RE: Tamiya Buggy Champ 2009 Resource Thread!    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Electric Off-Road Trucks, Buggies, Truggies and more >> RE: Tamiya Buggy Champ 2009 Resource Thread!
Page: <<   < prev  13 14 15 16 17 18 19 20 21 [22]
Login
RE: Tamiya Buggy Champ 2009 Resource Thread! - 11/1/2011 9:31 PM
grumppee
Score: 100
Last Login: 1/4/2013
Status: offline
No problem Lunchboxer...
Hide Signatures
(in reply to Lunchboxer)
       Post #: 526
RE: Tamiya Buggy Champ 2009 Resource Thread! - 11/2/2011 4:13 AM
grumppee
Score: 100
Status: offline
Well I decided something had to be done about the rear dampers. Mine leak terribly, and the torsion bar is in my opinion useless. I started to dig through some parts, and then I noticed the "Cam Lock Springs" sitting in my Buggy Champ box. So I thought to myself... what the heck.
A little stiff, I could cut down a coil or two... but they work surprisingly well.
Hide Signatures
(in reply to grumppee)
       Post #: 527
RE: Tamiya Buggy Champ 2009 Resource Thread! - 2/8/2012 2:43 AM
grumppee
Score: 100
Status: offline
After receiving a replacement Sand Scorcher body kit I decided to spray my beater shell with truck bed liner. It has proven to be very durable, and doesn't look terrible in my opinion. I through on the Brat wheels this evening, and I really like the stance.
Hide Signatures
       Post #: 528
RE: Tamiya Buggy Champ 2009 Resource Thread! - 2/11/2012 11:44 PM
grumppee
Score: 100
Status: offline
Is it common for an SRB to have a terrible turning radius?
I think it may be time to upgrade the steering servo. I weighed my Scorcher... 5.6lbs w/battery, and it turns like an aircraft carrier.
Hide Signatures
       Post #: 529
RE: Tamiya Buggy Champ 2009 Resource Thread! - 3/1/2012 9:50 PM
grumppee
Score: 100
Status: offline
I removed the Futaba steering servo and replaced it with a Hitec HS-645MG model. The stock rear shocks were also removed, and the scorcher was fitted with Tamiya 53155 coil-overs.
Hide Signatures
       Post #: 530
RE: Tamiya Buggy Champ 2009 Resource Thread! - 3/1/2012 9:55 PM
Lunchboxer
Score: 436
Last Login: 5/22/2013
Status: offline
I am sure the new shocks work better.. ha ha! (but probably slightly less scale.. !)
_____________________________
LB | WW2 | TLT | TB02 | DF03 | TEgg | F103GT | TXT | Hornet | Frog | Scalpel | Leo 2A6 | Aeromax | WW1 | Clod | CR-01
Hide Signatures
       Post #: 531
RE: Tamiya Buggy Champ 2009 Resource Thread! - 3/1/2012 10:20 PM
grumppee
Score: 100
Status: offline
Lol... not really concerned with scale looks on the Scorcher, I have a Trailfinder for that...
Hide Signatures
       Post #: 532
RE: Tamiya Buggy Champ 2009 Resource Thread! - 5/7/2012 11:19 PM
Caboose6789
Score: 100
Last Login: 12/3/2012
Status: offline
Here's my Silver Edition Buggy Champ:
Check out my deviantART gallery for more if you'd like: javascript:mox();
Check out my deviantART gallery! http://caboose6789.deviantart.com/
Hide Signatures
       Post #: 533
RE: Tamiya Buggy Champ 2009 Resource Thread! - 5/8/2012 1:13 AM
Lunchboxer
Score: 436
Status: offline
Looks great!!
Hide Signatures
(in reply to Caboose6789)
       Post #: 534
RE: Tamiya Buggy Champ 2009 Resource Thread! - 5/8/2012 3:56 AM
Caboose6789
Score: 100
Status: offline
 Thanks! It runs great when the shocks aren't bone dry
Does anyone know if mounting them upside down actually helps the leakage? I tried it breifly but they just filled up with dirt.
Either way I'll be swapping them out for RC Channel SRB shocks soon enough
Hide Signatures
       Post #: 535
RE: Tamiya Buggy Champ 2009 Resource Thread! - 5/8/2012 3:58 AM
Lunchboxer
Score: 436
Status: offline
Do they leak that badly?!
