byron's Premium Sport 20% oil (castor/syn), 10% nitro fuel actually contains about 17.2% oil and 7.5% nitro by volume, not 20% oil and 10% nitro as you might expect. All the other manufacturers I checked, Morgan, PowerMaster, Red Max, Wildcat, Cooper's, and S&W claim that they blend by volume , and I have no reason to doubt it.
