1\8 Scale Dumas Hydro
Tower Hobbies
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Boats >> RC Scale Boating >> 1\8 Scale Dumas Hydro Page: [1]
Login
1\8 Scale Dumas Hydro - 5/9/2009 1:13 AM
kentodd140
Score: 100
Last Login: 5/9/2009
Status: offline
I'm building a 1\8th Scale Dumas hydroplane.
It's an older model that calls out for a .67 engine. Does anybody have any other suggestions?
Is there a better engine that I can put into my Miller American Hydro?
Hide Signatures
       Post #: 1
RE: 1\8 Scale Dumas Hydro - 5/9/2009 4:27 PM
kennyach
Score: 100
Last Login: 11/7/2009
Status: offline
Hi m8 sound like the boat i did 20 year ago and now i am going a 1/8 Gary Finlay atlas van line from his plan you can find a lot of help on the site at http://www.rumrunnerracing.com/feforums/ these guy are for real on hydro and you fine me and my 1/8 atlas at http://www.rumrunnerracing.com/feforums/showthread.php?t=28164&page=2 and also on this site at kennyrach
Hide Signatures
(in reply to kentodd140)
       Post #: 2
RE: 1\8 Scale Dumas Hydro - 5/12/2009 12:58 AM
advanced builder
Score: 100
Status: offline
Yes I have one of each ,atlas van line ,miller a ,I hope you use a flex shaft on that miller, nothing but problems if you don't ,change that transom to a good grade of aircraft ply or birch ply, I need to change my motor mount ,Rubber vib mounts ,LOUD if mounted to hardwood,old school prints ,will show picks if needed ALSO CK OUT THAT CHAINSAW LOBSTERBOAT on ebay
http://cgi.ebay.com/Vintage-Radio-Controled-Motor-Boat_W0QQitemZ110387123333QQcmdZViewItemQQptZRadio_Control_Vehicles?hash=item19b395d485&_trksid=p3286.c0.m14&_trkparms=72%3A1205|66%3A2|65%3A12|39%3A1|240%3A1318|301%3A1|293%3A2|294%3A50
Hide Signatures
(in reply to kennyach)
       Post #: 3
RE: 1\8 Scale Dumas Hydro - 5/12/2009 2:14 AM
Hydro Junkie
Score: 105
Status: offline
The Miller needs more than that to be a good runner. Here is the short list:
1) Replace all the mahogany framing with aircraft grade birch ply, 1/16th ply for all cross frames except transoms and 1/8th for lengthwise frames
2) As per Advanced builder, replace the rear transom with 1/4 aircraft ply and replace the sponson transom with 1/8th aircraft ply, laminating no less than a 1/8th doubler for the skid fin bracket, though I would go thicker, to either 3/16ths or 1/4
3) Lose the rear radio box. Relocate the radio box to the front and the fuel tank(s) to under the deck around the CG
4) Be sure to cut lightening holes in all underdeck framing to minimize weight
That shoul dbe enough to get you started
< Message edited by Hydro Junkie -- 5/14/2009 4:42 AM >
Hide Signatures
(in reply to advanced builder)
       Post #: 4
RE: 1\8 Scale Dumas Hydro - 5/12/2009 2:46 AM
kennyach
Score: 100
Status: offline
Yep ! Hydro Junkie right about the mahogany framing that come with Dumas and replace with aircraft-grade plywood .you can get some good Finland Birch Plywood or Light Plywood at http://www.nationalbalsa.com/hardwood-ply.htm or http://www.aircraftspruce.com/catalog/wppages/domplywood.php
< Message edited by kennyach -- 5/12/2009 3:01 AM >
Hide Signatures
       Post #: 5
RE: 1\8 Scale Dumas Hydro - 5/13/2009 6:41 AM
Hydro Junkie
Score: 105
Status: offline
DO NOT USE LITE PLY IN YOUR BOAT!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! LITE PLY IS BALSA WITH BIRCH VENEER FACINGS AND WILL NOT HOLD UP!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Hide Signatures
       Post #: 6
RE: 1\8 Scale Dumas Hydro - 5/13/2009 3:25 PM
advanced builder
Score: 100
Status: offline
Here is an old Sept 1994 radio control boat modeler showing what Hydro Junkie is talking about.notice the holes in the bulkheads
Hide Signatures
(in reply to Hydro Junkie)
       Post #: 7
RE: 1\8 Scale Dumas Hydro - 5/13/2009 5:20 PM
kennyach
Score: 100
Status: offline
been using  it for year m8 and never have any thing go wrong yet .so i do not know what your talking about m8 .also see here http://www.rcgroups.com/forums/showthread.php?t=263239 and it was also use on the lady Linda launched 1999 .here the web http://www.comptonlbr.com/images/Lite-Ply2.pdf
< Message edited by kennyach -- 6/5/2009 1:37 PM >
Hide Signatures
       Post #: 8
RE: 1\8 Scale Dumas Hydro - 5/14/2009 4:51 AM
Hydro Junkie
Score: 105
Status: offline
I've watched hydros made with lite ply literally disitegrate while running. If you want to add lots of unneeded weight and glass the hull later to make it stronger so be it. Here is one of the posts from that thread:
I generally use lite ply/1/8" for stations/bulkheads when constructing a scratchbuilt hull. Planking generally is balsa in either 1/16" to 1/8" thickness. Ca'd to the stations as they lay. With this method, you generally will have some areas in the planking that need filled and i usually do so with the new light fillers. Then once the stern and bow blocks are faired in and everything is fair to my likeing, i then will proceed with the fiberglassing stage. Hull sanding/fairing and attachment of the bilge keels or any other items needing sealed in place by the final resin coat stage. Then removal from the building board and ultimately removal of those light ply bulkheads for the most part, except for those that will remain in place. Some people i know use the light ply for superstructure construction and then cover this with styrene(.020 to .040) or aircraft ply(1/64 to 1/32nd inch.). Gives a smooth surface and sharper corners. Hope this helps.