Hide Signatures
       Post #: 536
RE: Tamiya Buggy Champ 2009 Resource Thread! - 5/8/2012 4:02 AM
Caboose6789
Score: 100
Status: offline
 Yeah, after an hour or so of driving they're just pogo sticks. They haven't really changed much since 1979, so guess I can't blame them
Hide Signatures
       Post #: 537
RE: Tamiya Buggy Champ 2009 Resource Thread! - 5/8/2012 4:03 AM
Lunchboxer
Score: 436
Status: offline
The o-rings might have been damaged during assembly? Their design are similar to many of the Tamiya shocks and they shouldn't leak so badly.
Hide Signatures
       Post #: 538
RE: Tamiya Buggy Champ 2009 Resource Thread! - 5/8/2012 4:18 AM
Caboose6789
Score: 100
Status: offline
 No, they look pretty clean, and the kit came with a couple extras I can try if they are damaged. I think the main fault is that the parts inside just float around, that might leave some unwanted gaps at times
The front shocks keep their oil reasonably well, but the rear ones do a lot more work and they end up dry pretty fast.
Hide Signatures
       Post #: 539
RE: Tamiya Buggy Champ 2009 Resource Thread! - 5/31/2012 4:12 AM
Caboose6789
Score: 100
Status: offline
I tried grumppee's method of cutting down the cam lock springs a bit and putting them in the rear shocks, and it works pretty well. The back end will consistently hold its own weight now and I don't have to worry about the oil. Max travel is reduced a little but it's not too bad for light running
Hide Signatures
       Post #: 540
RE: Tamiya Buggy Champ 2009 Resource Thread! - 7/2/2012 12:20 AM
grumppee
Score: 100
Status: offline
The Tamiya 53155 coil-overs will rub on the stock rear wheels. Unless you plan on running Brat wheels like I do.
Hide Signatures
       Post #: 541
RE: Tamiya Buggy Champ 2009 Resource Thread! - 8/3/2012 9:20 PM
grumppee
Score: 100
Status: offline
I made a stop at the local Hobby store this afternoon. I decided to purchase a stiffer spring set for the rear coil overs. Unfortunately I could not get a set of Tamiya springs, however I did find a "generic" on-road medium spring and thought I would try them, $5 why not...
I replaced the lower spring perch with a larger unit I had in my parts box to accommodate the wider spring. Under full compression the lower spring perch will make slight contact with the rear wheel, but the added stiffness will most likely eliminate the issue in most cases. I am happy with the result. No more sagging in the rear from the weight of the buggy. I also removed the torsion bar...
Hide Signatures
       Post #: 542
RE: Tamiya Buggy Champ 2009 Resource Thread! - 8/3/2012 10:34 PM
grumppee
Score: 100
Status: offline
I just happen to look up at my Hornet on the shelf above my PC and had the strangest thought... rear Hornet shocks up front on the SRB. Hmmm...
I had to improvise with the lower spring perch. I used the inner oil damper ring (You know, the circular plastic piece with one, two, or three holes), some black rubber o-rings and wouldn't you know it... they fit.
Hide Signatures
       Post #: 543
RE: Tamiya Buggy Champ 2009 Resource Thread! - 8/3/2012 10:37 PM
thehuntingterminator
Score: 224
Last Login: 5/15/2013
Status: offline
Nice! What motor/ESC are you running in it?
- HobbyTownUSA Employee
- Writer for ModelKits.com & RcTruckStop.com
Hide Signatures
       Post #: 544
RE: Tamiya Buggy Champ 2009 Resource Thread! - 8/3/2012 11:08 PM
grumppee
Score: 100
Status: offline
Tamiya Sport Tuned and Tamiya ESC at the moment.
I corrected the rear shock and wheel contact under full compression with a set of Hornet rear wheel hubs. These push the rear wheels outward, providing the necessary clearance for the Tamiya dampers.
quote:
ORIGINAL: thehuntingterminator
< Message edited by grumppee -- 8/6/2012 7:41 PM >
Hide Signatures
(in reply to thehuntingterminator)
       Post #: 545
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.484RCU1
