RE: Thrust line, Datum line, Center line?
Tower Hobbies
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> Aerodynamics >> RE: Thrust line, Datum line, Center line?
Page: <<   < prev  1 [2]
Login
RE: Thrust line, Datum line, Center line? - 5/23/2009 9:22 PM
buzzard bait
Score: 100
Last Login: 11/8/2009
Status: online
Consider a plane that has, with respect to a datum line, – 3 degree thrustline, +2 degrees wing incidence, and +1 degree stab incidence.
Now consider the same plane, same datum line, but we change all the angles.  Now it has 0 degree thrustline, +5 degrees wing incidence, and +4 degrees stab incidence.
The last example actually describes the S.E.5a (in the picture – note the stab is shown at 0 degrees, but it was adjustable, and rigging diagrams had it set to +4).
These two planes have exactly the same downthrust, not with respect to the datum line, but in actual flight.  If we don’t agree on the simple geometry of this comparison, there is nothing more I can say.
Click to see fullsize image.
Click for fullsize
Hide Signatures
(in reply to CrateCruncher)
       Post #: 26
RE: Thrust line, Datum line, Center line? - 5/24/2009 1:52 PM
buzzard bait
Score: 100
Status: online
So let's take this same S.E.5a and change the angles.  Set the engine to -5 degrees, wing to 0, stab to -1.  Should fly the same, right?  Except the fuselage will move through the air at a different angle.
Anyone looking at the plane after changing the angles would immediately say it has downthrust, even though all the relative angles are exactly the same as they are in the picture above.  Of course, in the picture above, the plane doesn't look like it has downthrust to most people.
Now here's the take home message:  A scale modeler who is using a lot of down trim to keep his plane from climbing too much might be tempted, or advised, to reduce the wing incidence.  But if he did that, he would reduce the downthrust, unless he changed that too.  You could build an S.E.5a with 0 wing incidence, but then it wouldn't have any downthrust.  Even worse, it wouldn't look like an S.E.5a anymore.  Wing incidence is a very noticeable characteristic.  Why bother building a scale model if you're going to undo the effect by changing the wing incidence?
With reduced wing incidence the plane would indeed use less down trim, but that's not the real problem.  Who cares if you are carrying down trim?  The real problem is the difference between trim at low throttle and high throttle.
Of course full scale airplanes have this "problem" too.  That's why pilots are taught that the throttle, not the elevator, is to control climb and descent.  But many people expect their scale models to fly like their sport models.  That's the real source of the problem.
Hide Signatures
(in reply to buzzard bait)
       Post #: 27
RE: Thrust line, Datum line, Center line? - 5/24/2009 2:35 PM
1texasgolfer
Score: 100
Last Login: 10/6/2009
Status: offline
Hello everyone this is my first post.
I've been a bodyman for a good long time.  We use a Datum line when repairing frames unibody and such.  It is a imaginary line used for measurments, this can be used for repair or manufacturing. For instance locating the lower controll arm mounting bolts. Also used for specific heights.    Now change controll arms for landing gear strut mounting bolts, turbo prop mounts, wing spars and ribs while loaded or unloaded, etc.   you get the idea.
Hide Signatures
(in reply to Skratchbilt)
       Post #: 28
RE: Thrust line, Datum line, Center line? - 5/24/2009 3:31 PM
CrateCruncher
Score: 100
Status: offline
Yes, the planes are rigged identical.  Rigging the SE5 at (-3,+2,+1), or (0,+5,+4) or even (-4,+1, 0) is doing the same thing to the plane.  The only difference is that the Datum Line that the numbers are referenced to has inclined in angle.  The airplane doesn't care.  But notice that in all of the examples that the angle between the prop thrustline and stab is 4 degrees.  That number will determine the dynamic balance of the fuselage regardless of where the wing is set.
An example.  If we take a 10 pound iron bar and tie a string at the exact center and hang it by the other end of the string to the ceiling we can closely model an airplane fuselage.  The string tied to the ceiling represents the wings lift.  If you lightly touch one end of the bar it will rotate in pitch about the center where the string is attached.  This is exactly what an airplane fuselage does in flight.  The only difference is that the engine and tail group are different weights so the "string" has to be tied to the fuselage with a forward bias to accomodate the heavy motor.  Visualizing this heavy bar on a string idea is critical to understanding dynamic balance.
In your SE5 example (-4, +1, 0) the wing (+1) is just along for the ride.  The number that the plane cares about is (-4,  , 0).  If we make the runway on the surface of the earth our Datum Line the fuselage pitch in level flight will be a balance between the downward force at the nose of the plane and the lift force at the tail (could be + or -).  At 3/4 throttle, level flight might be (-2,  ,+2) but full throttle the plane now flies at (-5,  ,-1).  The -4 degree difference between thrust and stab of your SE5 was chosen based on engine power and stab lift so that the plane would pitch forward just enough to maintain level flight as airspeed increased.
