RE: AQUACRAFT'S NEW MISS VEGAS U-18    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Boats >> Speed - RC Nitro Boats >> RE: AQUACRAFT'S NEW MISS VEGAS U-18 Page: <<   < prev  4 5 6 7 [8] 9 10 11 12 13   next >   >>
Login
RE: AQUACRAFT'S NEW MISS VEGAS U-18 - 10/7/2009 9:55 PM
JLB7569
Score: 100
Last Login: 5/23/2013
Status: offline
Hello, I have some pictures of it posted here in the photo gallery.
Hide Signatures
(in reply to TrEsPaSS)
       Post #: 176
RE: AQUACRAFT'S NEW MISS VEGAS U-18 - 10/7/2009 9:57 PM
JLB7569
Score: 100
Status: offline
Hello, I have had mine run a consistant 43mph on GPS.
Hide Signatures
(in reply to srt10)
       Post #: 177
RE: AQUACRAFT'S NEW MISS VEGAS U-18 - 10/8/2009 7:58 AM
Jerry Dunlap
Score: 105
Status: offline
quote:
ORIGINAL: sleepy306
This boat is such an improvement over the first boat. So far, the only upgrades I have done are grim turn fin and CMDi balanced and sharpened octura y 535. I gps'd the boat (unfortunately no video) with 60% nitro and it ran 43.5 mph. At that speed, the boat gets a bit flighty and a handfull to pilot. I don't know if I should give the strut a degree or 2 of down angle to lower the nose or lower the strut. The strut is set as high as the stock setting allows and has 0 degree angle.
I can't see how the original miss vegas can compete with this boat stock for stock in an rtr race.
I stuck 3 oz. of lead on the front of the boat on the inside sponson walls. This seems to help keep the boat running more stable at top speed. I also made a new turn fin bracket from aluminum L material and lowered the Grim Fin. In rough water conditions, this helps keep the right sponson from lifting in a high speed turn.
JD
Hide Signatures
(in reply to sleepy306)
       Post #: 178
RE: AQUACRAFT'S NEW MISS VEGAS U-18 - 10/13/2009 7:08 AM
coyv10
Score: 102
Last Login: 5/22/2013
Status: offline
Info needed... I have the duece and I have converted it to the .32 and it runs great. My question is will the stock pipe work with the .32? because the mac pipe is very loud
Hide Signatures
(in reply to Jerry Dunlap)
       Post #: 179
RE: AQUACRAFT'S NEW MISS VEGAS U-18 - 10/13/2009 10:39 AM
Glenn Quarles
Score: 100
Last Login: 9/19/2012
Status: offline
Coy, give it a try...I have done some testing with it on a .21 and it works OK.
Glenn
_____________________________
Glenn Quarles
Owner Novarossi of America
Hide Signatures
(in reply to coyv10)
       Post #: 180
RE: AQUACRAFT'S NEW MISS VEGAS U-18 - 10/13/2009 9:32 PM
coyv10
Score: 102
Status: offline
Cool will try it and get back to you, coimg to Lubbock and time soon?
Hide Signatures
(in reply to Glenn Quarles)
       Post #: 181
RE: AQUACRAFT'S NEW MISS VEGAS U-18 - 10/17/2009 10:05 AM
TrEsPaSS
Score: 100
Last Login: 5/6/2012
Status: offline
quote:
ORIGINAL: coyv10
coy, I would definetly not run the stock pipe if you want performance, try a Macs 2340 (or a 2343 which has a 15degree up-angle) header with a 1328 muffled pipe (not as loud). Start by taking a 1/2 inch off each then cut small increments off until you are happy with the performance. You will need to cut out the wood pipe mount (leave 1/8" on hull floor) and trim a bit of hull (where the cowl sits) to accomodate the larger diameter pipe. I have been messing around with the .32 in a deuce for about 5months now and pretty much have her tuned in. Another good idea is to extend your rudder using 3/8" aft and use one of Toyotatruckin's rudders, I tested out the rudder on the .32 and it pretty much solved spin out issues due to prop walk. As mr dunlop said, add some weight to the sponson, I used one and half sticks (4.5oz) to settle the squirrliness
(torque roll) on straights. After some minor piston sleeve porting I ran a 48.3mph run with other boats in the water, once I was able to get the others out of the pond I hit 50+ then lost the ride due to a loose rudder control arm.
I happened by this ride, some great work on mods, any suggestions on where to go with her?
< Message edited by TrEsPaSS -- 10/30/2009 8:13 AM >
Hide Signatures
       Post #: 182
RE: AQUACRAFT'S NEW MISS VEGAS U-18 - 10/29/2009 9:49 PM
matt420
Score: 100
Last Login: 11/25/2012
Status: offline
thats my old hull spent many hours on it oh and dollars
Hide Signatures
       Post #: 183
RE: AQUACRAFT'S NEW MISS VEGAS U-18 - 10/30/2009 3:47 AM
malicent
Score: 100
Last Login: 3/16/2012
Status: offline
Yea Matt it sucks you got rid of it, but hey at least you got the dumas THAT YOU NEVER USED!!!!!!!!! lol just build that whip ya got and get back to the lake!!! lol.......
Hide Signatures
(in reply to matt420)
       Post #: 184
RE: AQUACRAFT'S NEW MISS VEGAS U-18 - 10/30/2009 8:11 AM
TrEsPaSS
Score: 100
Status: offline
quote:
ORIGINAL: matt420
trying to decide what to run in her. Some great work done on modding her, kudos!
Hide Signatures
       Post #: 185
RE: AQUACRAFT'S NEW MISS VEGAS U-18 - 10/30/2009 8:34 AM
malicent
Score: 100
Status: offline
well it depends on how you wanna run it tod. if ya wanna race it stick an .18 in her! You could even go .21 with the way Matt has her set up. It is a strong hull.
