RE: Duplicating an existing hull...ETHICALLY!
Tower Hobbies
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Boats >> Speed - RC Gas Boats >> RE: Duplicating an existing hull...ETHICALLY!
Page: <<   < prev  2 3 4 5 6 7 8 [9] 10 11   next >   >>
Login
RE: Duplicating an existing hull...ETHICALLY! - 6/11/2009 1:54 AM
Paul M
Score: 100
Last Login: 11/7/2009
Status: offline
Looks great Scott. MAN, I wish thiis thing were big enough for side by side twins. It would benothing to get this thing ready to paint.
I'm dreading the prep work I'm going to have to do on what I think I'm getting.
BTW - I thought I was the only one on the planet saying "spooged"
Hide Signatures
(in reply to Dreamin Hemi)
       Post #: 201
RE: Duplicating an existing hull...ETHICALLY! - 6/11/2009 2:17 AM
Dreamin Hemi
Score: 150
Last Login: 11/8/2009
Status: online
Inlines are not out of the rhelm of possibility....
_____________________________
These opinions expressed here are my own and may not necessarily represent the views of RCUniverse.com
Proprietor of FirstStateComposites dot com
Hide Signatures
(in reply to Paul M)
       Post #: 202
RE: Duplicating an existing hull...ETHICALLY! - 6/11/2009 2:49 AM
nothinbetr2do
Score: 110
Status: offline
quote:
ORIGINAL: Dreamin Hemi
o-yeah. should i be thinking about a second motor?  would 2 make it go faster?  would it need a second drive set up, or can 2 motors be linked into one prop? is this something that should be done now or can a second motor be added after the first one is set up and running?
< Message edited by nothinbetr2do -- 6/11/2009 2:54 AM >
just say no to "shelf queens"
Hide Signatures
       Post #: 203
RE: Duplicating an existing hull...ETHICALLY! - 6/11/2009 2:58 AM
nvs motorsports
Score: 100
Last Login: 10/8/2009
Status: offline
A good mod zenoah will be suffice i think inlines will upset the cg a lit due to to much weight on top of tunnel single engine will definately handle turns better
PROPRIETOR: NVS MOTORSPORTS
Automotive an Marine fibreglass
Hide Signatures
(in reply to nothinbetr2do)
       Post #: 204
RE: Duplicating an existing hull...ETHICALLY! - 6/11/2009 4:10 AM
Dreamin Hemi
Score: 150
Status: online
Oh yeah, fogot about the whole physics thing with the added weight on top that tall deck.  Still used to the mono's.  May not be great in the corners, but flat out would be sick in the straits!!!  I still wish to do that sometime.  Wonder if it's possible to stuff the engines in the sponsoon areas?  Would be a tight fit, but looks like it's doable.
< Message edited by Dreamin Hemi -- 6/11/2009 12:18 PM >
Hide Signatures
(in reply to nvs motorsports)
       Post #: 205
RE: Duplicating an existing hull...ETHICALLY! - 6/11/2009 4:56 AM
dreamwakes
Score: 100
Last Login: 11/4/2009
Status: offline
[[/quote]
Your absolutely right.  Sort of like quitting smoking I suppose.  Just have to stop cold turkey!  This hatch is my first test of NOT using it.  Hate the stuff, but just as mentioned before it's a safety net.  Once this pull is made, I'll add a few more coats and next hull will be PVA-less.
[/quote]
Hey Scott, I did not mean to infer that pva is horrible stuff, tis a excellent product and serves its purpose admirably...keep up the good work!!...
Hide Signatures
       Post #: 206
RE: Duplicating an existing hull...ETHICALLY! - 6/11/2009 10:54 AM
Dreamin Hemi
Score: 150
Status: online
A good product it is, however not good for getting a great finish.....especially in a garage/shop environment.  Just pulled out the hatch last night when I came home....a little harder to pop out, however the part looks perfect!  Great shine on the direct to mold finish and guess what....NO PVA WAS USED!  Actually came out a little easier than planned.  I'll show some pics later this morning.
Hide Signatures
(in reply to dreamwakes)
       Post #: 207
RE: Duplicating an existing hull...ETHICALLY! - 6/11/2009 12:06 PM
Dana W
Score: 100
Status: offline
It'll get easier the more parts you pull out .
DaVette Boats
Hide Signatures
       Post #: 208
RE: Duplicating an existing hull...ETHICALLY! - 6/11/2009 7:14 PM
Dreamin Hemi
Score: 150
Status: online
Update:
This morning I had Bobrien meet me in my shop as he wanted to be there for the great "opening of the mold".  I patiently waited for him to arrive....seemed like hours went by just knowing what I was headed to do.  Once he arrived, we jumped on the mold.  He was suprised as how heavy this entire mold actually is when bolted together with a hull inside.
