LED failure on EQ6
Tower Hobbies
Logged in as Guest
    Search This Thread
Printable Version
Carden Aircraft Cap 232 40%
Seller:  5811
Details:   $2,600.00   |  10/27/2009   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> Radios, Batteries, Clubhouse and more >> RC Radios, Transmitters, Receivers, Servos, gyros >> Radio Manufacturer Direct Support >> Smart-Fly (Quest Engineering) Support Forum >> LED failure on EQ6
Page: [1]
Login
LED failure on EQ6 - 5/12/2009 9:41 PM
LundFalcon
Score: 100
Last Login: 8/31/2009
Status: offline
Hi Robert,
I'm a happy owner of an EQ6, and it has served med well during a couple of years now. It still does, but I found out that the green LED on channel 7 came loose, and only works if I push down on it!!!!
Channel 7 is not in use in my setup, but I need to ask, if the "loose" LED can cause a failure during flight?
Kind Regards
Michael Lund
Denmark
Hide Signatures
       Post #: 1
RE: LED failure on EQ6 - 5/12/2009 9:47 PM
rrritchey
Score: 100
Last Login: 11/2/2009
Status: offline
Hi Michael,
No, it will not cause any problems. There is nothing it can short. Let me know if you have any other questions.
_____________________________
Robert Ritchey
Owner, Smart-Fly
Hide Signatures
(in reply to LundFalcon)
       Post #: 2
RE: LED failure on EQ6 - 5/12/2009 10:47 PM
LundFalcon
Score: 100
Status: offline
Great, thanks for your reply!! Then I'll go fly
Btw, I am know using a JR 921 reciever, and I've read the other posts about not using the BATT connections etc. You mentioned that THRO and AUX4 should be used for the powerleads, but in my setup, I prefer using GEAR and AUX3!!! Should that give any problems?
Regards
Michael
Hide Signatures
(in reply to rrritchey)
       Post #: 3
RE: LED failure on EQ6 - 5/12/2009 10:58 PM
rrritchey
Score: 100
Status: offline
Hi,
No, that is not a problem, your outputs on the unit are just out of order. The power leads are ALSO channels. Even if you plug the first power lead into throttle you can still use the output on the side for that channel.
Robert Ritchey
Owner, Smart-Fly
Hide Signatures
       Post #: 4
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.578RCU1