Jeremy.
Hide Signatures
       Post #: 186
RE: AQUACRAFT'S NEW MISS VEGAS U-18 - 10/31/2009 5:42 AM
matt420
Score: 100
Status: offline
ya its beefy, trespass check out page 31 look for the thread my outlaw/sport20 vegas and you can see how that hull started
Hide Signatures
(in reply to malicent)
       Post #: 187
RE: AQUACRAFT'S NEW MISS VEGAS U-18 - 10/31/2009 10:33 AM
TrEsPaSS
Score: 100
Status: offline
sweet, thanks Matt and Jeremy... I am looking for something great to do for the winter...
Hide Signatures
       Post #: 188
RE: AQUACRAFT'S NEW MISS VEGAS U-18 - 1/27/2010 8:19 AM
Waksk8n
Score: 100
Last Login: 8/13/2012
Status: offline
The Deuce is on sale at tower for $249. For tower members you can spend another $1 and get $50 off, so $200 out the door shipped. Good deal
Hide Signatures
       Post #: 189
RE: AQUACRAFT'S NEW MISS VEGAS U-18 - 1/28/2010 4:49 AM
madmax93
Score: 100
Last Login: 3/19/2013
Status: offline
yes and it looks like non members can get $20 off too, but it's only untill Jan 31st
KM baja...Dynamite...HPI Firestorm...Small Bolt...Easy Star...Wild Hawk
Hide Signatures
(in reply to Waksk8n)
       Post #: 190
RE: AQUACRAFT'S NEW MISS VEGAS U-18 - 5/12/2010 5:45 AM
silverback54
Score: 100
Last Login: 5/15/2010
Status: offline
   hope for some help,  first time rc,  ran the second tank of fuel out, refilled the tank, hook up the starter and all that I got was the starter the engine was not turning over.  opened it up and could not find the starter spring nor pin.  talking to teck support, the pin is free floating, does anyone have some ideas of the how or why.  I was really starting to enjoy, for the speed was increasing with only two tanks.  Now I am not sure about keeping the .18 or going to another engine.
Hide Signatures
(in reply to barmonkey)
       Post #: 191
RE: AQUACRAFT'S NEW MISS VEGAS U-18 - 5/13/2010 1:09 AM
Jerry Dunlap
Score: 105
Status: offline
quote:
ORIGINAL: silverback54
I would suggest you consider using a starting belt and electric starter. The Super Tigre 18 is a solid engine. You need to take the engine apart to remove the spring and pin before running it again. SUPG2052 is the part number for the backplate to replace the gear drive starter when using an electric starter.
JD
Hide Signatures
(in reply to silverback54)
       Post #: 192
RE: AQUACRAFT'S NEW MISS VEGAS U-18 - 6/1/2010 11:46 PM
roughneck793
Score: 100
Last Login: 9/22/2010
Status: offline
I need a replacement flex shaft, broke shaft and looking too upgrade, I tried finding a lnk in this forum but there was too many postings to go through, hanks
Hide Signatures
       Post #: 193
RE: AQUACRAFT'S NEW MISS VEGAS U-18 - 6/2/2010 12:29 AM
toyotatruckin
Score: 100
Status: offline
through me on the flexshaft in fact I just tossed up a listing here in the sale section so you can contact me through PM here or use my contacts page
http://www.aircapitolhobbies.com/Contact.html
Im easy to find....
http://www.youtube.com/user/toyotatruckin
Hide Signatures
(in reply to roughneck793)
       Post #: 194
RE: AQUACRAFT'S NEW MISS VEGAS U-18 - 8/15/2010 11:17 PM
ntrain42
Score: 112
Last Login: 1/4/2012
Status: offline
Well, I just picked up one of these. Hope it was $280 well spent. Just curious, but anyplace to competitively race these in the Mass./NH area?
Hide Signatures
(in reply to toyotatruckin)
       Post #: 195
RE: AQUACRAFT'S NEW MISS VEGAS U-18 - 8/16/2010 1:29 AM
amax
Score: 107
Last Login: 5/14/2013
Status: offline
These are whats close to ya
IMPBA Dist 1
NAMBA Dist. 11
Top Speed Hobbies llc. Gotta Need For Speed..
www.youtube.com/user/topspeedhobbies
Hide Signatures
(in reply to ntrain42)
       Post #: 196
RE: AQUACRAFT'S NEW MISS VEGAS U-18 - 8/16/2010 2:24 AM
ntrain42
Score: 112
Status: offline
Cool, thanks for links.
Hide Signatures
(in reply to amax)
       Post #: 197
RE: AQUACRAFT'S NEW MISS VEGAS U-18 - 8/17/2010 8:30 PM
ntrain42
Score: 112
Status: offline
Well my MVD came in.......couple quick questions: SHould I tear the engine apart make sure there is no debris inside? And what recommendations are in order to make it durable and seaworthy longterm? THanks for helping the noob.
Hide Signatures
       Post #: 198
RE: AQUACRAFT'S NEW MISS VEGAS U-18 - 8/17/2010 10:06 PM
toyotatruckin
Score: 100
Status: offline
Answer to the cleaning question
http://www.rcuniverse.com/forum/m_9934109/tm.htm
Hide Signatures
       Post #: 199
RE: AQUACRAFT'S NEW MISS VEGAS U-18 - 8/18/2010 3:26 AM
ntrain42
Score: 112
Status: offline
Thanks for the link, also, what about sealing up and reinforcing the hull? Saw alot of ppl doing that to the original MV, not sure if it needs to be done to the deuce?
Hide Signatures
       Post #: 200
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.641RCU1
