PilotLight
MI, USA Status: offline
I've finally got the engine running good, but it was on a engine test stand. I received a new rear cover plate. The old needle valve was broke off the engine so I let it hang by some blue medium fuel line. The engine ran OK, but the important thing was there was NO air in the fuel line. Next we changed the glow plug from a Fox with an idle bar to a 0 S #8. (more improvement) Finally, we noticed the fuel tank had a lot of fuel splashing inside so we decided to balance the prop. We found the prop was perfectly balanced on a magnetically suspended balancer, so we installed the propeller so that when the piston was at top dead center the propeller was horizontal not vertical. This produced a lot less vibration and the engine ran perfectly. To sumarize: * New fuel tubing between needle valve and carb * remove needle vavle from rear of engine (eliminate vibration) * run OS plugs * mount prop horizontally to piston top dead center (this made big difference)
