rojos
Score: 100 Joined: 10/29/2002 Last Login: 6/11/2013 From: Navarre,
FL, USA Status: offline
Here is the latest from the ARC group for models. Much bigger document for SUAVs. This is not in concrete yet! Steve April 1, 2009 Page 3 Subpart A. Model Aircraft 2. Model Aircraft Operated in Accordance with FAA Accepted Standards 2.1 Applicability Model Aircraft operations that are conducted in accordance with an FAA accepted set of standards established and administered by a community based association as discussed in Section 2.2, shall otherwise be exempt from the requirements of any Special Federal Airworthiness Regulation (SFAR) that results from this recommendation as long as they are operated by: • Hobbyist for the sole purpose of sport, recreation and/or competition under the conditions of such an FAA accepted program • Manufacturers which are flight testing aircraft intended to be operated for the sole purpose of sport, recreation, and/or competition and they are tested at an approved field as defined by and in accordance with an FAA accepted program with the approval of the community-based association responsible for the location • Educational institutions and/or students for the sole purpose of education or research and they are operated at an approved field as defined by and in accordance with an FAA accepted program with the approval of the community-based association responsible for the location • Manufacturers which are flight testing aircraft intended to be operated for other than sport, recreation, and/or competition and they are tested at an approved field as defined by and in accordance with an FAA accepted program with the approval of the community-based association responsible for the location RATIONALE: Reflects FAAs concept of regulating model aviation by exempting Model Aircraft from regulation. Under this approach, modelers participating within an aeromodeling structure/organization such as the Academy of Model Aeronautics (AMA) may operate their Model Aircraft in accordance with an accepted set of standards and operating procedures. Based on a more rigorous attention to safety, risk assessment, and risk mitigation, the accepted standards may provide greater latitude in the Model Aircraft operations. Modelers not participating in the additional safety programming established in an accepted set of standards shall comply with the requirements of Section 3. April 1, 2009 Page 4 COMMENTARY: It is important that manufacturers of Model Aircraft are able to test fly their aircraft as they do today without having to adhere to sUAS regulations. In order to give educational institutions (e.g., universities) the flexibility to provide "hands on" instruction and training to students preparing for careers in the UAS and aviation industries they are allowed to fly these systems under the requirements for Model Aircraft. For consistency, manufacturers who develop sUAS that are functionally similar to Model Aircraft, are allowed to test at a location following a community-based and FAA-accepted program. 2.2 Accepted Model Aircraft Standards and Procedures Accepted Model Aircraft Standards and Procedures may be established and administered by a community-based association. An accepted set of standards shall be based upon accepted and recognized safety principles and will include but not be limited to the following: RATIONALE: Community based organizations, such as the AMA, that have credibility within the Model Aircraft community and that have an established safety record and have demonstrated the ability to influence participant compliance shall be afforded the opportunity to establish a set of safety standards that are more comprehensive than the requirements and limitations given for non participating modelers, and use these standards as an alternative means of compliance with any regulations which may results from these recommendations. Since such standards are more comprehensive, operations under such standards shall allow for a broad spectrum of operations and greater latitude in the AMA operations. (1) Prescribed safety program entailing oversight, assessment, risk mitigation, and accident/incident reporting. (2) General safety guidelines and operating principles. (3) Operating guidelines specific to the location and to the type, size, performance, and propulsion of the various Model Aircraft. (4) Comprehensive programming addressing Model Aircraft having non standard weight, or identified as having unusual propulsion types or extraordinary flight characteristics. (5) Programming to facilitate Model Aircraft events, competition, national and international record attempts, gatherings, and Model Aircraft demonstrations and exhibitions. (6) Educational programming that assures participants are provided relevant safety