We started by removing all the clamping bolts.....something like 23 of them???  Doing so my hear started racing....
Using my plastic wedges we forced them into the seam where the halves meet and began lightly tapping them in.  Immediately began to hear the popping sound of the pieces separating from each other.  Worked our way around the edges using the wedges to free up all the way around.  The mold simply lifted apart.
Shown here is the upper deck of the newly born hull.  Notice the flash around the seam area....the gelcoat spooged in nicely (although next time won't use so much!)   So far looking good....
PS, thanks for stopping by Bill...!
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by Dreamin Hemi -- 6/11/2009 8:16 PM >
Hide Signatures
(in reply to Dana W)
       Post #: 209
RE: Duplicating an existing hull...ETHICALLY! - 6/11/2009 7:28 PM
Dreamin Hemi
Score: 150
Status: online
cont.....
From the upper deck to the lower.  This was the easiest pull.  A few easy hits on the mold with a rubber mallet was all it took to free the lower deck loose from the mold.  Here you see the new hull easily lifted out.
Other shots show the amount of flash that remained on the hull.  This was very easily removed using my plastic wedges.  Like mentioned by NVS, the actual seam is practically non existant due to the location.....very nicely placed by the way .  So far everything looks great.  The flash knocked off easily, and as I expected, just a minor gelcoat repair on the lower bottom edge due to too much PVA used.  Since the non-pva'd canopy came out nicely, the next hull will not use the stuff and will have an even better appearance than what you see here.  I'm absolutely pleased with the results.
Now that I have built one of these, there are a few changes I'm making to the molds.  First, making the flange on the seating area of the upper deck wider.  It's a bit tight!  Secondly, installing the rails before joining the deck together...just need to mind the transom wood attachment to the upper deck.  So far that's about it.....  This thing looks awesome!
Next post shows the complete results......
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 210
RE: Duplicating an existing hull...ETHICALLY! - 6/11/2009 7:43 PM
Dreamin Hemi
Score: 150
Status: online
Meet your..........
"NEMESIS" Catamaran
Had to make my 2,000'th post a big one!  hehe.  As you guessed, we (NVS and I) choose to name this new hull "NEMESIS"
Shown here are the final results of the many hours and late nights.  This is a very exciting moment for me to see the final product.  First out of the mold is a success.   Like I mentioned, a few minor corrections, and I'll be even more pleased.  Kitchens open......let the production begin!
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by Dreamin Hemi -- 6/11/2009 7:48 PM >
Hide Signatures
       Post #: 211
RE: Duplicating an existing hull...ETHICALLY! - 6/11/2009 7:48 PM
Hesco Racing
Score: 106
Status: offline
That boat looks stunning. Great job.
Hide Signatures
       Post #: 212
RE: Duplicating an existing hull...ETHICALLY! - 6/11/2009 9:21 PM
martno1fan
Score: 155
Status: offline
Very nice Scott she looks great  mate.
Mart
Manufacturer of quality gas boat mouldings.
waveridermouldings.zoomshare dot com
Hide Signatures
       Post #: 213
RE: Duplicating an existing hull...ETHICALLY! - 6/12/2009 1:05 AM
bondobuster
Score: 100
Last Login: 10/31/2009
Status: offline
Scott, congrats on a succesful new project. Can't get over the styling of the boat. Can you give us size/ weight specs on the finished hull? Again the Maestro has come up with another masterpiece!!!!!! BRAVO!!!
Hide Signatures
(in reply to martno1fan)
       Post #: 214
RE: Duplicating an existing hull...ETHICALLY! - 6/12/2009 1:27 AM
Dreamin Hemi
Score: 150
Status: online
Hey thanks a lot guys.  It was a fun ride.
As far as some specs go, here they are!
NEMESIS CATAMARAN
Overall Length:  49.5"
Total Beam: 14.75"
Height to top of deck (from sponsoon bottom to highest point on deck):  5.5"
Total height incl. canopy highest point:  9.25"
Weight on THIS lay up:  8.1 lbs with polyester resins (seems good, can of course adjust)
< Message edited by Dreamin Hemi -- 6/12/2009 1:28 AM >
Hide Signatures
(in reply to bondobuster)
       Post #: 215
RE: Duplicating an existing hull...ETHICALLY! - 6/12/2009 3:07 AM
nvs motorsports
Score: 100
Status: offline
Well done Scott looks awesome
The weight seems good im around 7.8 pounds so your on the money hows she feel for strength thesides should be indestructible the way the join is designed
Hide Signatures
       Post #: 216
RE: Duplicating an existing hull...ETHICALLY! - 6/12/2009 4:21 AM
infinityteg
Score: 100
Status: offline
Hi scott
Thanks for the thread. its been great reading and a real learning curve. I am in the process of making a plug for a jet sprint hull and am working on the seamless finish.
