ND_newbie
ND, USA Status: offline
All, I'm nearing completion on my initial Debonair. Which is a good thing, because I've been working on it for around two months now. (Every time I read the item in the description about how Tattoo built the prototype for this in a day, I just laugh at myself). Anyway, I'm curious about the link from the rudder servo to the nose gear. Is this just a length of 2/52 wire, guarded by a plastic sleeve? And could I substitute a dowel/pushrod assembly, such as the one used for the elevator and/or rudder, in its place? I'm not sure that my local hobby shop (which happens to be 130 miles away) carries any pushrods long enough to reach the nose from the rudder servo. Also, for the throttle linkage, can I just use a 2/52 pushrod connected directly to the throttle servo, or is there a preferred method? And finally, as soon as I finish this, I'm going to start on a spadet, for my 9 year old to fly. I have a Tower .40, and an MDS .48, to put on my 'Deb and the Spadet. Can anyone give me reccommendations on which engine I should put on the Deb, and which one should go on the Spadet? Thanks so much in advance. Mitchell Schaff Williston, North Dakota