information and validates the learning process. (7) Educational programming that addresses essential piloting issues including: • Recognition and avoidance of manned aircraft • Safe operation near spectators and other non participants April 1, 2009 Page 5 • Safe and cooperative operation with other modelers • Transitioning to higher performance and more complex models (8) Methodology for establishing and designating dedicated Model Aircraft flying sites providing: • Guidelines for flying site location, configuration and design layout applicable to its intended use and the type(s) of Model Aircraft flown, and which ensures Model Aircraft operations do not interfere with manned flight operations • Safety guidelines that ensure the safety of the public and provide adequate separation of persons and property from the Model Aircraft operations • Guidelines for coordinating and reviewing operating policies and procedures with the airspace controlling authority for those flying sites located within controlled airspace • Guidelines for coordinating and reviewing operating policies and procedures with the airport and applicable airspace control authority for those flying sites located within 3 NM of a military or public-use airport, heliport, or seaplane base. • Guidelines for establishing and disseminating flying site operating procedures, limitations and safety guidelines including the following: Hours of Operation Flying site operating procedures Frequency control procedures (if applicable) Traffic pattern and flight operations Cooperation with other modelers Applicable altitude restrictions Applicable No-Fly zones and operating area limits Flight line and pit area safety procedures Spectator and public access policies Emergency Procedures (e.g., Fire, First Aid) 3. Model Aircraft Not Operated in Accordance with Accepted Set of Standards ! 3.1 Applicability ! The following general requirements and limitations apply to Model Aircraft which are not operated in accordance with an FAA accepted set of standards, but are operated by hobbyists for the sole purpose of sport, recreation, and/or competition. April 1, 2009 Page 6 ALTERNATIVE VIEW: Eliminate Section 3.0 in its entirety. ALTERNATIVE RATIONALE: AMA believes this approach is flawed in that it fails to recognize the substantial diversity of the hobby, establishes unrealistic and unenforceable restrictions, and leaves absent a safety surveillance program to oversee the activities of those modelers who choose not to participate in a formal aeromodeling structure/organization More importantly, as a baseline set of standards, these limitations have the inherent potential of imposing a devastating impact on the aeromodeling activity and the hobby industry. 3.2 General Requirements ! (1) Model Aircraft shall be flown in open spaces and in a manner that does not endanger the life and property of others. (2) Model Aircraft shall yield the right of way to all manned aircraft. (3) Model Aircraft shall not interfere with operations and traffic patterns at airports, heliports, and seaplane bases. (4) Model Aircraft shall not be operated at locations where Model Aircraft activities are prohibited. (5) Model Aircraft are limited to unaided visual line-of-sight operations. The Model Aircraft pilot must be able to see the aircraft throughout the entire flight well enough to maintain control, know its location, and watch the airspace it is operating in for other air traffic. Unaided visual line-of-sight does not preclude the use of prescribed corrective lenses. (6) Model Aircraft shall be designed, equipped, maintained and/or operated in a manner in which the aircraft remains within the intended area of flight during all operations. (7) Model Aircraft pilots may not intentionally drop any object from a Model Aircraft that creates a hazard to persons or property. (8) Model Aircraft shall be operated in a manner that respects property rights and avoids the direct overflight of individuals, vessels, vehicles, or structures. (9) Model Aircraft shall not be operated in a careless or reckless manner. (10) Model Aircraft pilots shall not operate their aircraft while under the influence of alcohol or while using any drug that affects the person’s faculties in any way contrary to safety. (11) Model fixed-wing and rotorcraft aircraft shall not use metal-blade propellers. (12) Model Aircraft shall not use gaseous boosts. (13) Model Aircraft shall not use fuels containing tetranitronmethane or hydrazine. (14) Model Aircraft shall not use turbine-powered engines (e.g., turbo-fan, turbo-jet) as a propulsion source. ! April 1, 2009 Page 7 RATIONALE: Turbine powered aircraft are perceived by many members of the sUAS Aviation Rulemaking Committee (ARC) as being a higher risk. ALTERNATIVE VIEW: Eliminate the limitation. ALTERNATIVE RATIONALE: The blanket prohibition of turbine engines does not take into consideration the various and diverse turbine engines currently produced and impose an unjustified economic impact on the hobby industry. 