So now if we look at the SE5 (-4, +1, 0) we can see that changing it to (-4, 0, 0) doesn't decrease the downthrust 1 degree, it decreases the wing incidence by 1 degree at all airspeeds because the difference between thrust angle and stab is still 4 degrees.  Alternatively,  changing it to (-3, +1, 0) is a 1 degree reduction in downthrust because the difference between thrust and stab is now 3 degrees.  The reason for this is that the Y component of the thrust is reduced but the tails ability to generate lift at different angles of attack has not been.
PS: Welcome to RCU 1texasgolfer.  I think you'll like it here.
< Message edited by CrateCruncher -- 5/24/2009 3:49 PM >
_____________________________
"Never be seen with an ugly airplane."
Hide Signatures
       Post #: 29
RE: Thrust line, Datum line, Center line? - 5/24/2009 3:59 PM
CrateCruncher
Score: 100
Status: offline
Indeed full scale airplanes are rigged to climb at full throttle so the pilot doesn't have to pull the stick back for 20 minutes while climbing to cruise altitude.  Our models absorb a considerable portion of out attention just keeping them within visual range.  Thats why they are rigged to be altitude neutral with throttle setting.  While your comments on full scale craft are interesting Buzzard it just confuses this discussion.  Lets try to use R/C examples ok?
Let's design a very simple .60 size low wing sport plane.  It will weigh 7 pounds, with 60" span and 11" constant chord.  I will make the stab parallel with the fuselage angle for simplicity.  It will use a NACA 0012 airfoil.  I want it to be altitude neutral at both half throttle (V = 50 mph  or 73 fps) and full throttle (V=80 mph or 117 fps).  How should I rig it?
Weight =  Lift (full throttle)
mg =( Cl ) A (r) V^2 (1/2)
Solving for Cl at full throttle,  Cl = 2mg/rAv^2 = 2(7)32.2/(.0745)4.58(117)^2 = 0.097
Looking this up on a lift chart for NACA 0012 we discover a Cl of 0.1 corresponds with an angle of attack equal to 1 degree.
We now know that if we want the fuse straight at full throttle the rigging needs to be (  ,+1, 0).  We still don't know the thrust angle we need so it is left blank for now.  We could easily tune the plane at this point through trial and error by simply adding a degree of downthrust at  a time until it flies level but we can still get closer before we have to get our hands dirty.
Weight = Lift   right?   so,  Lift (half)  = Lift (full)  also.  Writing the lift term for each throttle and speed setting we find that all the constant terms drop out and leave us with a ratio:
Cl v^2 = Cl v^2  so, Cl(half) = .097 (117^2/73^2)  = 0.249
Again, looking this up on the NACA 0012 chart we see that a Cl of 0.25 corresponds with 2.5 degrees angle of attack.  So we're only talking about 1.5 degrees difference in the angle of the fuselage between half throttle and full throttle!  We could do a free body diagram and determine the lift generated by the stab, thrust relative to the throttle setting etc but its probably easier to just go the field and start at (-2, +1, 0) and change the first number up or down until it maintains altitude at full throttle.
< Message edited by CrateCruncher -- 5/24/2009 10:40 PM >
Hide Signatures
       Post #: 30
RE: Thrust line, Datum line, Center line? - 5/27/2009 1:54 PM
Mode One
Score: 120
Status: offline
CrateCruncher, Your last post seems to run away with this thread.  My question has been sufficiently answered, so have at 'er.
Hide Signatures
       Post #: 31
RE: Thrust line, Datum line, Center line? - 5/27/2009 4:34 PM
dick Hanson
Score: 100
Status: offline
Interesting how different people view the  use of referrence lines
 On the latest superlight electric aerobats  (rc types of  400 sq inches ) the  entire model is simply laid out  0-0-0
 why?
 because amodel this  size may  weigh -ready to fly - 6 ounces (not a misprint) and have  thrust of 18 ounces  (not a misprint.)
 with these  relationships  ,the  angles of attackneeded  are  extremely small  for  even fairly sharp maneuveing
 fo r th  wild n wooly flailing
 the model can actually turn in it's own length  with litle or no noticable  loss of  altitude
We can't post videos here (thank goodness) but there are a number of  videos of models which do this  very easily and smoothly.
  http://slowflyworld.de/sfw-yak-54.WMV
 here is one which is quite  revealing.
 Tho this type flying may seem preposterous to some - the  technical  advances which have made it possible  are  very interesting
Better yet , by  adapting the  methods learned , many new  RPV (pilotless craft) can do things totally impossible  with piloted vehicles
 In models   we have  adapted eight to power  and wingloadings,  totally  removed from those when we first flew RC in 1970
 much of the  data considered necessary  then , is  simply not needed  for  this apprach . stalling-,
 banking required for  turns-  take off  minimum speeds -,  etc., are not relevant
 the model  flies at ANY speed because  power (thrust) and lift generated by all surfaces of the model  can be  played  with  at will.
 Tho it aint relevant - I am building a  Neuport at the moment
 just because I like to play with   different  types of flying
The Neuport won't  be expected to do any of the  tricks the  YAK does in the  video..
< Message edited by dick Hanson -- 5/27/2009 4:55 PM >
I am watching you
Libby
Hide Signatures
(in reply to Mode One)
       Post #: 32
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
3.219RCU1