just one q? When joining the hull and deck, does it have the whole seam taped or is it just the sides taped and the front section of the hull/deck bonded together with the gelcoat/bog mix
thanks again
cheers
steve
Hide Signatures
       Post #: 217
RE: Duplicating an existing hull...ETHICALLY! - 6/12/2009 11:25 AM
Dreamin Hemi
Score: 150
Status: online
Steve, access is very limited, however using an arrow shaft taped to my brushes, I'm able to glass the length of the entire sides.  Also the 90 degree area across the sponsoons is glassed.  The only areas NOT glassed are the ones inside the sponsoon areas up at the fork.  Here I had placed more bog since I knew access was almost impossible.  So only about 7-8" of the nose is not taped, fortunatly not in a critical area.
< Message edited by Dreamin Hemi -- 6/12/2009 1:04 PM >
Hide Signatures
(in reply to infinityteg)
       Post #: 218
RE: Duplicating an existing hull...ETHICALLY! - 6/12/2009 1:17 PM
dreamwakes
Score: 100
Status: offline
Nice job Scott, one of the great messages in this thread is it shows anyone out there  buying  hulls  what they should look for in hull construction quality before forking out the dosh.
There are those who will always copy unethically!!...but generally speaking those who engage in this trade do not have the skills to build their own ideas and this follows through into the quality of building/ laminating in the finished product., A trained eye will see these defects and know they are not getting a product built with pride.
Thankyou for training those eyes.
Hide Signatures
       Post #: 219
RE: Duplicating an existing hull...ETHICALLY! - 6/12/2009 7:29 PM
Gerwin Brommer
Score: 100
Last Login: 11/6/2009
Status: offline
Scott for president !
Outstanding job !
Ps : I did send you an email with another mindblowing project...
Hide Signatures
       Post #: 220
RE: Duplicating an existing hull...ETHICALLY! - 6/12/2009 8:51 PM
macz
Score: 100
Status: offline
WOW!! Scott great job...can Il trade you my cat for one of yours.....lol.
Hide Signatures
(in reply to Gerwin Brommer)
       Post #: 221
RE: Duplicating an existing hull...ETHICALLY! - 6/12/2009 10:28 PM
nothinbetr2do
Score: 110
Status: offline
scott, the boat looks sweet, great job with it. i like the name to.  when i get the decals made for it, i'm going to include the name to. just not sure where i'm going to put it yet. maybe across the back or something. as i want to flame the rest of it. anyway again, great job with it and thanks for posting all the pics and info. i also returned your pm, tony
Hide Signatures
(in reply to macz)
       Post #: 222
RE: Duplicating an existing hull...ETHICALLY! - 6/13/2009 12:40 PM
Dreamin Hemi
Score: 150
Status: online
quote:
ORIGINAL: Gerwin Brommer
Outstanding job !
You guys are too much...I hate politics!!!  lol
Thanks for the kind words.
Making minor flange alterations to the molds and will be reconditioning the molds using the box full of conditioning and release products that TR was kind enough to send to me....one can of everything they offer!!!  I'll probably show the steps involved here, I don't know.  Definately don't HAVE to with these new molds, but I found out the sealer I had was not what I was supposed to use.  With the entire line of TR products in hand, I know the first release of a hull without PVA will be a success.  Would still be ok without doing this, but hey....it's summer here and I have 3 months off from students until the next school year!
Hide Signatures
       Post #: 223
RE: Duplicating an existing hull...ETHICALLY! - 6/13/2009 1:07 PM
twindaddy66
Score: 100
Last Login: 10/26/2009
Status: offline
Nice Scott, VERY nice. Congrats....oh hey...where are the cigars???
Rio 51 w/CY26... Supervee27 Nitro...Honey Bee King 2...E-REVO...E-MAXX...E-Savage...Futaba 3PK FASST
Hide Signatures
       Post #: 224
RE: Duplicating an existing hull...ETHICALLY! - 6/13/2009 1:25 PM
Dreamin Hemi
Score: 150
Status: online
The man is coming over to pick up this #1 hull today.  May have to burn one with him back here in my shop as we add some gear after we return from Aeromarine Laminates this afternoon with all his hardware.
Hide Signatures
(in reply to twindaddy66)
       Post #: 225
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
1.594RCU1