3.3 General Limitations ! (1) Model Aircraft shall not exceed 55 pounds (lbs). (2) Model Aircraft shall remain clear of clouds. (3) Model Aircraft will not operate in Class B airspace without the permission of the ATC authority. (4) Model Aircraft shall not be operated within 3 NM miles of an airport, heliport, or seaplane base without the permission of the ATC authority or airport manager. (5) Model Aircraft shall operate in close proximity to the ground, at or below 400 feet () above ground level (AGL), and shall at all times remain below and well clear of all manned aircraft. ! RATIONALE: By keeping Model Aircraft at or below 400 encounters with manned aircraft are reduced. This recommended general limitation is consistent with the current Model Aircraft guidance contained in AC91-57. ALTERNATIVE VIEW: Replace (5) with the following: Model Aircraft shall operate in close proximity to the ground, shall stay at or below 400 AGL when within 3 NM of an airport, and shall at all times remain below and well clear of all manned aircraft. ALTERNATIVE RATIONALE: Though it is agreed that there needs to be some altitude limit on the modelers that are not participating in a structured safety program such as AMAs, AMA also knows from their experience that creating a hard and fast across the board altitude limit, such as 400 is unnecessarily restrictive, unrealistic, and arguably poses a greater risk to personnel on the ground. AMAs experience has shown that the greatest risk to other participants in the NAS and perhaps the only significant risk posed by model aviation is when Model Aircraft are operated within three miles of an airport. The language in the ATERNATIVE VIEW mirrors the current guidelines in the AMA Safety Code. (6) Notwithstanding the above limitations, Model Aircraft weighing less than or equal to two lbs incapable of reaching speeds greater than 60 miles per hour (mph) (52 knots), and powered by electric motor or mechanical stored energy (e.g., April 1, 2009 Page 8 rubber-band powered) may operate within 3 NM of a military or public-use airport or heliport; if they remain a safe distance from the airport or heliport, remain well clear of all manned aircraft, and remain below 400 AGL. RATIONALE for the above limitations: (1) Currently accepted domestic weight limit and has international precedent as well. (2) Is consistent with the concept of visual line-of-sight (VLOS). (3) Class B is positive control. All aircraft are required to operate on a clearance. Gaining permission from ATC is equivalent to receiving a clearance. (4) Model Aircraft permitted to operate within 3 NM of the airport will be provided applicable operating limitations. (5) 400 is appropriate for Model Aircraft operations in Class C airspace without coordinating with ATC and is consistent with the intention of current domestic policy and with the UK, CASA, and Canada. (6) This is consistent with the guidelines currently established by AC91-57. (7) Makes a blanket exception for models weighing two lbs or less. This is an appropriate allowance for Park Flier and toy type models and allows them to use parks and small fields closer to airports. (7) Model Aircraft will not be flown at an airspeed that would cause the aircraft to inadvertently leave the prescribed maneuvering area. ! RATIONALE: The pilot will be responsible for limiting their speed so that they can remain within the prescribed maneuvering area. ALTERNATIVE VIEW: Replace (7) with the following: Model Aircraft cannot be operated at airspeeds which exceed 100 mph (87 knots). ALTERNATIVE RATIONALE: Restricting the speed of Model Aircraft not participating in an FAA-accepted safety program will mean that highperformance aircraft will not be operated by individuals that are not being scrutinized by their peers. Eliminating high-performance aircraft will also help to ensure that the operator will be able to keep their aircraft within the defined operational area (line-of-sight and below 400 AGL). Limiting the speed also will reduce the likelihood of turbine powered aircraft being operated without the guidance of an FAA-accepted safety program. Turbine powered aircraft are perceived by many members of the ARC as being a higher risk. (8) Model Aircraft cannot launch pyrotechnic devices which explode or burn. April 1, 2009 Page 9 (9) Excluding take-off and landing, no powered Model Aircraft may be flown closer than 25 feet to any individual, except for the pilot and the pilots helper located at the flight line.
< Message edited by rojos -- 5/12/2009 4:24 AM >
Hide Signatures