NOTICE THE WORDS PLANKING AND BILGE KEELS, WHICH ARE ONLY USED ON DISPLACEMENT TYPE HULLS AND OCEAN GOING SHIPS, NOT HYDROS
< Message edited by Hydro Junkie -- 5/14/2009 4:55 AM >
Hide Signatures
       Post #: 9
RE: 1\8 Scale Dumas Hydro - 5/14/2009 2:04 PM
kennyach
Score: 100
Status: offline
Hydro Junkie and all , Every day (if you are not careful) you learn something new
As a plane freak I can say that liteply is used extensively in the larger planes - often laser-cut or milled as fuselage bits. It is basically thick, light and stiff (enough) but we still chop out the middles of all big bits.
Its also soft enough to be cut easily with a knife
It has been used in boats as the main material - I think there was a plan or two in the last few years. Even if the adhesive is not waterproof, it is no worse than white glue, and both need to be welll sealed and painted.
And We really do live and learn.......What a good day today has turned out to be. Another great service here at RC universe
Hide Signatures
       Post #: 10
RE: 1\8 Scale Dumas Hydro - 5/15/2009 5:06 AM
Hydro Junkie
Score: 105
Status: offline
I agree, lite ply can be used on certain styles of boats, but a hydro isn't one of them. It's the same with luan/doorskin, it's not a suitable material for hydroplanes. What makes a hydro different is that it's strength is in it's skin, not the framework. That being said, the framing needs to be able to take the pounding and vibration from bouncing off the top of the waves and ripples. Lite ply, without glass reinforcement, won't take that kind of abuse for very long before it shatters. By reinforcing the lite ply, you have now added a considerable amount of weight that must be overcome. This is where the aircraft grade ply is much better material. It doesn't require reinforcing, it doesn't have the soft center that must be protected and it will take considerably more abuse than lite ply. For the record, I also have built aircraft and worked with lite ply and balsa, I have also broken parts made from both with little to no effort as well. I'll leave the lite ply and balsa in the air and the ply on the water
< Message edited by Hydro Junkie -- 5/15/2009 9:35 PM >
Hide Signatures
       Post #: 11
RE: 1\8 Scale Dumas Hydro - 5/15/2009 3:21 PM
kennyach
Score: 100
Status: offline
Hydro Junkie . Sound good to me m8 thank for the head up ,Hydro Junkie
< Message edited by kennyach -- 5/15/2009 3:22 PM >
Hide Signatures
       Post #: 12
RE: 1\8 Scale Dumas Hydro - 5/15/2009 10:09 PM
advanced builder
Score: 100
Status: offline
Atlas van line was my first build ,I changed a few things ,the back stringers [where you put the screws on the rear hatch ] went with 1/4 sq spruce also put screws thru transom into them 2 stringers JUST A IDEAL
Hide Signatures
       Post #: 13
RE: 1\8 Scale Dumas Hydro - 6/5/2009 1:22 PM
kennyach
Score: 100
Status: offline
advanced builder .It sound like a plan too me to put the screws on the rear hatch . And any picture of the screws thru transom into them 2 stringers that you did m8
< Message edited by kennyach -- 6/5/2009 1:23 PM >
Hide Signatures
       Post #: 14
RE: 1\8 Scale Dumas Hydro - 6/22/2009 2:00 AM
advanced builder
Score: 100
Status: offline
I have been away,kitchen remodel .What a job. here is a pic or two I added Another 1/8 ply to cover up the screw heads my transom is 3/8" thick 1/4 first than 1/8 to cover up screw heads . my driver is missing a brass roll bar holds all in place. missing also notice in pic 4, holes for fins to hold the front down [ she will blow over] wind in her face.
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by advanced builder -- 6/22/2009 2:06 AM >
Hide Signatures
       Post #: 15
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.860RCU1
